paulmillner
Joined: 09 May 2007 Posts: 21 Location: Berkeley, California
Posted: Fri Dec 10, 2010 12:39 pm Post subject: Grounding Sensors |
I solved this by installing a spring in the stack... so that the spring
keeps the washer tight against the sensor body, and makes up for
differences in pipe thread make-up.
Paul
On 12/9/2010 11:56 PM, AeroElectric-List Digest Server wrote:
| Quote: | If the brass fitting had NPT threads, trying to clamp a tabbed washer
between the fitting and the manifold is probably not a good idea.
Clamping force is required to maintain electrical contact/continuity
with the washer, fitting& sensor. NPT threads depend on taper&
interference fit to seal. Finding the perfect thickness of washer to
fill the gap between the manifold boss and the adapter shoulder while
maintaining the correct fit of the NPT threads without over- or
under-torquing might be challenging.
_________________ Paul Millner, Berkeley CA [OAK] |
