bankshire(at)harboursat.c Guest
Posted: Tue Dec 07, 2010 1:41 pm Post subject: Key Switch & LSE Ignition |
Hi all,
Will be using a standard aircraft key switch and connecting L/H mag P lead to terminal L on switch with shield grounded at mag and connected to GRD terminal on switch.
The LSE ignition key switch option (P) lead from output connector pin 1 to terminal R on the switch. This lead is shielded and connected to pin 9 on the output connector of the LSE and GRD terminal on the switch.
Q 1 Does the switch GRD terminal need to be grounded to the airframe ie battery ground because of the LSE ignition.
Q 2 Do I use the Jumper between the GRD & R terminals on the switch. ( Aerosportpower O360 with 1 mag L/H & LSE ignition R/H )
Q 3 Separate from above which TACH signal on LSE would be best to use for DYNON EMS Pulse or Analog
Hope I have explained this clearly and look forward to your replies thanks John Dehnert.
