robertbrunk(at)mac.com Guest
Posted: Sun Dec 19, 2010 9:35 am Post subject: F1028 blocking a/c |
I am trying to remove a black box containing the blower fan for my flightline a/c. So I can send it to John strain to get more volume so it will cool in my hot s Texas climate . I can't get it out because this brace blocks access to the rear baggage area . What can I do to allow the access I need to remove the box? Frustrated in corpus christi. N661g 300+ in condition mode
Robert E. Brunkenhoefer
Brunkenhoefer Law Firm, P.C.
606 N. Carancahua Street
Suite 1200
Corpus Christi, Texas 78476
Phone: 361-888-8808
Facsimile: 361-888-6753
robert(at)brunklaw.com
thane
Posted: Sun Dec 19, 2010 10:02 am Post subject: F1028 blocking a/c |
I have his system, can you slide it back off the tray and then drop it down
under the tray and forward?
Clearly many components will have to be removed to do this; ducting etc.!!
Maybe take some measurements to see if it would fit that way??
Thane States
321BY
166hrs.
_________________ Working on finish kit: I hate fiberglass!! |
Posted: Sun Dec 19, 2010 10:29 am Post subject: F1028 blocking a/c |
Great idea we will do as you suggest. What about the vertical brace that blocks the access.
Suite 1200
Phone: 361-888-8808
On Dec 19, 2010, at 11:58 AM, Thane States <thane2(at)comporium.net> wrote:
I have his system, can you slide it back off the tray and then drop it down under the tray and forward?
Clearly many components will have to be removed to do this; ducting etc.!! Maybe take some measurements to see if it would fit that way?? Thane States
321BY
166hrs.
Posted: Sun Dec 19, 2010 1:25 pm Post subject: F1028 blocking a/c |
Is the fan speed inside the black box on top or the round thing with the fan blades exposed?
Suite 1200
Phone: 361-888-8808
321BY
166hrs.
Posted: Sun Dec 19, 2010 1:26 pm Post subject: F1028 blocking a/c |
I cannot slide the box back off the tray.
Suite 1200
Phone: 361-888-8808
321BY
166hrs.
