GPS antenna location
Kelly McMullen
PostPosted: Wed Nov 24, 2010 7:38 am    Post subject: GPS antenna location Reply with quote
Has anyone mounted their GPS antenna(s) underneath the cabin cover,
say inside an overhead console? Is there any reason the cabin cover
fiberglass would not be transparent to GPS signals? Given that Vans
mostly implies the cover is structural and discourages drilling beyond
what the plans call for, I'd rather put antenna on underside than
drill holes for coax and mounting. Not to mention avoiding the drag
and appearance of extra protrusions. Figuring will have minimum of
430W, EFIS independent GPS, and possibly ADS-B GPS antennas.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
recapen(at)earthlink.net
PostPosted: Wed Nov 24, 2010 7:51 am    Post subject: GPS antenna location Reply with quote
Not underneath a cabin cover - but inside the engine cowl...with fresh (non-metallic) paint on it. Still works fine.
Mine's a Garmin 420W...
pitts_pilot(at)bellsouth.
PostPosted: Wed Nov 24, 2010 8:07 am    Post subject: GPS antenna location Reply with quote
I agree that under the cowl is better than under the cabin top only
because of the thickness of the cabin top. FG isn't really transparent
to the GPS signal, and the thicker the FG, the more degradation of the
GPS signal. The heat under the cowl is also a consideration, but the
heat under the cabin top will probably get as high in direct sunlight,
depending on the color paint used. So far I'm planning on putting my
GPS antenna under the cabin top too, inside my fresh air plenum. That
is until I get feedback from those that had problems with it there.
Linn
Y'all have a great Thanksgiving tomorrow!!!!
Kelly McMullen
PostPosted: Wed Nov 24, 2010 8:24 am    Post subject: GPS antenna location Reply with quote
Yes, that is exactly what I have in mind. Just trying to get all the
planning for what will/won't go inside the lovely carbon fiber
overhead console before permanently glassing the console in place.
Really want to minimize external antennas. Current plane looks like
porcupine with 2 comms, loran Elt,VOR, stormscope, Adf and transp ants
sticking out everywhere.,
Remember, keep your base empty wt under control on T-day. Allegedly
easier than controlling wt of what is attached to plane.
On Wed, Nov 24, 2010 at 9:04 AM, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
 So far I'm planning on putting my GPS antenna under the cabin
top too, inside my fresh air plenum.  That is until I get feedback from
Linn
Kelly McMullen
KCHD
rv10builder(at)verizon.ne
PostPosted: Wed Nov 24, 2010 8:36 am    Post subject: GPS antenna location Reply with quote
I grabbed a GPS and put it under the cabin cover, received a reception just
fine, so I put my antenna inside/above a self made overhead console that
will sit right over the area where the front seats are.
The antenna is easy enough to move if it does not work. I don't like the
idea of the excessive heat from the engine area, may not be an issue for the
antenna but I know of a couple of times my (car) gps did not work due to
being overheated sitting in the trunk one summer, so that tells me it cant
be a good thing having all the heat over any items that don't need to be in
the engine area(aka designed for that location)
Pascal
Sent: Wednesday, November 24, 2010 7:32 AM
Subject: GPS antenna location
I'm not convinced that glassing the overhead console in place is a good
idea. I realize that you have access panels in the CF OH consoles, but
you never know what's going to occur down the road (airway??? Wink ). My
OH console will not have an access cover so I plan on embedding nuts in
the cabin top so I can put screws in to hold the OH console up. I had
also thought of using silicone to mount the OH console .... and haven't
tossed the idea out just yet. Anyone have comments????
Linn
Mauledriver(at)nc.rr.com
PostPosted: Wed Nov 24, 2010 11:41 am    Post subject: GPS antenna location Reply with quote
I decided to optimize the mounting of the 430W antenna according to the
best avionics advice I could find. The installation manual being first
and and avionics shop owner second (Bill Betts, SparkChasers, KJNX). My
thinking was 1) every source of advice has a bias 2) the performance of
the 430W WAAS GPS being most important to me, 3) follow the avionics
invested parties advice. So it's mounted on top of the cabin, right in
the middle, far away from any possible interference, holes thru the
cabin top, stuck out in the airstream.
The are 3 or 4 other GPS antenna involved. Here I just tried to find
good locations that should perform satisfactorily, provide easy
installation/maintenance and be aesthetically pleasing. So 2 are
mounted along upper rim of the windshield - a location that's worked
well on my Maule. 1 or 2 are going to be velcroed to the glare shield.
No holes, nothing sticking out, nothing being visually unpleasant.
Not flying so can't say how this will all work out.
Bill "applying high performance Dupont industrial coatings" Watson
Strasnuts
PostPosted: Thu Nov 25, 2010 9:21 am    Post subject: Re: GPS antenna location Reply with quote
Kelly,
I have been going through this as well. I have an ugly double shark fin antenna that has to go on top of the cabin cover as far forward as possible. My problem is the ground plane. Garmin wants 18x18 ground plane and all I can do is 10x33 copper mesh that sandwiches on the inside. With Geoff's overhead console it is really easy to reach inside through the access plates. Also, if you want to look at a nice install that is hidden, look what Robin Marks did on his cabin top. I would think structurally the carbon fiber console has to compensate for the cabin top being milled out.
http://www.painttheweb.com/painttheweb/rv-10/GPSAntenn.aspx
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Jim Combs
PostPosted: Thu Nov 25, 2010 6:23 pm    Post subject: GPS antenna location Reply with quote
I see you all are determined to embed / mount the GPS antenna into the cabin.
Here is another solution.
I have mine under the cowl on a mounted plate attached to the firewall and the top of the engine mount.
Flying now with 200 hours and no issues.  I have access to them, they are easily inspected and
serviced if ever needed, and it a ton easier to do (no fiberglass or routing of cables up to the
cabin top).
I have the 430W GPS antenna, an XM weather antenna, and a stand-alone GPS receiver (49$ driving co-pilot
EFIS and AP).
Food for thought.
Jim Combs
N312F - Flying (again!)
 Filesize:  172.97 KB
 Viewed:  6431 Time(s)
 Filesize:  162.88 KB
RV-10 -> N312F - Flying as of 12/2008
PostPosted: Fri Nov 26, 2010 11:11 am    Post subject: GPS antenna location Reply with quote
I added some pics in my building log here:
http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=4053&log=117562&row=2
the best avionics advice I could find. The installation manual being
first and and avionics shop owner second (Bill Betts, SparkChasers,
KJNX). My thinking was 1) every source of advice has a bias 2) the
performance of the 430W WAAS GPS being most important to me, 3) follow
the avionics invested parties advice. So it's mounted on top of the
cabin, right in the middle, far away from any possible interference,
holes thru the cabin top, stuck out in the airstream.
shield. No holes, nothing sticking out, nothing being visually
unpleasant.
PostPosted: Fri Nov 26, 2010 11:26 am    Post subject: GPS antenna location Reply with quote
Bill, thanks for the pics. But they posed the question why you mounted
the small GPS antennas under the upper windscreen rather than down on
the glareshield??? Inquiring minds want to know.
Linn
> being first and and avionics shop owner second (Bill Betts,
> SparkChasers, KJNX). My thinking was 1) every source of advice has a
> bias 2) the performance of the 430W WAAS GPS being most important to
> me, 3) follow the avionics invested parties advice. So it's mounted
> on top of the cabin, right in the middle, far away from any possible
> interference, holes thru the cabin top, stuck out in the airstream.
> find good locations that should perform satisfactorily, provide easy
> unpleasant.
PostPosted: Fri Nov 26, 2010 3:31 pm    Post subject: GPS antenna location Reply with quote
No reason than just to get them up and out of the way. I didn't think
they would interfere with visibility (?).
As I recall, the question I answered with the one antenna on the glare
shield is "why did they use such a plug so big I couldn't string it thru
the center strut"?
mounted the small GPS antennas under the upper windscreen rather than
down on the glareshield??? Inquiring minds want to know.
Linn
>> a bias 2) the performance of the 430W WAAS GPS being most important
>> to me, 3) follow the avionics invested parties advice. So it's
>> mounted on top of the cabin, right in the middle, far away from any
>> possible interference, holes thru the cabin top, stuck out in the
>> airstream.
>> unpleasant.
davidsoutpost(at)comcast.
PostPosted: Fri Nov 26, 2010 4:11 pm    Post subject: GPS antenna location Reply with quote
I am several months away from starting work on the fiberglass canopy but what was the reason for the tinted lexan cover over the GPS antenna's? Every antenna in the Cozy MKIV we built is buried under the glass and works flawlessly. The GNS 430 antenna was actually mounted on a shelf in the nose of the plane. and is receiving through 4 layers of glass, 3/4"foam, and 3 more layers of glass.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
dlm46007(at)cox.net
PostPosted: Fri Nov 26, 2010 5:19 pm    Post subject: GPS antenna location Reply with quote
antennas do fail; you might want to change it. reception is not the problem, maintenance is.
PostPosted: Fri Nov 26, 2010 7:14 pm    Post subject: GPS antenna location Reply with quote
That's true,, however the antenna's appear to be easily accessible from inside the cabin via the overhead console and weakening the integrity of the canopy could have been avoided.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
