tdawson-townsend(at)auror Guest
Posted: Sun Nov 21, 2010 10:07 pm Post subject: Weight & Balance datum |
I guess I can call Van’s this week, but I had a couple questions I throw out there on W&B moment arms:
<![if !supportLists]>a) <![endif]>The pilot moment arm is given as 114.58”, but of course, the front seats are adjustable through a range. Where did Van’s place that point?
<![if !supportLists]>b) <![endif]>Likewise, the baggage area is quite large, so is the Van’s-chosen moment arm location in the center? At the (conservative) aft end of the baggage area?
I guess I can measure those myself next time I’m at the hangar, but thought I would write this while thinking about it.
TDT
Tim Dawson-Townsend
RV-10 N52KS (http://aprs.fi/?call=n52ks)
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
57.07 KB |
1449 Time(s) |
coop85(at)verizon.net Guest
Posted: Mon Nov 22, 2010 7:41 am Post subject: Weight & Balance datum |
FWIW the pilot location is pretty insignificant as you are essentially sitting on the CG. As for the baggage area I would guess the center, but you could measure it pretty easily comparing one of the other fixed points (like the leading edge of the wing if I remember correctly).
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Monday, November 22, 2010 1:02 AM
Subject: Weight & Balance datum
TDT
Tim Dawson-Townsend
57.07 KB |
1444 Time(s) |
