fuel flow transducer location
rvdave
PostPosted: Fri Nov 19, 2010 11:19 pm    Post subject: fuel flow transducer location Reply with quote
Plans show transducer to be in the tunnel, I've heard there are less fluctuations if it is placed after the mechanical pump and before distribution for fuel injection, is this correct?
Dave Ford
Cadillac, MI
daveleikam(at)wi.rr.com
PostPosted: Sat Nov 20, 2010 4:41 am    Post subject: fuel flow transducer location Reply with quote
I called Flo-Scan about the placement of mine and they told me the worst place to put the sensor is between the electric pump and the mechanical pump. Best would be before both pumps. I put mine after the fuel servo mounted on top of the air box. Flo-Scan said this would work fine.
Dave Leikam
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=320145#320145
David Leikam
RV10
N89DA
Kelly McMullen
PostPosted: Sat Nov 20, 2010 4:51 am    Post subject: fuel flow transducer location Reply with quote
As always, it depends. You want straight hose on either side of the
transducer for smooth transition without burbles. Sometimes that is
easier between fuel pump and servo, sometimes easier between servo and
flow divider. I suppose if one moved the boost pump and filter forward
in the tunnel it could be ahead of the filter.
On Sat, Nov 20, 2010 at 5:38 AM, David Leikam <daveleikam(at)wi.rr.com> wrote:
Dave Leikam
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
David Leikam
RV10
N89DA
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
davidsoutpost(at)comcast.
PostPosted: Sat Nov 20, 2010 5:35 am    Post subject: fuel flow transducer location Reply with quote
I just finished mounting mine yesterday and used the EI red cube FT-60. I mounted it in the tunnel and have 6" straight line before and after the cube.  I know it is between the electrical Andair pump and the mechanical pump but it is the recommendation location by Vans and I want less fuel fittings and lines in the engine compartment. I will move it if needed after the plane is flying. I will make up a new bypass fuel line while the tunnel is easily accessible just in case it needs to be moved.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
Robin(at)PaintTheWeb.com
PostPosted: Sat Nov 20, 2010 6:51 am    Post subject: fuel flow transducer location Reply with quote
I mounted mine (not the red cube) in the tunnel with a nice long smooth lead in and out of the transducer and my readings were basically useless. Boost pump on added 3-5 gph with some bouncing. Boost pump off had 1-3 gph bouncing including low reading bouncing into the yellow that gave me low fuel flow warnings both in climb out and randomly in cruse flight. BTW this also threw off my fuel consumption/remaining fuel calculations. Not good!  Furthermore the bouncing makes it impossible to balance ones fuel injectors as you cannot get accurate FF readings.
Finally fed up with the issue we relocated the transducer between the fuel servo and flow divider. Since then my readings have been rock solid and all low fuel pressure warnings + bouncing is gone. If building I would not waste my time placing the transducer in the tunnel again.
Sorry no photos.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of davidsoutpost(at)comcast.net (davidsoutpost(at)comcast.net)
Sent: Saturday, November 20, 2010 5:26 AM
Subject: Re: fuel flow transducer location
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
jump2(at)sbcglobal.net
PostPosted: Sat Nov 20, 2010 7:25 am    Post subject: fuel flow transducer location Reply with quote
Has any of you ask about the long term or short term of the vibration from engine on the transducer,if you mount it on the engine and not a solid piece of the aircraft such as the firewqll or engine mount?
My understanding is it shortens the life of the transducer.
Just my thoughts.
Patrick Thyssen
--- On Sat, 11/20/10, Robin Marks <Robin(at)PaintTheWeb.com> wrote:
Subject: RE: fuel flow transducer location
Date: Saturday, November 20, 2010, 8:48 AM
Sorry no photos.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of [url=/mc/compose?to=davidsoutpost(at)comcast.net]davidsoutpost(at)comcast.net[/url]
To: [url=/mc/compose?to=rv10-list(at)matronics.com]rv10-list(at)matronics.com[/url]
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
aerosport1
PostPosted: Sat Nov 20, 2010 8:09 am    Post subject: fuel flow transducer location Reply with quote
Here is were I mounted mine. 170 HRS and so far so good. I know other people have it here as well.
Geoff Combs
 Filesize:  554.91 KB
 Viewed:  12461 Time(s)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
dlm46007(at)cox.net
PostPosted: Sat Nov 20, 2010 8:20 am    Post subject: fuel flow transducer location Reply with quote
I too mounted the GRT unit as shown in the tunnel by Vans; no problems from beginning TT360
Deems Davis
If you look at the documentation that JPI sends with their products for installing their (Floscan) sensor, it recommends installation on the hose inline between the servo and the spider, next best location is between the mech pump and the servo. None of their instructions call for hard mounting the transducer. Floscan lists the bearing life as 10,000 hrs.
Deems
On 11/20/2010 8:18 AM, Patrick Thyssen wrote: [quote]
Just my thoughts.
Patrick Thyssen
--- On Sat, 11/20/10, Robin Marks <Robin(at)PaintTheWeb.com> (Robin(at)PaintTheWeb.com) wrote:
From: Robin Marks <Robin(at)PaintTheWeb.com> (Robin(at)PaintTheWeb.com)
Sorry no photos.
Robin
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
rv10builder(at)verizon.ne
PostPosted: Sat Nov 20, 2010 8:21 am    Post subject: fuel flow transducer location Reply with quote
Look at the archives for "569JC" (April 2010)
Here is the bottom line however:
What went wrong? The short version: a fuel line broke.
The long version: During final assembly it came to my attention that
people
with the Fuel Flow transducer in the =93Tunnel=94 where experiencing FF
fluctuation when using the electric pump. The fix? Move the FF
Transducer to
between the Fuel Injection Servo and the Spider. Well, that=92s what I
did.
When I relocated the Transducer I had to fabricate a line between the
Servo
and the Transducer. The line I fabricated was =BC inch aluminum, that
was the
flaw. That line broke just outside the fitting. When I made that line I
made
sure it wasn=92t under any stress, in a natural position, etc.
Apparently that
was not enough. Now, I will say this. This was the one component of the
airplane I was never quite happy with. It just =93didn=92t look
right=94. I had
some other builders take a look, half heartedly hoping they would tell
me
that aluminum was bad and I should change it, but no one did. So it
stayed,
and worked fine for 58 hours.
https://dl.dropbox.com/u/5834625/RV10/photo%203.jpg
Ask yourself, if already installed, if it's worth moving the transducer. There was talk of this in the past and in the end a high time flyer left his where it is and knows for the times the fuel pump is on the transducer is inaccurate but ultimately it plays little factor in the big scheme of things. I saw Robin's post and know he had pains but I also know of two others that have not.
I was worried about this in the past so I bring this up so the newer builders don’t get worried about moving the transducer. I say- leave it alone and deal with it once flying if it's an issue of safety or other concern.
Pascal
Sent: Saturday, November 20, 2010 7:18 AM
Just my thoughts.
Patrick Thyssen
--- On Sat, 11/20/10, Robin Marks <Robin(at)PaintTheWeb.com (Robin(at)PaintTheWeb.com)> wrote:
Subject: RE: RV10-List: fuel flow transducer location
Sorry no photos.
Robin
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
rv10flyer
PostPosted: Sat Nov 20, 2010 8:41 am    Post subject: Re: fuel flow transducer location Reply with quote
Mine is going in the tunnel per plans. Will move after flying if I feel it is needed then.
Wayne G.
AirMike
PostPosted: Sat Nov 20, 2010 8:50 am    Post subject: fuel flow transducer location - red cube Reply with quote
I put mine in the tunnel per the plans. Flawless readings after 90+ hrs.
See you OSH '18
Q/B - sold.
jfrjr(at)roadrunner.com
PostPosted: Sat Nov 20, 2010 8:53 am    Post subject: fuel flow transducer location Reply with quote
I have had such a different experience. GRT supplied transducer in "stock" tunnel location. After calibration it hasn't skipped a beat. Does not fluctuate and doesn't change with or without boost pump Totalizer always within a gallon of actual used--all this after 200 hours. Now I hope I just didn't jinks myself. Jay Rowe 40301
On Nov 20, 2010, at 9:48 AM, Robin Marks <Robin(at)PaintTheWeb.com (Robin(at)PaintTheWeb.com)> wrote:
Sorry no photos.
Robin
From: [url=mailto:owner-rv10-list-server(at)matronics.com]owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)[/url] [mailto:[url=mailto:owner-rv10-list-server(at)matronics.com]owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)[/url]] On Behalf Of [url=mailto:davidsoutpost(at)comcast.net]davidsoutpost(at)comcast.net (davidsoutpost(at)comcast.net)[/url]
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
jcumins(at)jcis.net
PostPosted: Mon Nov 22, 2010 4:01 pm    Post subject: fuel flow transducer location Reply with quote
We have the EI Fuel flow gauge with the red cube transducer in our Saratoga. It works great. It is place between the mechanical fuel pump and the Servo inlet. We have no bounce readings at all very stable and once the fuel flow gauge was programmed for the proper number of pulses it is very accurate. It is located right behind the fuel pump on the back of the engine. We now have over 350 hours on it and no issues at all.
On the RV-10 I am going to mount it between the servo and the Divider valve on the lower front part of the engine. I would not recommend it goes in the tunnel at all.
John G. Cumins
40864 Winds (flutting ribs)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen
Just my thoughts.
Patrick Thyssen
Sorry no photos.
Robin
From: [url=/mc/compose?to=owner-rv10-list-server(at)matronics.com]owner-rv10-list-server(at)matronics.com[/url] [mailto:[url=/mc/compose?to=owner-rv10-list-server(at)matronics.com]owner-rv10-list-server(at)matronics.com[/url]] On Behalf Of [url=/mc/compose?to=davidsoutpost(at)comcast.net]davidsoutpost(at)comcast.net[/url]
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
