kheindl(at)msn.com Guest
Posted: Wed Nov 17, 2010 4:43 pm Post subject: Oil change question |
I don't usually have a problem with getting the oil pressure back after an oil change, but this time I seem to have an airlock.I was going to bypass the tank and connect the in/out hoses together and crank the engine for a few seconds (I am not using ignition).
Is that okay ?
Thanks for any input.
Karl
kevann(at)gotsky.com Guest
Posted: Wed Nov 17, 2010 5:49 pm Post subject: Oil change question |
Karl,
Follow the Rotax Service Instructions SI-912-020, SI-914-021 I get them at www.rotaxowner.com
If you introduced air into the system and do not then properly purge the system, severe engine damage could result.
Kevin
Posted: Thu Nov 18, 2010 5:35 am Post subject: Oil change question |
Hi Kevin,
I think you meant SI-912-10. But it doesn't tell me what to do in my case. I did drain the oil from the hose coming out of the bottom of the engine, but have always done that before. I'll keep handcranking.
Karl
Subject: Re: Oil change question
Date: Wed, 17 Nov 2010 17:46:42 -0800
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Tahoma;font-size:10pt;} Karl,
Kevin
Posted: Thu Nov 18, 2010 7:05 am Post subject: Oil change question |
Hi Karl,
SI-912-018 is the what I meant to say. Purging of the lubrication system is needed if air got in the system. I've never heard of connecting the in/out hoses together as you suggest.
Perhaps your oil pressure sender is at fault?
Kevin
Posted: Thu Nov 18, 2010 9:38 am Post subject: Oil change question |
Kevin,
Yes, that is more like it, and it has a nice diagram also. I don't have a compressor and will make a fitting using a bicycle valve.
The oil pressure reading was fine just before the oil change, so I don't think it is an instrument malfunction.
Many thanks,
Karl
Date: Thu, 18 Nov 2010 07:02:26 -0800
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Tahoma;font-size:10pt;} Hi Karl,
Kevin
