kheindl(at)msn.com Guest
Posted: Tue Nov 16, 2010 10:36 am Post subject: Starter problem fixed |
I should have known that it was something simple, but I just couldn't believe that it was an electrical problem, because I tried a different power source and cables.Anyway, it was the ground connection to the engine, a copper ring connector firmly bolted down. I didn't really see any corrosion, but after cleaning it thoroughly everything worked fine.
C'est la vie.
Karl
gregoryf.flyboy(at)comcas Guest
Posted: Tue Nov 16, 2010 1:11 pm Post subject: Starter problem fixed |
Congratulations on your fix, Karl! Also, thanks for the response. Many times, after a problem is solved, the solution is never placed back on the server. It is sure nice to know what you found. Someone else will undoubtedly have this problem in the future, and will have this to refer to.
Greg F
Karl
