TommyLewis(at)aol.com Guest
Posted: Mon Nov 15, 2010 11:06 am Post subject: rudder stop |
Over the weekend I found that the RV10 rudder stop on the right side has broken, the rivets had been sheared. The rudder stop was laying in the bottom of the rudder. When this has happened to others, have you simply riveted it back on, or replaced rivets with #8 or #6 bolts, or is there an after market replacement???
Tom Lewis
Granbury, Tx
RV10 N143EB
philperry9(at)gmail.com Guest
Posted: Mon Nov 15, 2010 11:27 am Post subject: rudder stop |
Tom,
You can use screws to hold the stops in position. They'll hold up much better in shear.
Van's even made that change on their demo planes. If you look closely you'll see they've changed them all to screws.
Phil
On Mon, Nov 15, 2010 at 1:02 PM, <TommyLewis(at)aol.com (TommyLewis(at)aol.com)> wrote:
[quote] Over the weekend I found that the RV10 rudder stop on the right side has broken, the rivets had been sheared. The rudder stop was laying in the bottom of the rudder. When this has happened to others, have you simply riveted it back on, or replaced rivets with #8 or #6 bolts, or is there an after market replacement???
Tom Lewis
Granbury, Tx
RV10 N143EB
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
get="_blank">http://www.matronics.com/Navigator?RV10-List
tp://forums.matronics.com
Tim Olson
I've heard of people doing it both ways...some have used
Rivets and some have used screws. My only thought is
that if you do indeed replace the rivets with something,
you may actually not want to replace it with something
too strong. If you make it too strong, the forces may
be transferred to other parts, and you may end up
breaking something else. Ultimately, the way to
prevent the problem is to make sure to always use a
rudder gust lock, and make sure that the one you use
is strong enough to withstand whatever is thrown at it.
Tim Olson - RV-10 N104CD
On 11/15/2010 1:02 PM, TommyLewis(at)aol.com wrote:
| Quote: | Over the weekend I found that the RV10 rudder stop on the right side has
Tom Lewis
Granbury, Tx
RV10 N143EB
kdbelue(at)charter.net Guest
Posted: Mon Nov 15, 2010 11:40 am Post subject: rudder stop |
I've found the stock rudder stop to be just about useless. I had to leave my RV10 outside overnight and the next day the wind sheared the stops. It didn't take but about 30 min. Anyway, there's a guy on Van's Airforce website that makes a plastic stop that you bolt to the metal hinge bracket that works much better.
On Nov 15, 2010, at 1:02 PM, TommyLewis(at)aol.com (TommyLewis(at)aol.com) wrote:
Tom Lewis
Granbury, Tx
RV10 N143EB
coop85(at)verizon.net Guest
Posted: Mon Nov 15, 2010 11:49 am Post subject: rudder stop |
Concur with Tim on the gust lock, the rudder can really get knocked around
in a stiff breeze. FWIW I have just been using a cargo strap hooked into a
lightening hole on each horizontal stab and wrapped around the tail light.
Locks the rudder in place great, was free (already had the strap) but isn't
going to win in style points. There are certainly more elegant methods guys
are using, I've just been to cheap/lazy to try one.
As for the rudder stop, there is a nylon aftermarket that I bought but can't
remember who had them. I suggest a search of the archives.
Marcus
Posted: Mon Nov 15, 2010 11:58 am Post subject: rudder stop |
I've looked at the plastic stop and decided not to install it. I just redrill the parts #28 and put in a #6 screw with the nut between the brackets. I noticed on N220RV that Van's had done the same thing when I visited the factory. I'm a little surprised that they didn't modify the manuals to do it that way, but I think that's a sufficient fix for the rivets. As Tim said, the best solution is to get a gust lock that will hold the rudder. The stops are mainly there to have a good hard point to keep the rudder from over-controlling and hitting the elevator and to verify that there is no obstruction in the rudder pedals or cables to get full travel. Letting the rudder hit the stops in the wind is bad news. Whether the stops sheer or not, the rudder can be damaged if this is allowed to happen. I've seen a rudder that had to be completely replaced because it was banging up against the stops and the trailing edge was badly distorted because of a severe impact against the stop in high wind.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Nov 15, 2010, at 2:02 PM, TommyLewis(at)aol.com (TommyLewis(at)aol.com) wrote:
| Quote: | Over the weekend I found that the RV10 rudder stop on the right side has broken, the rivets had been sheared. The rudder stop was laying in the bottom of the rudder. When this has happened to others, have you simply riveted it back on, or replaced rivets with #8 or #6 bolts, or is there an after market replacement???
Tom Lewis
Granbury, Tx
RV10 N143EB
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
scottmschmidt(at)yahoo.co Guest
Posted: Mon Nov 15, 2010 3:11 pm Post subject: rudder stop |
I have had this happen to me as well. My first rudder lock was not very robust and high winds at Las Vegas caused it to slip out of the pedals which then caused my rudder to shear the stops and damage the rudder. I was able to repair and replace the stops with #6 screws. I never walk away from my plane without putting the rudder lock in even if I am just running to the bathroom. One blast from a taxiing plane will damage that rudder.
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Mon, November 15, 2010 12:55:38 PM
Subject: Re: rudder stop
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Tom Lewis
Granbury, Tx
RV10 N143EB
href="
speckter(at)comcast.net Guest
Posted: Mon Nov 15, 2010 4:49 pm Post subject: rudder stop |
One solution to the floppy rudder is to install rudder return springs. I do not have near the flopping as my non spring friends. It is cheap, easy and keeps the cables nice and snug.
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Monday, November 15, 2010 6:08 PM
Scott Schmidt
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Tom Lewis
Granbury, Tx
RV10 N143EB
012345678901234567890
Jim Berry
Posted: Mon Nov 15, 2010 7:47 pm Post subject: Re: rudder stop |
Does anyone have a bomb-proof rudder lock that they are really happy with?
Jim Berry
N15JB
Phase 1
dlm46007(at)cox.net Guest
Posted: Mon Nov 15, 2010 8:14 pm Post subject: rudder stop |
I have two 1x1x.062 angles each 30" with a foam strip
RTVed to a side. a center hole for an AN4 bolt is centered on each angle.
The threaded shaft that connects the two angles passes between the rudder
and the fuselage. It is held on with a lock nut on one end and a wingnut on
the other. weighs about a pound and is carried in the tiedown bag. the wind
would probably break the entire tail cone off before breaking the rudder
lock. Not dainty or elegant but sturdy and sure.
Posted: Mon Nov 15, 2010 8:48 pm Post subject: rudder stop |
I am very happy with the modified bogi-bar as a gust lock. I think I've posted a picture before. I'll try to take one tomorrow and post it. As I see it, it would be almost impossible for it to come loose if installed correctly. The plane that had the rudder destroyed had the spring-loaded gust lock installed, but it broke from the force of the wind.
Jesse Saint
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Nov 15, 2010, at 10:47 PM, Jim Berry wrote:
Albert Gardner
Posted: Mon Nov 15, 2010 9:17 pm Post subject: rudder stop |
This one is cheap and effective. Easy to install and store away.
Albert Gardner
N991RV
Yuma, AZ
23.71 KB |
13396 Time(s) |
24.41 KB |
13396 Time(s) |
22.8 KB |
13396 Time(s) |
RV-10 N991RV |
davidsoutpost(at)comcast. Guest
Posted: Tue Nov 16, 2010 8:38 am Post subject: rudder stop |
Here is a link to purchase the internal rudder stop. I am pleased with the quality and price and installed mine when I was building the rudder.
http://stocktoneaa.org/Rudder%20Stop.html
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Tue Nov 16, 2010 9:14 am Post subject: rudder stop |
OK, David, I give up ... is there a link to Merlin Enterprises so I can check this out, rather than the "buy it now"?
Thanks, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Tue Nov 16, 2010 10:04 am Post subject: rudder stop |
No,,,as far as I know he does not have a website. I believe this is the only part he manufactures and he posts on the Vans RV forum and is one of its moderators. He just posted today that he has another batch ready for orders and I figured someone on this list might be interested since the subject was recent. http://www.vansairforce.com/community/showthread.php?t=64982
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
Kelly McMullen
Posted: Tue Nov 16, 2010 12:25 pm Post subject: rudder stop |
Do you have a picture of how you installed yours? It certainly is
sized differently than the Van's stop.
On Tue, Nov 16, 2010 at 10:59 AM, <davidsoutpost(at)comcast.net> wrote:
[quote] No,,,as far as I know he does not have a website. I believe this is the
subject was recent.
David Clifford
RV-10 Builder
65% Done-95% To Go
N849RV (reserved)
A&P/IA, EAA Tech Counselor
KCHD |
dave.saylor.aircrafters(a Guest
Posted: Tue Nov 16, 2010 12:56 pm Post subject: rudder stop |
I been using this one for a while (scroll down to the tow bar pictures):
http://forums.matronics.com/viewtopic.php?p=300884#300884
It's nice to be able to put the gust lock in while standing outside on
the ground. Plus no other gizmos to haul around.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Mon, Nov 15, 2010 at 7:47 PM, Jim Berry <jimberry(at)qwest.net> wrote:
Posted: Tue Nov 16, 2010 1:23 pm Post subject: rudder stop |
That's very similar to my mod. I just use a tube that will fit in a hole on the pedals. I also usually put the stick through the hole in the towbar then use the seatbelt on the other side to hold it back, which locks the elevator & ailerons.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Nov 16, 2010, at 3:53 PM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com> wrote:
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
> Jim Berry
> N15JB
> Phase 1
> http://forums.matronics.com/viewtopic.php?p=319535#319535
Posted: Tue Nov 16, 2010 4:20 pm Post subject: rudder stop |
| Quote: | >use the seatbelt on the other side to hold it back<<
Yep, that's basically what I did before the bungee. Now I can lock
all the controls in one motion. Probably not a big deal but it does
seem easier now and that makes it a little more likely that I'll
actually use it.
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Tue, Nov 16, 2010 at 1:17 PM, Jesse Saint <jesse(at)saintaviation.com> wrote:
That's very similar to my mod. Â I just use a tube that will fit in a hole on the pedals. Â I also usually put the stick through the hole in the towbar then use the seatbelt on the other side to hold it back, which locks the elevator & ailerons.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
> the ground. Â Plus no other gizmos to haul around.
> Dave Saylor
> AirCrafters
> 140 Aviation Way
> 831-722-9141 Shop
> 831-750-0284 Cell
>> Jim Berry
>> N15JB
>> Phase 1
