Flap Switch Wiring
Ianrat
PostPosted: Sun Nov 14, 2010 2:01 pm    Post subject: Flap Switch Wiring Reply with quote
Does any one have a diagram of the new flap actuator switch wiring positions.
The plans only show the old type with the limit switches attached.
Thank you
Ian Ratcliffe
CH601XL. Very Happy
craig(at)craigandjean.com
PostPosted: Sun Nov 14, 2010 7:37 pm    Post subject: Flap Switch Wiring Reply with quote
Just wire it as a polarity reversing switch. Use a DPDT switch with a center
off position. The up and down positions should be non-latching (momentary).
Sometimes denoted as (on)-off-(on). Wiring here:
http://www.1728.com/dpdt.gif from http://www.1728.com/project2.htm
The right switch from B&C would be an S700-2-7.
I've attached an image from the AeroElectric book but you may only be able
to see it if you go to the Matronics web version of the list.
-- Craig
 Filesize:  55.2 KB
 Viewed:  5112 Time(s)
Ianrat
PostPosted: Mon Nov 15, 2010 4:31 am    Post subject: Re: Flap Switch Wiring Reply with quote
Thank Craig. It works very well. Very Happy
Ianrat
Ch601xl
Brisbane Australia
