RV-10 Sensor Platform
David Shelton
PostPosted: Thu Nov 11, 2010 10:01 am    Post subject: RV-10 Sensor Platform Reply with quote
Is anyone interested in using their RV-10 for aerial photography or remote sensing? We’re now customizing our cargo pods with camera holes, equipment racks and other features to accommodate a variety of payloads. The entire pod may be attached/removed in 30 seconds so you can quickly reconfigure the airframe for work or play.
Payloads: EO/IR, Laser Scanners, LADAR, Aux Fuel, Speakers, Radio Repeaters, Etc.
Applications: Aerial Photography, Security, Atmospheric Research, Pipe Survey, Forestry Services, etc.
Please visit the website (www.MotorcyclePilot.com) or call me to discuss your needs. David Shelton, 847-651-4373
RV-10 Sensor Pod
 Filesize:  86.76 KB
 Viewed:  4455 Time(s)
Tim Olson
PostPosted: Thu Nov 11, 2010 4:10 pm    Post subject: RV-10 Sensor Platform Reply with quote
Re: the "work" part. Surprisingly, it's illegal for us to
do any "work" in our experimentals. Even flying for the
purpose of selling aerial photos would be illegal, since
we're not allowed to operate commercially.
Tim Olson - RV-10 N104CD
On 11/11/2010 12:01 PM, David Shelton wrote:
Shelton"<SBaircraft(at)yahoo.com>
Repeaters, Etc.
http://forums.matronics.com/viewtopic.php?p=319013#319013
http://forums.matronics.com//files/img_3780_signalsb_946.jpg
David Shelton
PostPosted: Thu Nov 11, 2010 6:23 pm    Post subject: Re: RV-10 Sensor Platform Reply with quote
Section 91.319 makes it clear that we can't "carrying persons or property for compensation or hire." This would clearly prevent us from carrying a paying photographer but it doesn't necessarily stop us from taking pictures ourselves.
Amateur-built aircraft are regularly used for paying air show performances, skywriting, aerial photography, etc. A handful of law enforcement agencies use them for aerial surveillance. These applications don't carry any persons or property for hire and there is no clear ruling against them. Admittedly, the FARs are a little vague in this area and we leave their interpretation up to the customer.
In other instances, it is appropriate to convert the airworthiness certificate to another experimental category. For example, one of our customers will be using an RV-10 to evaluate a new type of sensor they are working on. They will be switching to the "Research and Development" category.
Jim Combs
PostPosted: Fri Nov 12, 2010 10:53 am    Post subject: RV-10 Sensor Platform Reply with quote
Actually air to ground photography is called out in the regs as NOT flying for hire.
Jim C
On Thu, Nov 11, 2010 at 7:07 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
-->  RV10-List message posted by: "David
Shelton"<SBaircraft(at)yahoo.com (SBaircraft(at)yahoo.com)>
Repeaters, Etc.
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
RV-10 -> N312F - Flying as of 12/2008
