ronlee(at)pcisys.net Guest
Posted: Tue May 02, 2006 4:45 pm Post subject: What is the best way to determine speed improvements? |
I have used 3-way GPS runs in the past.
I have started using 4 way GPS runs.
I tried using the Excel program on Kevin Horton's site and did not
do very well. Both runs (yesterday and today) had a Standard Deviation
of around 3.
Point 2 below is the data in knots and today's is Point 3 (in MPH). The
final TAS
was identical in both cases which seems oddly coincidental.
I use a GPS to average the speed for each directional run which I had hoped
would smooth out piloting errors. Apparently it did not.
I am curious how well others do on this and whether I should just go up
and record the IAS under set conditions then redo it after making a change
that may improve airspeed (such as Pressure recovery wheelpants).
Ron Lee
Point 2 Vwind Wind dir Vtrue
Vg Track (kts) (deg) (kts)
148 352 14.7 336 161.8
160 252 12.1 308 166.8
176 166 19.2 307 161.7
175 84 20.8 326 166.6
ave 16.7 319.4 164.2
std dev 2.9
All these values are MPH
Point 3 Vwind Wind dir Vtrue
190 352 21.7 265 192.5
171 256 17.5 286 186.4
194 168 10.3 271 191.9
202 80 15.8 247 186.6
ave 16.3 267.5 189.3
std dev 3.3
khorton01(at)rogers.com Guest
Posted: Tue May 02, 2006 5:43 pm Post subject: What is the best way to determine speed improvements? |
On 2-May-06, at 7:37 PM, Ron Lee wrote:
Deviation
of around 3.
MPH). The
final TAS
had hoped
go up
change
Ron Lee
std dev 2.9
std dev 3.3
Ron,
There are several possible explanations for the poor quality data:
1. The weather conditions may not have been good enough. You need
really smooth air, and the wind direction and speed at the test
altitude must be steady.
2. You made a mistake when copying down one or more of the numbers.
This is easy to do.
3. You didn't fly as accurately as necessary. If you want good
quality data, the flying must be very accurate. The altitude and IAS
for each run must be exactly the same. You need to fly a constant
heading long enough for the GPS to filter out any variations and
provide a steady track and GS.
The key to success - I find it extremely difficult to get good data
unless I have someone with me to record the data. That lets me
concentrate on flying the aircraft. If I have someone to record the
data, I can normally get a std deviation of less than one knot, but
I've been doing this sort of stuff for many years.
Don't get discouraged. Practice makes perfect. Accurate performance
testing takes a lot of work.
As far as simply recording IAS. That can work, if you have developed
a test procedure that gives a repeatable result. If you get the same
IAS on several different flights, then you have an idea of what the
performance is. Don't simply take IAS readings on one flight, and
believe that they are guaranteed to be accurate.
Good luck,
gcomfo(at)tc3net.com Guest
Posted: Wed May 03, 2006 4:49 am Post subject: What is the best way to determine speed improvements? |
rv8(at)lazy8.net Guest
Posted: Wed May 03, 2006 5:03 am Post subject: What is the best way to determine speed improvements? |
Ron and Kevin
I am assuming the program on Kevin's website is similar to the one I use
from the Nat'l Test Pilot School. Sounds the same.
I agree with Kevin, getting good data is not easy. I have run at least
100 4-legged GPS runs in the last 3 years testing 4 different props and
numerous speed mods on my RV8. If the standard deviation is more than 1,
I throw away the run. This is an indication that either I did not fly it
right, did not wait long enough for the speed to settle down after the
last turn, or the air 1) has vertical movement, or 2) the winds aloft
are varying in direction or speed.
Ron, as you know already, here in the mountains it is hard to find
smooth steady winds. Especially on the front range where you are, the
chance of having zero mountain wave in the spring is small. So, you
really have to watch the winds aloft forecasts and choose your test
days. Today, for example, I was going to test my latest cowl mod, but
the winds are too strong, and showing variance in direction in my area
(4-corners).
Also, I always use my autopilot with altitude hold to fly the patterns.
This gives me time to take data and watch for traffic. I used to test
without an autopilot, and it is very hard, and probably dangerous
because you run out of time to watch for traffic.
It is also important to fly your tests at the same density altitude,
rpm, fuel flow, weight, bug density on the wings, etc. to have data to
compare. Even then, there will be some variations, so I always fly 3
different days, and 3 or 4 patterns each day, and take an average to
assess each mod.
Have fun...it is a lot of fun.
John
Kevin Horton wrote:
>Deviation
>of around 3.
>MPH). The
>final TAS
>had hoped
>go up
>change
>Ron Lee
>std dev 2.9
>std dev 3.3
Ron,
This is easy to do.
Good luck,
