teamgrumman(at)yahoo.com Guest
Posted: Fri Nov 05, 2010 8:38 pm Post subject: Engine Thrust Line: Page three. Is the engine level. |
After spending something like 2 hours trying to figure out how to level the plane, now it was time to check the level of the engine.
I first set the magnetic angle finder on the #4 cylinder rocker cover.
Then #2 rocker
Then #3 rocker
Then #1 rocker.
For all practical purposes, the engine appeared to be aligned with the airframe. Mind you, I have 2 spacers on each of the top two engine mounts. Looking closely, the engine does appear to be negative thrust angle by less than 1/2 degree. The resolution is not great. I would have to say the needle was just a shade toward 1/2 degree down on all 4 rocker covers.
You draw your own conclusions.
| | - The Matronics TeamGrumman-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
| Description: |
| Filesize: |
40.25 KB |
| Viewed: |
1104 Time(s) |
| Description: |
| Filesize: |
45.68 KB |
| Viewed: |
1104 Time(s) |
| Description: |
| Filesize: |
41.9 KB |
| Viewed: |
1104 Time(s) |
| Description: |
| Filesize: |
52.85 KB |
| Viewed: |
1104 Time(s) |
| Description: |
| Filesize: |
51.62 KB |
| Viewed: |
1104 Time(s) |
