Sling Shot engine shims
rickofudall
PostPosted: Tue Oct 26, 2010 11:06 am    Post subject: Sling Shot engine shims Reply with quote
Thom, Ted, all, I went out to the hangar and measured up the Mk III and Firestar engine mounts to get some input for Autocad. I measure both at 9.5" between bolt centers fore to aft. Since I have to have a little material to hang on to while fly cutting the face of the shims I set thickness of the forward edge of the front shim at .125". Using Ted's suggestion that .875" (7/8") is the best height to correct the thrust line, I put the aft edge of the aft shim at 1.00". Connect the two lines and measure the angle and out pops 4 degrees on the button. Thom, based on your measure that your thrust line is currently 3.5 degrees up, shims based on these numbers would put your thrust line down (converging with the bottom of the wing by .5 degrees.
Rick
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
 - G.K. Chesterton
Thom Riddle
PostPosted: Wed Oct 27, 2010 5:14 am    Post subject: Re: Sling Shot engine shims Reply with quote
Rick,
I didn't read your post until I read Ted's most recent post so now I know the ANGLE of Ted's Slingshot thrust line. It surprises me that it is not closer to the angle of the horizontal stabilizer.
Thanks for doing my job for me. Did you happen to take the measurements of the size of the mount pads? If not, you needn't bother as I will be going to the hangar Thursday and measure those as well. It is possible, but not likely, that the pads are a different size on the Slingshot than on your MkIII. Once I confirm the pad size I'll let you know.
Thanks again for everyone's help on this.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
rickofudall
PostPosted: Wed Oct 27, 2010 10:01 am    Post subject: Sling Shot engine shims Reply with quote
Thom, The pads are a bit over 2.5" fore to aft. The distance between mounting holes is 1.75" (taken from a spare mount). I can get 2 1/2" wide bar stock at a local supplier in both 1" and 1/4" thick. The smaller size for the front wil I figure I'll put a 1.375 hole in the middle of the shims just to take a little weight out of them. I picked the size only because I have a cut down drill of that size that has the shank ground to 3/4" so I can run it right out of a collet and it is short enough that I don't have to get all aerobic cranking the table up and down. I went back and dimensioned the drawing so you can compare to your mount just to be sure. Turns out I had the accuracy turned down a bit to much on angular measurements when I said it is spot on at 4 degrees, but I doubt that little extra will make a big difference.
Rick
On Wed, Oct 27, 2010 at 8:14 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
--> Kolb-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Rick,
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
“Everyone is entitled to his own opinion, but not his own facts.”
Daniel Patrick Moynihan
http://forums.matronics.com/viewtopic.php?p=317194#317194
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
 - G.K. Chesterton
 Filesize:  55.79 KB
 Viewed:  4202 Time(s)
Thom Riddle
PostPosted: Wed Oct 27, 2010 10:19 am    Post subject: Re: Sling Shot engine shims Reply with quote
Thanks again, Rick.
Assuming my motor mount is identical to the one you measured, that should work fine the way you described it. Let me make sure tomorrow that my motor mount is the same and I'll give you the go ahead.
I really appreciate your help with this.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Fred Kerfoot
PostPosted: Fri Nov 05, 2010 4:44 am    Post subject: Sling Shot engine shims Reply with quote
Rick, don't forget to make 4 thin beveled shims for the under side of the engine mounts. (6 thin & 2 thick total).
Otherwise you will be bending the bolts.
                 FredK
Fred K
