gonzo24
Posted: Thu Oct 28, 2010 3:12 pm Post subject: SD8 alt connection |
sorry if this has been covered but I cannot find it.
I am needing info on connection of the SD-8 aux alternator. I have a B&C 60 amp primary and one odyssey 680 batt. Z13 shows the SD-8 connection from the relay to the batt contactor I believe.
can I just hook this power out relay lead direct to the batt buss for back up power only? Do i use a fusible link or in line fuse holder or breaker for this connection?
I'm running dual lightspeed plasma II plus' as well.
Is their a diagram showing how to properly set up this mix of components?
thanks guys...
_________________ RV-7a completed flown 700+ hrs sold
Rv-7 under construction |
Posted: Thu Oct 28, 2010 7:40 pm Post subject: SD8 alt connection |
Yes, it's Z-13/8. When the SD-8 is powered up,
the battery contactor can optionally be turned
off and the SD-8 used to power only items driven
from the battery bus.
gonzo24
Posted: Fri Nov 19, 2010 6:03 am Post subject: Re: SD8 alt connection |
Bob,
thank you for the reply. In reviewing the Z-13/8 schematic... since the 2awg batt and 14awg batt buss are all connecting at the same point on the batt contactor on the engine side of the firewall.... Wouldn't it be the same thing to terminate the SD-8 output lead directly to the battery buss stud inside the cabin?
I ask this as all of my SD-8 power components i.e. regulator, capacitor, OV, relay are installed cabin side of the firewall (per the instructions received with these parts). Why would it be necessary to run the lead with the inline 30amp fuse back out to the batt contactor? In the event of a Primary alt failure, the SD-8 should still be excited through the 14AWG contact it has to the primary battery.
Should one connect a smaller aux batt on the Batt buss as well in this case? I ask this as LSE's power diagram shows two batteris for dual ignition as well.
thank you for your time.
Posted: Fri Nov 19, 2010 1:05 pm Post subject: SD8 alt connection |
At 08:03 AM 11/19/2010, you wrote:
Bob,
Whoops! You have an always hot fat wire coming through
the firewall?
| Quote: | I ask this as all of my SD-8 power components i.e. regulator,
primary battery.
Okay, you've arranged components with priorities ordered
differently than suggested in the Z-figures and I understand
why. I wish B&C wouldn't put those little notes in with
his products suggesting that certain electro-whizzies are better
off inside the cabin.
Sure, connect the SD-8 to the battery bus . . . in fact,
put a 30A fuse in one of the battery bus fuse-slots and
use it to route power to the system.
Airplane parts are airplane parts. They are selected and
qualified for specific duty in locations selected first
for functionality, minimum parts count, weight, and nice
failure mode effects analysis. Obviously, boxes with LCD
displays, push buttons and knobs NEED to go in the cabin
and their tolerance for environmental extremes are relaxed
because shares spaces where people sit. All other gizmos,
particularly system power management parts should be happy
living anywhere except perhaps bolted to an exhaust stack.
The current locations for your SD-8 system parts
and battery bus are now pretty much a given so you're
compelled to make adjustments for how the wires are
handled.
| Quote: | Should one connect a smaller aux batt on the Batt buss as well in
No . . . don't mix-match architectures. I've
encountered several instances where the system
integrator attempted to cherry-pick what appeared
to be "good and wonderful" features of multiple
systems with the notion that each plucking of
an idea makes the whole more righteous.
The whole idea behind LSE's recommendations go
to increasing probability that at least one
of two ignition systems will have power irrespective
of MULTIPLE failures . . . and without regard to
the thought processes that ago toward fabrication
of a FAILURE TOLERANT system.
The battery in the OBAM aircraft owned, operated
and maintained by a cognizant builder is the most
reliable source of energy in the airplane. It's
only limitation is total stored energy traded off
with how much lead, water and plastic the builder
is willing to drag around. Then comes TWO, engine
driven power sources capable of mitigating battery
limitations. By the way, if you DO find yourself
operating either battery only . . . or battery+SD8,
then turn one of the ignition systems off. The
engine will hardly know the difference and your
electrical system loads drop by about 2 amps.
B&C and LSE make recommendations based on their
best wishes and understanding of the systems they
sell. The AeroElecric Connection goes toward a
rational approach for crafting the whole system
based on ingredients that go into recipes for
success going WWWwaaayyyy back . . . further
than any current supplier of electro-whizzies.
Understand that supplier recommendations are
almost never 'wrong'. But most suppliers are
not system integrators with a focus on the big
picture. Note how many different Z-figures there
are as opposed to how many ways the legacy T/C
aircraft is wired . . .
I'll have a first-hand review of a dark-n-stormy
night story to share with the List where the
outcome wasn't a complete disaster . . . everybody
walked away. The system integrator cherry-picked
whippy ideas without regard their 'fit' in the
overall system. The effects of some poor decisions
were expensive and linger to this day. I'll tell
you all about it after the court case settles.
Please don't take anything above as a
harbinger of doom for what you've described.
Your system's WIRING and FUNCTIONALITY are
going to be just fine and will function as
advertised. We're only sifting through the
simple-ideas that go to very low orders of
risk.
| Quote: | thank you for your time.
You're most welcome. That's what we're all here
for . . .
Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
Posted: Sat Nov 20, 2010 7:41 am Post subject: Re: SD8 alt connection |
Most electrical devices that can not be shut off should be on the engine side of the firewall. And if practical, devices that can be shut off should also be on the engine side of the firewall. Look at each component of the electrical system and ask yourself, "If this device starts smoking, would I rather have it inside of the cockpit or outside, and how will I shut it off?" When something starts smoking inside of the cockpit, it will be difficult to know what device it is. Shutting off the master switch should remove power from almost everything inside of the cockpit.
It would be better to place the following components on the engine side of the firewall: Battery, Battery Contactor, Main Battery Bus, Essential Bus Relay, Voltage Regulator, Capacitor, Alternator Relay
Joe
_________________ Joe Gores |
slipstream(at)wavecable.c Guest
Posted: Sun Nov 21, 2010 10:12 am Post subject: SD8 alt connection |
Sure wish I'd read this a year or more ago. As Gonzo wrote above, I followed the installation diagrams on the SD-8 and LR-3C to place a number of devices on the pilot side of the firewall. This includes the SD-8's voltage regulator, relay, capacitor, and crowbar OV module. On the main side of the system, the LR-3 is also mounted on the pilot side of the firewall. The hot battery bus, E-bus relay, current limiters, shunts, inline fuses and fuselinks are in the engine bay. Moving everything to the engine side would be a major hassle of working around the engine mount and plumbing (I'd probably just remove the whole engine and mount assembly), but less of a hassle now than after it's flying, I suppose.
So, considering the devices above, what's my risk? Is it worth pulling the motor off to consolidate all my electrical devices, or can I sleep at night knowing that the items I do have inside the cabin are negligible risk? For reference, my electrical system follows Z-13/8 precisely, except for the B&C LR-3 voltage regulator and no electronic ignition.
Brooks Wolfe
RV-7 -- Finishing details details
[i]----
Posted: Sun Nov 21, 2010 2:14 pm Post subject: Re: SD8 alt connection |
Brooks,
I would sure hate to pull an engine to modify the electrical system. Would it be much of a hassle to move the voltage regulator to the engine side and leave the other items in that circuit where they are? The voltage regulator should have adequate cooling. B&C must not think that their parts will fail. My RV-12, that is built according to Van's instructions, has the voltage regulator forward of the firewall, but the capacitor is in the cockpit.
An option is to add a relay in the engine compartment to shut off the AC output of the dynamo. Perhaps Bob will comment on the feasibility of doing that. The dynamo will be putting out a high voltage without a load.
There is an ideal way of doing things and there is a good-enough way. I do not know where to draw the line. Many times I am tempted to take shortcuts. Then I ask myself what is the best in the long run.
At least you have the main battery bus forward of the firewall. That is the most dangerous component.
Joe
gonzo24
Posted: Sun Nov 21, 2010 5:58 pm Post subject: Re: SD8 alt connection |
Hello Bob,
As usual your answers are thought provoking, specific, and yet posed in such a way to allow for builder interpretation to maintain a fault tolerant architecture.
Just to clarify, I have not routed any "fat" 2awg wires into the cockpit per your written instructions for reduction of electrical noise issues. The only two power leads coming through the firewall are... The Batt buss which is fed from the + of the battery via a 14 awg wire. The main buss is fed off of the 60 A limiter fuse from the post opposite the B&C Alternator feed through a short 8 awg lead.
Thanks again for your thorough and timely response.
Posted: Tue Nov 23, 2010 6:16 am Post subject: SD8 alt connection |
At 12:08 PM 11/21/2010, you wrote:
No, don't rip up anything and re-configure. The risks
are low as most have to do with crash worthiness
for taking always-hot feeders long distances or through
firewalls. Just pay attention to support and insulation
of your always hot conductors.
Posted: Tue Nov 23, 2010 6:19 am Post subject: SD8 alt connection |
Hello Bob,
Sounds good to me but not sure why you
added a limiter to the bus feeder. As long
as your firewall pass thru is well crafted,
that device will never be called upon to
act for its intended purpose.
