tc1917(at)bellsouth.net Guest
Posted: Mon Oct 25, 2010 2:12 am Post subject: slingshot thrust line |
I am going to jump in here because I believe the SS has the engine thrust
line too far back. I hope you get this pic of my SS with the 912. The 582
had about the same thrust line as my 912 only adjusted for the power. If
you dont raise the back of the engine on the mount you will be virtually
pushing the nose over. The entire airframe will be fighting. You MUST
raise the rear mounts from 3/4 to maybe 7/8 of an inch (one guy went more
than that) in order to correct the angle of attack. I bet you have a really
heavy stick or a lot of bungee stretch to compensate. At 7/8 at the rear of
the mounts, you will be able to fly virtually hands off at your regular
cruise rate and not have to fight it on take off. I bet you got a handful
when you firewall the engine at take off. Not just my opinion, fact on this
one and if you dont believe, well, fight it in the air. Raise the rear of
the engine a little at a time and you will see the difference in the first
quarter inch. You will notice the angle of the blade in relation to the
boom. This really works. Trust me. Ted Cowan, Slingshot, 912UL, zoom zoom
88.64 KB |
16496 Time(s) |
aoldman(at)xtra.co.nz Guest
Posted: Mon Oct 25, 2010 9:46 pm Post subject: slingshot thrust line |
Yep that worked for me on the MK111c. Packed the back up with 2 washers.
There is a slight pitch up when you throttle back from cruse rpm by about
200 rpm . The pitch up is so slight that it is no more than a "be aware this
will happen" it is normal, when some one is flying the Kolb for the first
time . I was trying to get the prop away from the boom at the bottom to
reduce noise. Not sure that worked , but I like the way it fly's now . I
have never measured the angles . Just changed things a little and went
flying .
Down under
MK111c
Thom Riddle
Posted: Tue Oct 26, 2010 3:01 am Post subject: Re: slingshot thrust line |
Ted,
You are correct regarding full power take-off. It becomes a handful quickly so I don't add full power until I'm airborne, and then only gradually.
I guess I'll try a little at a time as others have suggested but will probably end up with about what you have. My concern is that the Jabiru mount is a steel pad virtually identical in size to the steel pad on the Kolb and is 2 or 3 inches square or perhaps larger. So it is not like the Rotax that have vertical bolts through the slightly flexible Lord mounts. It is steel to steel which means I will need tapered shims. The Lord mounts have horizontal bolts between the steel tubing Jabiru mount and the Jabiru engine which you can see clearly in one or two of Chris's photos, and in the attached photo from my SS.
This is why it is not just a matter of simply inserting washers. If it was that simple it would have been done long ago.
392.71 KB |
16474 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
pj.ladd(at)btinternet.com Guest
Posted: Tue Oct 26, 2010 6:46 am Post subject: slingshot thrust line |
<<You are correct regarding full power take-off. It becomes a handful
gradually.>>
When you are airborne is NOT when you need to apply full power.
Back to basics. Were we not all taught to apply full power GRADUALLY and
increase speed GRADUALLY?. If that is done then all the normal corrections
of rudder and stick should take care of problems. Too much power too soon,
before you have full control and the torque will get you.
The phase when we are all vulnerable is when we are low so grab height as
quickly as you can. That means full power BEFORE you leave the ground.
Don`t we run full power checks to make sure that full power is available for
take off?
I am a comparative newbie on the Kolb compared to some of you but I flew my
Challenger, with the same problem of a high mounted pusher for some while
and the same applies
Of course the Challenger with a tricycle gear didn`t have quite the same
problems as a tail dragger
How about cutting the Kolb boom down to get rid of the rear weight and
convert to trike u/c. It was done with the Thruster, probably the most
numerous type in the UK. When I had one in the early days it was a tail
dragger but there are very few left now. New ones are built with a trike u/c
and nearly all the old ones have converted. I am surprised that one of you,
with the freedom which you have to Experiment hasn`t had a go at that.
Now THAT aught to start a new thread
Cheers
Pat
rickofudall
Posted: Tue Oct 26, 2010 6:48 am Post subject: slingshot thrust line |
Thom, I don't have a Slingshot, but I do have a small machine shop. You draw up the shims you need and I'll make them for the cost of material and mailing. If you're using AN3 bolts to attach the Jabby engine mount buying 16 new bolts shouldn't set you back more than $20 and neither will any shims. $40 seems awfully cheap to fix a problem and put your mind at ease.
Rick Girard
On Tue, Oct 26, 2010 at 6:01 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Ted,
Thom Riddle
Buffalo, NY (9G0)
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
“Everyone is entitled to his own opinion, but not his own facts.”
Daniel Patrick Moynihan
http://forums.matronics.com/viewtopic.php?p=317062#317062
http://forums.matronics.com//files/jabiru_engine_rt_rear_cropped_196.jpg
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
Thom Riddle
Posted: Tue Oct 26, 2010 7:01 am Post subject: Re: slingshot thrust line |
Rick,
Thanks a bunch for your offer. I will gladly take you up on it. I'll get the drawings to you as soon as I can. Have to take some dimensions first, probably not until the weekend.
Thanks again.
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Tue Oct 26, 2010 8:35 am Post subject: slingshot thrust line |
At 10:44 AM 10/26/2010, Pat Ladd wrote:
| Quote: | | How about cutting the Kolb boom down to get rid of the rear weight and convert to trike u/c. It was done with the Thruster, probably the most numerous type in the UK. When I had one in the early days it was a tail dragger but there are very few left now. New ones are built with a trike u/c and nearly all the old ones have converted. I am surprised that one of you, with the freedom which you have to Experiment hasn`t had a go at that. |
Most of us prefer taildraggers... why take a perfectly good airplane and put a training wheel on it?
-Dana
Politicians and diapers have one thing in common. They should both be changed regularly, and for the same reason. [quote][b]
Posted: Tue Oct 26, 2010 9:01 am Post subject: slingshot thrust line |
Gang:
I feel like Dana. I like Kolbs the way Homer designed them.
I have experience flying and demonstrating the first Sling Shot powered with a 582. I did not detect any adverse flight characteristics with it. Flew a TV videographer at Lakeland. Had fun wringing out the SS, low level through the cabbage palms and pastures south of Lakeland. There is a Kolb video clip with part of that flight on it on Youtube.
I also have experience flying TNK's Rotax 912ULS SS. No perceived problems with it.
I can not remember if there was any kind of modifications to the engine mounts. I think if there were, it would have been pretty obvious to me.
I experimented with different thrust lines with my FS and my mkIII. Always going back to the factory recommended settings.
When I take off in any model Kolb, I go full throttle immediately, but like any other aircraft, I don't jam the throttle forward.
Kolbs are good aircraft. The only aircraft I fly. We have some pilots that seem to have problems flying them. Maybe they need more training and flight time.
I am not saying that individuals that change the engine thrust line is wrong. Everyone is free to do as they wish with experimental aircraft. I am saying I could not find justification in my Kolbs to keep changes I made. Maybe I was doing it wrong. ;-(
My own personal opinion.
mkIII - 3,000.00+ hours airframe
912ULS - 440.00+ hours engine
[quote] Most of us prefer taildraggers... why take a perfectly good airplane and put a training wheel on it?
-Dana
_________________ John Hauck
Titus, Alabama |
jbhart(at)onlyinternet.ne Guest
Posted: Tue Oct 26, 2010 5:33 pm Post subject: slingshot thrust line |
At 07:15 AM 10/25/10 -0700, you wrote:
Thom,
The other problem with this that Chris alluded to is that the point and
angle at which the thrust is acting is so far aft of the CG that it results
in a significant nose down pitching moment when adding power, more so I
believe than if the thrust was parallel to relative wind.
The nose down rotation due to the addition of power is caused by the thrust
line (moment arm) passing above aircraft vertical cg. The higher the thrust
line the greater the moment arm and the more the nose wants to go down. To
compensate, one must apply stick back pressure to maintain constant level
flight. This in turn applies additional load to the tail which must also be
picked up by the wing. This effect is not influenced by the point of thrust
application, pusher or tractor if the thrust line is parallel to the
relative wind.
If the thrust line is angles up to and above the relative wind. then point
of application can have some effect. As above one would expect greater nose
down effect as the thrust line is rotated upward for the pusher
configuration as this again increases the moment arm relative to the
vertical cg. Also if the thrust vector is not parallel to the relative
wind, power factor will be present. One can detect this by making steep
banks to the right and to the left. If power factor is present, the plane
will bank much easier or feel more solid in one direction than the other.
I added an attachment to help describe what is going on. It can be seen at:
http://jackbhart.com/firefly/pf&thr.jpg
Jack B. Hart FF004
Winchester, IN
Posted: Tue Oct 26, 2010 10:21 pm Post subject: slingshot thrust line |
Yep ,got me why would you put a wheel on the front of a Thruster. Learned to
fly in one of those . Did my first 100 hrs in one . Not many proplems with
that wheel way out the back. It was a early one that was built for a 447 but
was running a 503 so round outs tended to be a bit sudden. You could wheel
it on sooo smooth you could hardly feel it was on the ground. My instructor
hated that . Three point it he would say ,I did get good at that after a
while.
Downunder
MK111c
Posted: Wed Oct 27, 2010 1:16 am Post subject: slingshot thrust line |
Not many proplems with that wheel way out the back.>>
Hi,
I had none.. Aftre coming from gliding the Thruster was the machine I
trained on and didn`t know that threepointing was supposed to be difficult.
The Challenger was easier though although I always landed with the weight
firmly on the mains and the nose held high
Cheers
Pat
Posted: Wed Oct 27, 2010 6:05 am Post subject: slingshot thrust line |
Dana,
love it...training wheel heh heh
I bought a Kolb because I fell in love with the design about 3 airplanes back. Then the opportunity came about. I had been in a Eurostar partnership which dissolved and I found myself with about 20K not earmarked for other things.
This coincided with a distributor picking up the import rights from another company who had decided not to sell |Kolbs any more.
So the Kolb became available in the UK at the time I had some cash.
Having trained on the taildragger Thruster the thought of going back to a rear wheel after the trike u/c Challenger was not a problem. In fact, once I got back into the habit, and with differential footbrakes it was nearly as easy to handle as the trike u/c.
Although I am well pleased with my Mk111Xtra I cannot forget the ease of ground handling which goes with a `training wheel`. No problems with weathercocking or nosing over if I braked too hard and very little trouble keeping straight even if the throttle was pushed flat out from a standing start. No different handling on grass or tarmac even in a brisk sidewind.
Must be a good reason why the military went for a wheel up front after about the DC3 and the B-17.
Training wheel.......
Cheers
Pat
Richard Pike
Posted: Wed Oct 27, 2010 6:41 pm Post subject: Re: slingshot thrust line |
Ok, for those of you that think a MKIII would be better with a nose (training) wheel, here's your chance to put your money where your mouth is. I have for your inspection a Gen U Wine nose wheel for a MKIII, $15 for the trouble to box it up plus what ever shipping turns out to be.
All 4130 steel construction, made from Gen U Wine cub jury struts plus what ever else I had handy. Built in pitot and static air tubes, already calibrated. Remove 6 of the the screws that attach the nose cone and screw it in place. Non-swiveling, so you no longer have to worry about running off the runway.
The only thing it is good for is it allows you to do full throttle run ups with two aboard without having to worry about standing the airplane on it's nose.
Why did I make it? I don't remember, but as Butch Cassidy said to Sundance Kid in the movie, "It seemed like a good idea at the time."
Richard Pike
MKIII N420P (420ldPoops)
74.02 KB |
16424 Time(s) |
71.62 KB |
16424 Time(s) |
74.19 KB |
16424 Time(s) |
79.35 KB |
16424 Time(s) |
Posted: Thu Oct 28, 2010 2:56 am Post subject: slingshot thrust line |
I have for your inspection a Gen U Wine nose wheel for a MKIII, $15 >>
Gee, thank you Richard. Such kindness. You are all heart
However to make this a working proposition I am afraid that there may be
other expenses incurred.
1) making the wheel swivel
2) under the general heading of moving the weight off the rear wheel
a)slide the boom forward
b) transfer the engine from the top of the cockpit to the bit of the boom
which is now sticking out the front
c)reverse the engine to make a tractor configuration, (this will make the
whole thing quieter)
3) It is probable that with the low position of the protruding boom (and
engine)the cockpit will blank the airflow to the tail unit so perhaps that
should be transferred to another boom protruding from the rear of the
cockpit top.
4) With the propellor now being mounted low the u/c legs will have to be
lengthened to give the prop ground clearance
5) The cockpit door will now be so high that a small ladder should be
carried.
6) These changes will certainly move the MAUW outside the limits of the UK
`microlight` spec. and this will incur extra insurance, a different flying
license which will mean more training and new exams to be passed.
Different rules for maintenance will apply and I shall have to employ a
mechanic.
You can see Richard that the costs do not stop at $15 so in view of my
impecunious state I am sorry that I shall have to refuse your kind offer.
However it is heartwarming to see how members of this wonderful List are so
keen to help out others.
Cheers
Pat
Richard Pike
Posted: Thu Oct 28, 2010 4:57 am Post subject: Re: slingshot thrust line |
| pj.ladd(at)btinternet.com wrote: | <snip>
However it is heartwarming to see how members of this wonderful List are so keen to help out others.
Cheers
Pat |
Wow - and I thought my wife knew how to haggle... So - I need to send it to you for nothing plus pay you $15? (You don't work for our current political administration do you?)
Richard Pike
rickofudall
Posted: Thu Oct 28, 2010 5:43 am Post subject: slingshot thrust line |
Pat, You've misunderstood the application. Here are two pictures of the original application for this type of augmented landing gear on a somewhat larger scale. It's a nose over wheel just like that used on the Barling Bomber. No need to add all that extra stuff, just bolt it on and be on your way. If you apply too much power too early, your plane comes over on it's nose and continues on its merry way. I'm surprised the regulators in the EU haven't made it a requirement already.
Rick
On Thu, Oct 28, 2010 at 5:53 AM, Pat Ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
| Quote: | --> Kolb-List message posted by: "Pat Ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
However to make this a working proposition I am afraid that there may be other expenses incurred.
b) transfer the engine from the top of the cockpit to the bit of the boom which is now sticking out the front
c)reverse the engine to make a tractor configuration, (this will make the whole thing quieter)
3) It is probable that with the low position of the protruding boom (and engine)the cockpit will blank the airflow to the tail unit so perhaps that should be transferred to another boom protruding from the rear of the cockpit top.
4) With the propellor now being mounted low the u/c legs will have to be lengthened to give the prop ground clearance
5) The cockpit door will now be so high that a small ladder should be carried.
6) These changes will certainly move the MAUW outside the limits of the UK `microlight` spec. and this will incur extra insurance, a different flying license which will mean more training and new exams to be passed. Different rules for maintenance will apply and I shall have to employ a mechanic.
You can see Richard that the costs do not stop at $15 so in view of my impecunious state I am sorry that I shall have to refuse your kind offer.
Cheers
Pat
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
23.58 KB |
16407 Time(s) |
32.54 KB |
16407 Time(s) |
Posted: Thu Oct 28, 2010 11:46 pm Post subject: slingshot thrust line |
I'm surprised the regulators in the EU haven't made it a requirement already. >>
Hi Richard,
I am sure they are thinking about it. After seeing the picture of the `training wheel` in use I can quite see that my worries about the `knock on` effects of fitting the wheel were groundless. I think that the ladder may still come in useful.
Pat
I am Obama`s best (only) friend.
Pat
