Posted: Fri Oct 22, 2010 1:20 pm Post subject: Overhead light panel, lit! |
I purchased these 12Volt, 150 lumin LEDs because they are low profile, high output, low heat, low current and very long lasting. I purchased these on the web at: Sailorsams.com. They work great for this application.
10'X25' Mobile Mini storage container deliverred next Friday. Plane is coming out of the basement and the container will be a mini hanger for a month or two. All that is left is to do is final sensor hookups on the engine, exhaust, and attach the fuel and oil lines. Then off to paint!!!
JOhn Gonzalez #40409, 2300 hours with QB wings and fuse. Of course it still needs to have its' wings back on and they won't fit in the storage container.
141.91 KB |
1497 Time(s) |
142.03 KB |
1497 Time(s) |
144.21 KB |
1497 Time(s) |
111.64 KB |
1497 Time(s) |
150.65 KB |
1497 Time(s) |
138.25 KB |
1497 Time(s) |
134.4 KB |
1497 Time(s) |
