sean(at)stephensville.com Guest
Posted: Tue Oct 19, 2010 12:47 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Working on wrapping up the dreaded Section 29 and have come across two
areas where I am unable to get the skin rivets bucked. The attached
pictures show the two areas. One is in the bottom right corner where
the F-1041 meets F-1042 and the other is behind the F-1001J where the
forward longeron attaches.
What have others done in these two spots? Anyone have a special bucking
bar recommendation or maybe the use of pop rivets in these areas?
-Sean #40303
82.77 KB |
10401 Time(s) |
77.94 KB |
10401 Time(s) |
rleffler
Posted: Tue Oct 19, 2010 1:25 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
My tungsten bar fit in those places without an issue. I know that wasn't
the answer you were looking for.
Bob
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
jeff(at)westcottpress.com Guest
I used 1/2" and/or 3/4" steel bar material in areas like this....
resulting in very sore fingers for a few days afterwards.
Jeff Carpenter
40304
On Oct 19, 2010, at 1:44 PM, Sean Stephens wrote:
| Quote: | Working on wrapping up the dreaded Section 29 and have come across
two areas where I am unable to get the skin rivets bucked. The
attached pictures show the two areas. One is in the bottom right
corner where the F-1041 meets F-1042 and the other is behind the
F-1001J where the forward longeron attaches.
bucking bar recommendation or maybe the use of pop rivets in these
areas?
-Sean #40303
<IMG_0536.jpg><IMG_0537.jpg>
Posted: Tue Oct 19, 2010 1:40 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Is that the modified emp bar you are referring to? Unfortunately an
RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and
never returned it. Cannot remember his name or if he is even still around.
-Sean #40303
Bob
rleffler
Posted: Tue Oct 19, 2010 2:25 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Nope, my tungsten bar is relatively thin, but unmodified. I also have some
thinner steel bars, but don't recall using them there.
N410BL - Phase I
rv10builder(at)verizon.ne Guest
Posted: Tue Oct 19, 2010 2:34 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Bob;
You just had to rub that in!!, but actually it's the perfect answer. The bar
is small and tough, but it's expensive too. It does work very well for a
person just starting who could benefit from it throughout the build.
Sean;
I used thin plates (1/2 in or so) initially and grinded down one of my
bucking bars to fit after not being able to take the abuse of the riveting
on the plates.
You'll have many more small areas that will need tight riveting. Consider
cherry rivets or pop rivets- which BTW I rarely did until the RV-12 came out
and I figured the whole plane is pop rivets so it can't be that bad.
Pascal
Sent: Tuesday, October 19, 2010 2:14 PM
Subject: RE: Tough Rivets on Fuse Forward Side Skin
Bob
Posted: Tue Oct 19, 2010 2:45 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Did you purchase the bar or make it? If you bought it, do you have a
reference link?
-Sean #40303
carlosh(at)structuralaz.c Guest
Posted: Tue Oct 19, 2010 2:54 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Here's a less expensive tungsten
choice....http://www.tungsten-bucking-bar.com/prices.html
Carlos in AZ
On 10/19/2010 3:31 PM, Pascal wrote:
Bob;
The bar is small and tough, but it's expensive too. It does work very
well for a person just starting who could benefit from it throughout
the build.
Sean;
my bucking bars to fit after not being able to take the abuse of the
riveting on the plates.
Consider cherry rivets or pop rivets- which BTW I rarely did until the
RV-12 came out and I figured the whole plane is pop rivets so it can't
be that bad.
Pascal
> wasn't
> Bob
effectus(at)rogers.com Guest
Posted: Tue Oct 19, 2010 2:57 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
You can get them from Mike Lauritsen at Cleaveland Tools
Dave
Posted: Tue Oct 19, 2010 3:00 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Stein sells a tungsten bar. Make sure you're sitting down when you
see the price.
On Oct 19, 2010, at 3:38 PM, Sean Stephens wrote:
<sean(at)stephensville.com>
a reference link?
-Sean #40303
> have some
rv10(at)colohan.com Guest
Posted: Tue Oct 19, 2010 4:55 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
I picked up a tungsten bar from ebay, sold by the fine folks at www.tungsten.com.
Works great. It is edging out my Cleaveland Main Squeeze as my "favourite tool".
Chris
On Tue, Oct 19, 2010 at 3:58 PM, Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote] --> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)>
Stein sells a tungsten bar. Make sure you're sitting down when you see the price.
[quote] --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
Did you purchase the bar or make it? If you bought it, do you have a reference link?
-Sean #40303
[quote] --> RV10-List message posted by: "Bob Leffler"<rv(at)thelefflers.com (rv(at)thelefflers.com)>
Deems Davis
Posted: Tue Oct 19, 2010 5:00 pm Post subject: Tough Rivets on Fuse Forward Side Skin |
Sean:
Here's what I did for that situation:
http://deemsrv10.com/album/Sec%2029%20Fuse%20Side%20Skins/slides/DSC02624.html
I used a cutoff wheel on a die grinder to make the cut,
BTW ,I think I know where your emp bar is, it found its way into my hangar, send me your address and I'll send it to you.
Deems
On 10/19/2010 2:38 PM, Sean Stephens wrote: [quote]--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com> (sean(at)stephensville.com)
Is that the modified emp bar you are referring to? Unfortunately an RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and never returned it. Cannot remember his name or if he is even still around.
-Sean #40303
[quote]--> RV10-List message posted by: "Bob Leffler"<rv(at)thelefflers.com> (rv(at)thelefflers.com)
Bob
