How to set my accelerometer?
ssssskippy
PostPosted: Sun Oct 17, 2010 8:24 am    Post subject: How to set my accelerometer? Reply with quote
Hi
I have a problem with my rear accelerometer on a yak52.
It shows on the ground a solid 2G instead 1G.
In the instruments back, there is 3 small screws and a big one.
Can somebody tells me how to set the instrument accurately?
Olivier
Le 17 oct. 2010 à 16:18, Eric Wobschall <eric(at)buffaloskyline.com> a écrit :
Any time a propeller can turn, it can potentially windmill, especially if the resistance is low.
As the airplane moves, the air flow creates pressure differentials in the propeller blades, which are airfoils. This forces the blades to move in the direction of the leading edge, thereby converting this kinetic energy to torque acting on the propeller shaft.
On Oct 17, 2010, at 12:19 AM, Elmar Hegenauer wrote:
> Why does the propeller windmill on
> a ceased engine, sheared gearbox?
> Elmar
bwade154(at)yahoo.com
PostPosted: Sun Oct 17, 2010 1:33 pm    Post subject: How to set my accelerometer? Reply with quote
Olivier I had a problem with my G-meter a few years ago and took the back cover off, mine the interior was made of brass kind of like a clock and vibration over the years just wore it out I took the back G-meter out and put it up front and I had another meter to put in the back you do know that the front g-meter is also a switch and when you exceed the G limit a buzzing sound goes to the headset telling you to knock it off your exceeding my G-limits.
Bill Wade
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Sent: Sun, October 17, 2010 12:20:47 PM
Subject: How to set my accelerometer?
--> Yak-List message posted by: ssssskippy <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
Hi
Olivier
Le 17 oct. 2010 à 16:18, Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)> a écrit :
--> Yak-List message posted by: Eric Wobschall <eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>
> --> Yak-List message posted by: Elmar Hegenauer <elmar.h(at)shaw.ca (elmar.h(at)shaw.ca)>
> Elmar
ssssskippy
PostPosted: Sun Oct 17, 2010 1:46 pm    Post subject: How to set my accelerometer? Reply with quote
Thanks for your answer.
So you mean that the best way is to replace it?
2010/10/17 bill wade <bwade154(at)yahoo.com (bwade154(at)yahoo.com)>
[quote]Olivier I had a problem with my G-meter a few years ago and took the back cover off, mine the interior was made of brass kind of like a clock and vibration over the years just wore it out I took the back G-meter out and put it up front and I had another meter to put in the back you do know that the front g-meter is also a switch and when you exceed the G limit a buzzing sound goes to the headset telling you to knock it off your exceeding my G-limits.
Bill Wade
From: ssssskippy <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Hi
Olivier
> Elmar
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
PostPosted: Mon Oct 18, 2010 7:35 am    Post subject: How to set my accelerometer? Reply with quote
Yes if its worn so bad that it will not return to 1 g after a flight and gives erroneous measurements in the air, the rear cockpit G-meter is not wired to the aircraft and doesn't need the switch. But keep in mind that the Yak 52 G-meter has a switch in it, it is wired in front cockpit and front and rear meters are the same. I had to something with mine because the buzzer kept going off.
Does the GIB really need a G-meter?
To: yak-list(at)matronics.com
Sent: Sun, October 17, 2010 5:44:05 PM
Subject: Re: How to set my accelerometer?
[quote] Olivier I had a problem with my G-meter a few years ago and took the back cover off, mine the interior was made of brass kind of like a clock and vibration over the years just wore it out I took the back G-meter out and put it up front and I had another meter to put in the back you do know that the front g-meter is also a switch and when you exceed the G limit a buzzing sound goes to the headset telling you to knock it off your exceeding my G-limits.
Bill Wade
Hi
Olivier
> Elmar
et="_blank">http://www.matronics.com/Navigator?Yak-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution
http://www.matroni=================== [b]
ssssskippy
PostPosted: Mon Oct 18, 2010 8:22 am    Post subject: How to set my accelerometer? Reply with quote
Ok
Roger that.
In fact it’s a good thing for me that the GIB have a Gmeter……I’m still learning aerobatics so my instructor can read the G’s in the back seat.
Now I understand why  I see all in black when the GIB pull a loop J)))
Olivier
De : owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] De la part de bill wade
Envoyé : lundi 18 octobre 2010 17:31
À : yak-list(at)matronics.com
Objet : Re: How to set my accelerometer?
Bill Wade
Hi
Olivier
>> Elmar
5
6
7
8
9
Rob Rowe
PostPosted: Mon Oct 18, 2010 10:47 am    Post subject: Re: How to set my accelerometer? Reply with quote
Olivier,
As a wild card you could check to see if the G meter's internal transport protection screw has been fully wound OUT (counter-clockwise).
It's under the slotted cover ('B' in the attached PDF file) on the back of the meter.
You need to make sure that it's snug up against the casing (and not free to rotate) otherwise it might impinge on the mechanism.
Bon courage!
Rob R.
G-Meter Adjustments.pdf
 Filename:  G-Meter Adjustments.pdf
 Filesize:  150.24 KB
 Downloaded:  407 Time(s)
sammessani(at)yahoo.fr
PostPosted: Mon Oct 18, 2010 11:04 am    Post subject: How to set my accelerometer? Reply with quote
Hi,
Easy to repair, the big screw rear the accelerometer
is to stock the gmeter, the 3 screws are for SET the alarm
limit. Open completely the gmeter by the screws on the side
and you Will understand the mechanism it's easy
After the most difficult is to calibrate, I used for this my iPhone
Sam
Envoyé de mon iPhone
Le 18 oct. 2010 à 18:16, "ssssskippy" <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)> a écrit :
[quote] st1\:*{behavior:url(#default#ieooui) } <![endif]-->
Ok
Roger that.
Olivier
De : owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com] De la part de bill wade
À : [url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
From: Olivier Vigneron <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
To: [url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
2010/10/17 bill wade <[url=mailto:bwade154(at)yahoo.com]bwade154(at)yahoo.com (bwade154(at)yahoo.com)[/url]>
Bill Wade
From: ssssskippy <[url=mailto:ssssskippy(at)gmail.com]ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)[/url]>
To: "[url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]" <[url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]>
--> Yak-List message posted by: ssssskippy <[url=mailto:ssssskippy(at)gmail.com]ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)[/url]>
Hi
Olivier
Le 17 oct. 2010 à 16:18, Eric Wobschall <[url=mailto:eric(at)buffaloskyline.com]eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)[/url]> a écrit :
> --> Yak-List message posted by: Eric Wobschall <[url=mailto:eric(at)buffaloskyline.com]eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)[/url]>
>> --> Yak-List message posted by: Elmar Hegenauer <[url=mailto:elmar.h(at)shaw.ca]elmar.h(at)shaw.ca (elmar.h(at)shaw.ca)[/url]>
>> Elmar
http://www.matronics.com/Navigator?Yak-Listhttp://www.matroni===================
5
ssssskippy
PostPosted: Mon Oct 18, 2010 11:23 am    Post subject: How to set my accelerometer? Reply with quote
thank you for your answer.
How do you use the iphone to calibrate it? I know that the iphone contains some accelerometer but I didn't know that you could access to the G values?
2010/10/18 sammessani(at)yahoo.fr (sammessani(at)yahoo.fr) <sammessani(at)yahoo.fr (sammessani(at)yahoo.fr)>
[quote]Hi,
Sam
Ok
Roger that.
Olivier
De : owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] De la part de bill wade
À : (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)
To: (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)
2010/10/17 bill wade < (bwade154(at)yahoo.com)bwade154(at)yahoo.com (bwade154(at)yahoo.com)>
Bill Wade
From: ssssskippy < (ssssskippy(at)gmail.com)ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
To: " (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)" < (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)>
--> Yak-List message posted by: ssssskippy < (ssssskippy(at)gmail.com)ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
Hi
Olivier
Le 17 oct. 2010 à 16:18, Eric Wobschall < (eric(at)buffaloskyline.com)eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)> a écrit :
> --> Yak-List message posted by: Eric Wobschall < (eric(at)buffaloskyline.com)eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>
>> --> Yak-List message posted by: Elmar Hegenauer < (elmar.h(at)shaw.ca)elmar.h(at)shaw.ca (elmar.h(at)shaw.ca)>
>> Elmar
5
6
PostPosted: Mon Oct 18, 2010 2:47 pm    Post subject: How to set my accelerometer? Reply with quote
You can find it in AppStore, anyway attache
Your gmeter with you mobile,use for this adhesive
tape and move them with your hand and check
both value. A friend of me repaired my 2 gmeter
on my yak52 & now they work fine.
Sam.
Le 18 oct. 2010 à 21:18, Olivier Vigneron <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)> a écrit :
[quote]thank you for your answer.
2010/10/18 [url=mailto:sammessani(at)yahoo.fr]sammessani(at)yahoo.fr (sammessani(at)yahoo.fr)[/url] <[url=mailto:sammessani(at)yahoo.fr]sammessani(at)yahoo.fr (sammessani(at)yahoo.fr)[/url]>
Hi,
Sam
Le 18 oct. 2010 à 18:16, "ssssskippy" <[url=mailto:ssssskippy(at)gmail.com]ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)[/url]> a écrit :
Ok
Roger that.
Olivier
De : [url=mailto:owner-yak-list-server(at)matronics.com]owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)[/url] [mailto:[url=mailto:owner-yak-list-server(at)matronics.com]owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)[/url]] De la part de bill wade
À : (yak-list(at)matronics.com)[url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
From: Olivier Vigneron <[url=mailto:ssssskippy(at)gmail.com]ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)[/url]>
To: (yak-list(at)matronics.com)[url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]
2010/10/17 bill wade < (bwade154(at)yahoo.com)[url=mailto:bwade154(at)yahoo.com]bwade154(at)yahoo.com (bwade154(at)yahoo.com)[/url]>
Bill Wade
From: ssssskippy < (ssssskippy(at)gmail.com)[url=mailto:ssssskippy(at)gmail.com]ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)[/url]>
To: " (yak-list(at)matronics.com)[url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]" < (yak-list(at)matronics.com)[url=mailto:yak-list(at)matronics.com]yak-list(at)matronics.com (yak-list(at)matronics.com)[/url]>
--> Yak-List message posted by: ssssskippy < (ssssskippy(at)gmail.com)[url=mailto:ssssskippy(at)gmail.com]ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)[/url]>
Hi
Olivier
Le 17 oct. 2010 à 16:18, Eric Wobschall < (eric(at)buffaloskyline.com)[url=mailto:eric(at)buffaloskyline.com]eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)[/url]> a écrit :
> --> Yak-List message posted by: Eric Wobschall < (eric(at)buffaloskyline.com)[url=mailto:eric(at)buffaloskyline.com]eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)[/url]>
>> --> Yak-List message posted by: Elmar Hegenauer < (elmar.h(at)shaw.ca)[url=mailto:elmar.h(at)shaw.ca]elmar.h(at)shaw.ca (elmar.h(at)shaw.ca)[/url]>
>> Elmar
5
6
7
mike_beresford(at)yahoo.c
PostPosted: Mon Oct 18, 2010 11:27 pm    Post subject: How to set my accelerometer? Reply with quote
Hi all
There is a very basic, very easy G-meter calibration technique:
- Put the G-meter on a solid surface, in the normal flight attitude. It should now read 1G
- Stand it vertically upright. It should now read zero.
- Place it in the inverted position. It should now read -1G.
This technique is part of the overall calibration routine we use on G-meters fitted to some more modern aerobatic trainers, and is part of the OEM's documented procedure. The full procedure also includes checks on the effect of vibrations, but that is probably not done for the Russian G-meters.
Blue skies
Mike
From: "sammessani(at)yahoo.fr" <sammessani(at)yahoo.fr>
Sent: Tue, 19 October, 2010 0:39:55
Sam.
2010/10/18 (sammessani(at)yahoo.fr)sammessani(at)yahoo.fr (sammessani(at)yahoo.fr) < (sammessani(at)yahoo.fr)sammessani(at)yahoo.fr (sammessani(at)yahoo.fr)>
Hi,
Sam
Le 18 oct. 2010 à 18:16, "ssssskippy" < (ssssskippy(at)gmail.com)ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)> a écrit :
Ok
Roger that.
Olivier
De : (owner-yak-list-server(at)matronics.com)owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto: (owner-yak-list-server(at)matronics.com)owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] De la part de bill wade
À : (yak-list(at)matronics.com) (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)
From: Olivier Vigneron < (ssssskippy(at)gmail.com)ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
To: (yak-list(at)matronics.com) (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)
2010/10/17 bill wade < (bwade154(at)yahoo.com) (bwade154(at)yahoo.com)bwade154(at)yahoo.com (bwade154(at)yahoo.com)>
Bill Wade
From: ssssskippy < (ssssskippy(at)gmail.com) (ssssskippy(at)gmail.com)ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
To: " (yak-list(at)matronics.com) (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)" < (yak-list(at)matronics.com) (yak-list(at)matronics.com)yak-list(at)matronics.com (yak-list(at)matronics.com)>
--> Yak-List message posted by: ssssskippy < (ssssskippy(at)gmail.com) (ssssskippy(at)gmail.com)ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
Hi
Olivier
Le 17 oct. 2010 à 16:18, Eric Wobschall < (eric(at)buffaloskyline.com) (eric(at)buffaloskyline.com)eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)> a écrit :
> --> Yak-List message posted by: Eric Wobschall < (eric(at)buffaloskyline.com) (eric(at)buffaloskyline.com)eric(at)buffaloskyline.com (eric(at)buffaloskyline.com)>
>> --> Yak-List message posted by: Elmar Hegenauer < (elmar.h(at)shaw.ca) (elmar.h(at)shaw.ca)elmar.h(at)shaw.ca (elmar.h(at)shaw.ca)>
>> Elmar
et="_blank">[/url][url=http://www.matronics.com/Navigator?Yak-List]http://www.matronics.com/Navigator?Yak-List tp://[/url][url=http://forums.matronics.com]forums.matronics.com _blank">[/url][url=http://www.matronics.com/contribution]http://www.matronics.com/contribution
[/url][url=http://www.matroni===================]http://www.matroni===================
[/url][url=http://www.matronics.com/Navigator?Yak-List]http://www.matronics.com/Navigator?Yak-List[/url][url=http://www.matroni===================]http://www.matroni===================
5
6
7
8
ssssskippy
PostPosted: Tue Oct 19, 2010 12:15 am    Post subject: How to set my accelerometer? Reply with quote
Impossible to find simpler and more accurate J)))
De : owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] De la part de Mike Beresford
Envoyé : mardi 19 octobre 2010 09:25
Hi all
Blue skies
Mike
Sam.
Hi,
Sam
Ok
Roger that.
Olivier
Bill Wade
Hi
Olivier
>> Elmar
http://www.matronics.com/Navigator?Yak-Listhttp://forums.matronics.com
5
6
7
8
9
ssssskippy
PostPosted: Tue Oct 19, 2010 5:00 am    Post subject: How to set my accelerometer? Reply with quote
Hi
Good news!
Thank you very much for all your advices, especialy Rob for the internal picture and Sam for the calibration procedure.
In fact, it was the transport screw that was blocking the Gmeter internal mouvement due certainly to the vibrations (good hoping so, Beach Boys forever Smile)) )
Bye and have nice flights
Olivier
2010/10/18 Olivier Vigneron <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
[quote] marvellous!!
Thank you very much
2010/10/18 Rob Rowe <yak-list(at)robrowe.plus.com (yak-list(at)robrowe.plus.com)>
--> Yak-List message posted by: "Rob Rowe" <yak-list(at)robrowe.plus.com (yak-list(at)robrowe.plus.com)>
Olivier,
Bon courage!
Rob R.
http://forums.matronics.com/viewtopic.php?p=316217#316217
http://forums.matronics.com//files/g_meter_adjustments_844.pdf
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
