craig.nelson(at)heraeus.c Guest
Posted: Fri Oct 15, 2010 6:24 pm Post subject: wheels/side load |
hi all I built a plane in the mid 80's and used 20 in bicycle wheels. had them custom spoked to a mini bike hub with breaks and larger spokes. flew the heck out of this plane. it was a wing warp design and I had lots of x wind landings
uncle craig
63.68 KB |
2960 Time(s) |
Dana
Posted: Sat Oct 16, 2010 5:57 am Post subject: wheels/side load |
I've been thinking about bicycle wheels for the biplane I'm designing.
One idea I had was to sandwich two hubs together and respoke the
wheels to get more side support.
OTOH the new Schwinn Stingray bikes (nothing like the one I had as a
kid) has a real fat rear wheel. but I doubt it'd be adequate for
anything heavier than a true ultralight.
-Dana
"Nelson, Craig" <craig.nelson(at)heraeus.com> wrote:
(10/15/2010 22:21)
| Quote: | hi all I built a plane in the mid 80's and used 20 in bicycle wheels. had them custom spoked to a mini bike hub with breaks and larger spokes. flew the heck out of this plane. it was a wing warp design and I had lots of x wind landings
uncle craig
Posted: Sat Oct 16, 2010 6:31 am Post subject: wheels/side load |
| Quote: | kid) has a real fat rear wheel. but I doubt it'd be adequate for
-Dana
Dana, other spoke enthusiasts,
With a little bit of research, there are probably dozens of likely candidates that
would work very well for use on a plane. There are lots of scooters, mini motorcycles,
and the like, that would probably work well. Most of these will comes with some kind
of disc brake set-up. With diameter from 12" to 20+", a guy could easily come up with
a set of olden-day looking spoked wheels.
Personally, I can't really picture a Kolb wearing a set of spoked wheels. The style doesn't
make me think of "early 1900's airplanes. Maybe after seeing a Kolb with them, I'd see what
Rick is getting at.
For the relatively low touchdown speed, I don't think the side-load issue is a major
consideration. I think a 20" spoked Honda scooter front wheel would be plenty robust to
handle routine landings.
I want to see what a Kolb looks like with spoked wheels, even if it's only a mock-up.
Mike Welch
MkIII CX
capedavis(at)yahoo.com Guest
Posted: Sat Oct 16, 2010 6:41 am Post subject: wheels/side load |
Craig, Nice looking aircraft !
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Posted: Sat Oct 16, 2010 7:57 am Post subject: wheels/side load |
John,
You'd be screwed!!
Mike
Subject: Re: Kolb-List: wheels/side load
Date: Sat, 16 Oct 2010 09:17:28 -0600
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Tahoma;font-size:10pt;} Mike W/Gang:
What about landings that are other than routine?
Mike Welch
MkIII CX
arget=_blank>http://www.matronics.com/Navigator?Kolb-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
eagle1live(at)yahoo.com Guest
Posted: Sat Oct 16, 2010 8:20 am Post subject: wheels/side load |
For you Kids who are to young to remember, back in the early 1930's many cars had wire wheels. They were a big upgrade from some of the wooden spooked wheels.
The former Az Bald Eagle
Sent: Sat, October 16, 2010 8:17:28 AM
Subject: Re: wheels/side load
.hmmessage P { PADDING-BOTTOM:0px;MARGIN:0px;PADDING-LEFT:0px;PADDING-RIGHT:0px;PADDING-TOP:0px;} BODY.hmmessage { FONT-FAMILY:Tahoma;FONT-SIZE:10pt;} Mike W/Gang:
Mike Welch
MkIII CX
Posted: Sat Oct 16, 2010 8:46 am Post subject: wheels/side load |
John
After I sold this plane the new owner ground looped it at high speed, bent a wing tip and scrubbed the gear clean off the plane….. after all that the wheels straight and true
Uncle craig
Don’t archive
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of John Hauck
Sent: Saturday, October 16, 2010 11:17 AM
Mike W/Gang:
Mike Welch
MkIII CX
| Quote: | | http://www.matronics.com/Navigator?Kolb-List | 0123456789
