Washing Gas (was)Just when you were getting used to 10% et
pchristensen10(at)austin.
PostPosted: Fri Oct 15, 2010 10:43 am    Post subject: Washing Gas (was)Just when you were getting used to 10% et Reply with quote
I use it to kill weeds and bugs. Or alternatively I make suppositories and shove them up some congressman's (oops I almost used a bad word)
Pete
On 10/15/2010 10:06 AM, FLYaDIVE wrote: [quote]Pete:
After yo have a carboy filled with this alcohol/gas/water mixture what do you do with the hazardous waste?
Here is a simple process to reduce the hazmat to zero.
Agitate the mixture while holding a propane (or hotter) flame blowing onto the top of the mixture.
The alcohol/gas will burn off leaving water.
There is also another process where you put a submersible heater into the mixture which causes the flammable stuff to vaporize and that vapor is them hit with a flame. This is a bit questionable due to cost and setup requirements.
Barry
On Fri, Oct 15, 2010 at 10:04 AM, Pete Christensen <pchristensen10(at)austin.rr.com (pchristensen10(at)austin.rr.com)> wrote:
--> RotaxEngines-List message posted by: Pete Christensen <pchristensen10(at)austin.rr.com (pchristensen10(at)austin.rr.com)>
I siphon my unwashed gasoline into the water I have standing in the bottom of my 6.5 gallon glass carboy by putting the outlet side of the siphon hose in the standing water so that the gasoline swirls into the standing water. Having marked the water level on the side of the carboy before adding gas I am able to judge the quantity of ethanol I have removed since the level comes up about 3/4" after the mix settles. I usually let it sit 1/2 hour to be safe. I then siphon washed gas off the top leaving about 1.25" of gasoline on top of the water so that I don't siphon up any water with the washed gas. I can wash about 25-30 gallons by just siphoning more unwashed gas into the carboy and don't have to add any more water with each carboy fill up. Eventually there is 4 or 5 inches of alcohol/water mix in the bottom of of the carboy so that only 4 gallons of unwashed gas can be added. When that happens I siphon the alcohol/water mix off the bottom of the tank being careful not to siphon any gasoline.
I then start over. There is always some gas and water/alcohol left in the carboy so that I am not wasting any gasoline.
Pete
On 10/14/2010 6:52 PM, Noel Loveys wrote:
--> RotaxEngines-List message posted by: "Noel Loveys"<noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)>
I take it you are leaving lots of time for the water to settle out
completely. Are you draining from the bottom or siphoning?
Noel
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
http://forums.matronics.com
le, List Admin.
Barry
"Chop'd Liver"
thesupe(at)hotmail.com
PostPosted: Fri Oct 15, 2010 5:30 pm    Post subject: Washing Gas (was)Just when you were getting used to 10% et Reply with quote
Didn't they start out as water cooler bottles?  Now the watercooler bottles are plastic.  I do have a glass one that I used to make beer in but havn't done it in quite a while.  Good thing we can get non oxiginated premium gas up here in Mn.  That's what I run through my Jabiru and Rotax.  Take care,  Jim Chuk
Date: Fri, 15 Oct 2010 13:36:02 -0500
To: rotaxengines-list(at)matronics.com
Subject: Re: RotaxEngines-List: Washing Gas (was)Just when you were getting used to 10% ethanol...
It is a large small mouth bottle used in making beer.
[img]cid:part1.06060001.03090808(at)austin.rr.com[/img]
On 10/15/2010 10:04 AM, Hugh McKay wrote:
--> RotaxEngines-List message posted by: "Hugh McKay" <hgmckay(at)bellsouth.net> (hgmckay(at)bellsouth.net)
Pete,
Pardon my ignorance in this matter, but please describe what you refer to as "a 6.5 gallon carboy"?
Hugh McKay
Rotax 912 UL
Allegro 2000
From: "Pete Christensen" <pchristensen10(at)austin.rr.com> (pchristensen10(at)austin.rr.com)
Sent: Friday, October 15, 2010 10:04 AM
To: <rotaxengines-list(at)matronics.com> (rotaxengines-list(at)matronics.com)
Subject: Washing Gas (was)Just when you were getting used to 10% ethanol...
--> RotaxEngines-List message posted by: Pete Christensen <pchristensen10(at)austin.rr.com> (pchristensen10(at)austin.rr.com)
Pete
-->  RotaxEngines-List message posted by: "Noel Loveys"<noelloveys(at)yahoo.ca> (noelloveys(at)yahoo.ca)
Noel
 Filesize:  238.71 KB
 Viewed:  2500 Time(s)
Float Flyr
PostPosted: Sun Oct 17, 2010 5:34 pm    Post subject: Washing Gas (was)Just when you were getting used to 10% et Reply with quote
You could run it through a still.... Alcohol boils off somewhere around 80C at sea level. Then use the distilled alcohol, which BTW is not palatable (Darn!), as fuel for a table heater or for cleaning small parts. The alcohol is bio degradable but I don’t know about the stuff they put in to make it unpalatable.
Noel
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Pete Christensen
Sent: October 15, 2010 4:11 PM
Subject: Re: Washing Gas (was)Just when you were getting used to 10% ethanol...
Pete
Pete:
Barry
Pete
Noel
le, List Admin.
Barry
"Chop'd Liver"
[quote] <=======================http://www.matronics.com/Navigator?RotaxEngines-List[/b]http://forums.matronics.com - List Contribution Web generous nbsp;   --> http://www.matronics.com/c=[/b] [b]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
