Carolina Flyer
Joined: 03 Oct 2010 Posts: 62 Location: Buffalo, South Carolina
Posted: Wed Oct 06, 2010 9:34 am Post subject: New to the Forum |
Hello Everyone,
I am so glad I ran across this Forum..... There is a wealth of knowledge here, and some awesome pictures.... I have a Kolb Firestar II that I bought that I found on Barnstormers..... It had a few things that needed intention.... The Tail Wheel had broke off from a hard handing, and it damaged the elevator and rudder. Just the covering was damaged on the elevator, and the bottom of the rudder need the bottom tubing replaced. I have it almost finished, and just today I purchased a MicroAir 760 to install in a new dash I am working on... I did not like the drum brakes and I removed them and installed the Black Max 1000 system.... and to top it off I installed some wheel and tire combo that I have come up with...I have seen many people have the Carlisle golf cart tires on a 6" rim and call them Tundra Tires.... They are Heavy and Stiff, and the size is all I see that is close to being what is referred to as a Tundra Tire..... These Tires I have are Soft and only use between 5 and 10 pounds of air, and they are Light Weight........... They act like the Big Boys Tundra Tires in Alaska...... The Rims I have are 8" in Diameter, and fit on Black Max and Hegar wheel hubs, and maybe others..... Anyway I would like your input on what you think about my Tire and Wheel Combo........
Kolb Firestar II
Rotax 503 with Electric Start
C-Box Re-Drive with a RK400 Clutch
68" Warp Drive Prop
Black Max 1000 Hydraulic Brakes
Tundra Tires on 8" x 9" Aluminum Rims
Current in date BRS Ballistic Recovery Chute
Kuntzleman Dual Magnum Strobes
ELT (emergency locator transmitters)
N-Numbered with a current Annual done May 2010
Soon to be Installed Micro Air 760 VHF TRANSCEIVER ,
And maybe later a 3 Blade Prop, because they make less noise
149.4 KB |
7343 Time(s) |
128.71 KB |
7343 Time(s) |
_________________ Kolb Firestar II
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
zeprep251(at)aol.com Guest
Posted: Wed Oct 06, 2010 11:34 am Post subject: New to the Forum |
Joe,
Looks pretty spiffy with those big shoes! Welcome
G.Aman former FS2 builder/owner
WhiskeyVictor36(at)aol.co Guest
Posted: Wed Oct 06, 2010 12:22 pm Post subject: New to the Forum |
Hey Joe,
Those big wheels are awesome! I like them.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 10/6/2010 1:36:47 P.M. Eastern Daylight Time, joe.a.lawson(at)gmail.com writes:
| Quote: | Anyway I would like your input on what you think about my Tire and Wheel Combo........
Carolina Flyer
Posted: Wed Oct 06, 2010 5:53 pm Post subject: Re: New to the Forum |
Thanks for the kind comments.... I didn't go with these Tundra Tires for the Looks, even though I think it Looks better with Large Tires.... I feel that the front gear on the Firestar bends to easy, and it should bend before making the cage bend.... These Tires just softens the suspension. The Kolb Factory quoted me $200.00 for New Main Gear, and hopefully these Tires will help me to not have to replace my Main Gear in the Future .......... Joe
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Richard Pike
Posted: Wed Oct 06, 2010 6:46 pm Post subject: Re: New to the Forum |
Good looking airplane. Moving the prop further away from the trailing edge will cut down on your prop noise. What is the reduction ratio of your gearbox?
Richard Pike
MKIII N420P (420ldPoops)
Carolina Flyer
Posted: Wed Oct 06, 2010 7:34 pm Post subject: Re: New to the Forum |
The GearBox is 3.0 to 1 ratio with the RK400 clutch
I plan on putting a Stainless Exhaust system on it soon
111.88 KB |
7298 Time(s) |
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Fri Oct 08, 2010 9:10 am Post subject: Re: New to the Forum |
Are those tires the Nanco 21x12x8?
| Carolina Flyer wrote: | Hello Everyone,
Kolb Firestar II
68" Warp Drive Prop
And maybe later a 3 Blade Prop, because they make less noise |
Carolina Flyer
Posted: Fri Oct 08, 2010 9:48 am Post subject: New to the Forum |
Jason,
Yes they are, do you use them as well...... Joe
On Oct 8, 2010, at 1:10 PM, "Jason Omelchuck" <jason(at)trek-tech.com>
wrote:
> Hello Everyone,
> Tundra Tire..... These Tires I have are Soft and only use between 5 !
> Kolb Firestar II
> 68" Warp Drive Prop
http://forums.matronics.com/viewtopic.php?p=315110#315110
503 C-Box / RK400
Soon to have a
Rotax 670 DCDI
with a C-Box and
RK 400 Clutch
Challenger II
503 Tall Drive
