glastar(at)gmx.net Guest
Posted: Tue Oct 05, 2010 4:43 am Post subject: 1st answered 2nd question about rudder trim |
Thanks a lot Bob, exactly what I did need.
Now looking at rudder trim, anybody has the internal (system) trim and
can tell how good it works?
Cheers Werner
On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote:
Try iflyrv10.com
Bob
robin(at)PaintTheWeb.com Guest
Posted: Tue Oct 05, 2010 7:52 am Post subject: 1st answered 2nd question about rudder trim |
Mine works very well. Would not fly without it. Putting one in my 8A now.
http://painttheweb.com/painttheweb/rv-10/RudderTrim.aspx
Robin
On Oct 5, 2010, at 5:41 AM, Werner Schneider <glastar(at)gmx.net> wrote:
Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works?
Cheers Werner
> Try iflyrv10.com
> Bob
Posted: Tue Oct 05, 2010 8:11 am Post subject: 1st answered 2nd question about rudder trim |
Thanks a lot Robin,
any idea how much deflection you use normally?
Cheers Werner
On 05.10.2010 17:49, Robin Marks wrote:
Robin
> Cheers Werner
>> Try iflyrv10.com
>> Bob
tsts4
Posted: Tue Oct 05, 2010 8:22 am Post subject: Re: 1st answered 2nd question about rudder trim |
Another option, if you don't like the fixed wedge method or don't want to go the servo route, is a spring bias system:
http://www.mlblueskunk.com/Rudder_Trim_System.html
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Posted: Tue Oct 05, 2010 8:40 am Post subject: 1st answered 2nd question about rudder trim |
Yes... not much and sometimes it requires a little "reverse" deflection.
It all depends on how your plane is rigged (ultimately) and then of course
fuel / passenger loading and X Wind.
I rarely (if ever) see it deflected more than 30% of its maximum travel.
BTW while I consider all other cockpit trim indicators an absolute safety
requirement but having a rudder trim indicator is not a requirement
because you can easily overpower the rudder trim with foot action and you
have a built in indicator with the slip ball. Your call. The only reason I
bring it up is my painter shorted out my Ray Allen position indicator
(thanks!) and after about 160 hours of additional flight time I have not
really missed the Rudder Trim indication. Again your call.
Robin
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Tue Oct 05, 2010 9:50 am Post subject: 1st answered 2nd question about rudder trim |
Robin, first time I actually went out to your site. Nice job, GREAT write-up... and I'm flattered that you used one of the shots as the background that I took of your plane while we were touring Hearst Castle, Morrow Bay, and Pismo with both our 10's. Now that was fun! Flying back to Calif in the next few days for a visit. Hope to see you soon on a visit to Pecan.
Don McDonald
--- On Tue, 10/5/10, Robin Marks <robin(at)PaintTheWeb.com> wrote:
Subject: Re: 1st answered 2nd question about rudder trim
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Tuesday, October 5, 2010, 8:49 AM
--> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)>
Robin
On Oct 5, 2010, at 5:41 AM, Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
| Quote: | --> RV10-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>
Cheers Werner
> --> RV10-List message posted by: "Condrey, Bob (US SSA)"<bob.condrey(at)baesystems.com (bob.condrey(at)baesystems.com)>
> Try iflyrv10.com
> Bob
sp; --> httphttp://forums.matronics.com/" target=_blank>http://forums.matronics.com
_________________ Don A. McDonald
40636 |
jcumins(at)jcis.net Guest
Posted: Tue Oct 05, 2010 10:58 am Post subject: 1st answered 2nd question about rudder trim |
Bob
I plan to go with the Bias spring system by
http://www.mlblueskunk.com/Rudder_Trim_System.html I like the design and I
do not have to cut into my rudder.
John G. Cumins
40864 Emp complete Wings s/b started
Posted: Tue Oct 05, 2010 3:28 pm Post subject: 1st answered 2nd question about rudder trim |
I'm trying to go with Don Orrick's solution as documented here on Tim
Olsen's site:
http://www.myrv10.com/tips/mods/RudderTrim/DonOrrick.html
Don's has a very fine flying '10 with many fine features I'd love to
copy. When I saw it at Oshkosh several years ago I couldn't figure out
what the vernier knob was for but later saw this on Tim's site.
I fly a Maule right now and it has a similar setup in the sense that it
simply applies a spring to the right rudder pedal control using one of
these to control the spring:
http://www.aircraftspruce.com/catalog/appages/thandledashctrl.php
The assumption here is that only right trim is required. Works fine on
the Maule and is about as simple as it gets.
Don uses a pulley to turn 180 degrees at the firewall. I mocked it up
with the T-handle control above and looks like the cable can make the
turn with out the pulley. So I've installed a bracket and cable and
will try to size and fit a spring to see if I can make it work. If
not, the Skunk works control horn approach looks good too.
Bill Watson
On 10/5/2010 8:41 AM, Werner Schneider wrote:
Posted: Tue Oct 05, 2010 4:25 pm Post subject: 1st answered 2nd question about rudder trim |
Yes this photo is on my phone, iPad and website. I occasionally get comments about flying over all that water but you and I know we were on the shoreline shooting west.
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Don McDonald
Sent: Tuesday, October 05, 2010 10:48 AM
Don McDonald
To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
--> RV10-List message posted by: Robin Marks <robin(at)painttheweb.com>
Robin
> --> RV10-List message posted by: Werner Schneider <glastar(at)gmx.net>
> Cheers Werner
>> --> RV10-List message posted by: "Condrey, Bob (US SSA)"<bob.condrey(at)baesystems.com>
>> Try iflyrv10.com
>> Bob
= Use the Matronics List Features Navigator to browse[/b] | [/b][/quote] Day Browse, Chat, FAQ,[/b]w.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV1[/quote] =======================[/b][/quote] m">http://forums.matronics.com[/b][/quote] -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]
19.26 KB |
5493 Time(s) |
