sean(at)stephensville.com Guest
Posted: Fri Sep 24, 2010 7:48 am Post subject: Blank Messages (was: iPad Mount update) |
I noticed something similar that started just recently with the
Matronics lists. Not sure if Matt changed anything recently, but...
I use Thunderbird (on a Mac) and had to set my account to always use
plain text when sending emails to the matronics.com domain or they would
just show up as blank. I never had to do this until about a month ago.
Maybe Matt could chime in with any suggestions.
-Sean
On 9/24/10 10:21 AM, Tim Olson wrote:
He's got something funky with his email program. I am
trying to pull it apart now and see if there is an attachment
to view. But here is the text I extracted. I noticed the message
had size, but just wasn't displaying....
Tim
Tim Olson
Posted: Fri Sep 24, 2010 8:03 am Post subject: Blank Messages (was: iPad Mount update) |
Actually, to be a friendly email person, it's a good idea
to use only text email anyway, when possible. In thunderbird
you can still compose an HTML email if you hold SHIFT
while you click "write" for a new email.
The reason is, if you send HTML email, in most people's cases,
the HTML email takes up more space than a text email does, but
it gets worse, it also sends a text version of it and the
recipient's viewer chooses which one to display. So
now you're increasing each message size by 2X just because
you are sending HTML emails.
Things like background images to emails, and stuff like
that, are just a waste of space.
Also, it's a little harder to embed malicious scripts into
text-only emails. So I set that as my default for all
emails, and only send HTML when there is good reason.
Tim Olson - RV-10 N104CD
On 9/24/2010 10:45 AM, Sean Stephens wrote:
-Sean
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28109 Location: Toledo Washington (KTDO) USA
Posted: Fri Sep 24, 2010 9:04 am Post subject: Blank Messages (was: iPad Mount update) |
I haven't changed anything on the input message processing in quite a while.
As has been pointed out, make sure to configure the email client to send "plain-text" only. If the messages are showing up blank, the lack of a legitimate plain-text MIME section is almost always the cause.
Matronics List Admin
At 08:45 AM 9/24/2010 Friday, you wrote:
I noticed something similar that started just recently with the Matronics lists. Not sure if Matt changed anything recently, but...
I use Thunderbird (on a Mac) and had to set my account to always use plain text when sending emails to the matronics.com domain or they would just show up as blank. I never had to do this until about a month ago.
-Sean
>Tim
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: 95+ Hours TTSN - Enjoying Every Minute...
_________________ Matt Dralle
Deems Davis
Posted: Sat Sep 25, 2010 10:06 am Post subject: Blank Messages (was: iPad Mount update) |
Sorry for all of the white space, and Thanks Tim for parsing the
message and re-posting. I use T'bird on a pc and also occasionaly find
emails from matronics lists with empty text. I changed my send options
from (Auto Detect) to plain text, we'll see if that helps.
Deems
On 9/24/2010 8:45 AM, Sean Stephens wrote:
month ago. Maybe Matt could chime in with any suggestions.
-Sean
> Tim
Posted: Sat Sep 25, 2010 11:09 am Post subject: Blank Messages (was: iPad Mount update) |
Tbird used to have an option of 'HTML and text' but it now seems like
we have to make a choice. Bummer.
Linn
On 9/25/2010 1:29 PM, Deems Davis wrote:
Deems
> -Sean
>> Tim
