Adjusting screw torque
Goto page 1, 2  Next
4aplat
PostPosted: Tue Oct 12, 2010 8:40 am    Post subject: Adjusting screw torque Reply with quote
Hi
For my #570 2200 Jab engine I'm looking for the torque I'm supposed to apply on the adjusting screw
I'm not able to found it in the "J2200 Engine Maintenance Solid Valve Lifter Models Manual"
thanks in advance
MicheL
the French Jabiru Forum
http://jabiru-owner.com
Clive J
PostPosted: Tue Oct 12, 2010 9:43 am    Post subject: Adjusting screw torque Reply with quote
Michel, what adjusting screw do you refer to?
A screw on what?
Regards, clive
4aplat
PostPosted: Tue Oct 12, 2010 10:37 am    Post subject: Re: Adjusting screw torque Reply with quote
Hi Clive
I'm speaking about the screw on the Rocker Arm.
Itorked the head at 24 ft.lbs but the screw broke (see the picture)
MicheL
A screw on what?
Regards, clive
Clive J
PostPosted: Tue Oct 12, 2010 11:49 pm    Post subject: Adjusting screw torque Reply with quote
Hello again Michel.
I'm afraid the picture didn't come through, send it direct to my E mail
address.
I don't think there is a torque number for the adjusting screw locknut.
I have heard of these breaking and usually it is because the locknut is
done up too tight.
People are worried the locknut will come loose but in practice if the
locknut is tightened up just by feel this is sufficient. Certainly
nothing like 24 ft/lbs. more like 8. Next time I have the covers off
I'll try it with a torque wrench.
A lot more force is needed to undo the lock nut than do go it up. Try
locking and unlocking a few times with a light force. If the adjusting
screw is the type that takes a hexagon wrench this weakens it so it is
nothing like a normal set screw. Later ones have changed to a solid
screw I think.
There is too much messing about with tappet adjusting. In reality with a
metal to metal head to barrel joint the tappet clearance will not
change. On the very old engines when you pull up a head bolt you are
often twisting the head (even at the right torque as the ally was poor).
Cleaning out the bolt holes so it's a true torque to the bolt is
important. The twist of the head caused locking onto the bolt shank. If
you feel this the bolt hole will need clearing out. An ordinary drill
will do it though there used to be talk of 'reaming' I drilled mine and
they were fine.
I set to 12 thou clearance and providing next time I still have more
than 10 and I can get a 12 feeler gauge 'in' I don't mess with adjusting
the tappet.
In time there is wear in the tappet face and bush and this will need
adjusting out but that is after many hours. That is when with a 12 thou
feeler in the gap you can rattle the tappet.
Regards, Clive
4aplat
PostPosted: Tue Oct 12, 2010 11:56 pm    Post subject: Re: Adjusting screw torque Reply with quote
HI clive
thank's for the answer
here are the pictures (just copy and glue in your browser)
I don't have your email !
http://jabiru-owner.com/images/pdf/vis01.jpg
http://jabiru-owner.com/images/pdf/vis02.jpg
I found the torke value in this document :
http://www.jabirupacific.com/pdf/HeadTorqueValveSetting.pdf
MicheL
matronics(at)rtist.nl
PostPosted: Wed Oct 13, 2010 12:17 am    Post subject: Adjusting screw torque Reply with quote
Ouch... Please read the head torque document over once more. Each time it
mentions 24ft/lb it only refers to the 6 cylinder head bolts.
Rob
4aplat
PostPosted: Wed Oct 13, 2010 12:31 am    Post subject: Re: Adjusting screw torque Reply with quote
reading
Adjust the tappets when the engine is
cold. Head torqued to 24 ft lb. when cold. Carry out this adjustment after five hours of
operation and again after ten hours of operation. At the 25 hour inspection this is done
again.
I supposed 24ftlb was the torque for the nut (as it is int the "tapped adjustment" paragraph
MicheL (not very good in english)
Rob
Lynn Matteson
PostPosted: Wed Oct 13, 2010 2:23 am    Post subject: Adjusting screw torque Reply with quote
Clive, I just figured he was talking about the valve adjusting screw,
but I thought he or someone else would clarify this. I don't know the
torque setting for that screw/jam nut, as I have always just snugged
them up and then added a "bit for good measure"....this is a case
where us old mechanics had this "torque figure" written into our
DNA. : )
Lynn Matteson
Jabiru 2200, #2062
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying...1054 hrs (since 3-27-2006)
On Oct 12, 2010, at 1:40 PM, James, Clive R wrote:
<clive.james(at)uk.bp.com>
A screw on what?
Regards, clive
Lynn
Kitfox IV-Jabiru 2200
N369LM
Clive J
PostPosted: Wed Oct 13, 2010 8:14 am    Post subject: Adjusting screw torque Reply with quote
Indeed the wording is not good.
Need to be careful with 24 ft/lbs, this doesn't apply to all engines. I
believe it's 18, 20 and 24 depending on which engine you have (I maybe
wrong about the 18, I only have a 2000 and a 2003 manual here).
Regards, Clive
Clive J
PostPosted: Wed Oct 13, 2010 8:25 am    Post subject: Adjusting screw torque Reply with quote
'nip it up, and a bit'
I do know of a plane that ended up upside down in a field, one of the
tappet adjusters worked loose and the valve stopped opening. Power
dropped off, 2 POB, couldn't maintain altitude, long crop. Bingo.
I always assumed the nut must have been missed rather than not done up
enough but we'll never know....
4aplat
PostPosted: Wed Oct 13, 2010 9:27 am    Post subject: Re: Adjusting screw torque Reply with quote
Hi Clive
Is it possible to know where it's possible to find 18 (20 or 24) in the manual ?
thanks in advance
MIcheL
Regards, Clive
plus2s
PostPosted: Wed Oct 13, 2010 11:46 am    Post subject: Adjusting screw torque Reply with quote
From memory 24 ft/lb is the assembly torque - rechecks are at 20 ft/lb for head studs
Rgds
Keith
--- On Thu, 14/10/10, 4aplat <ulm(at)ascenseur-parisien.com> wrote:
Subject: Re: Adjusting screw torque
To: jabiruengine-list(at)matronics.com
Date: Thursday, 14, October, 2010, 6:27 AM
--> JabiruEngine-List message posted by: "4aplat" <ulm(at)ascenseur-parisien.com (ulm(at)ascenseur-parisien.com)>
Hi Clive
thanks in advance
MIcheL
Regards, Clive
http://forums.matronics.com/viewtopic.php?p=315595#315595http://www.matronics.com/Nanbsp; -Matt matronics.com/contribution" target=_blank>http://www.matronics.com/contri================
Clive J
PostPosted: Wed Oct 13, 2010 12:02 pm    Post subject: Adjusting screw torque Reply with quote
Section 5.3 'Initial after 25 hours checks'
in all the manuals I have here.
I recall lately there is two torques, one for building the engine and
one for checking afterwards.
The setting in 5.3 is the one to check for.
What is your serial number of the engine and what engine? 2200/3300?
Regards, Clive
Clive J
PostPosted: Wed Oct 13, 2010 12:13 pm    Post subject: Adjusting screw torque Reply with quote
So from the manual below, if you can see the 'zapgrab' picture generally it's 20-22ft lbs
This is from section 7. This is manual has been updated from the one I got with my engine, I only have that on paper and I recall that being 18 ft lbs, the front cover of this manual I just downloaded from the Jab Aus site says it's applicable to all 2200a engines. The 'soft headed' ones all surely bend at 22 lbs...
What vintage is your engine? And the heads?
Regards, Clive
[img]cid:649100620(at)13102010-1658[/img]
-----Original Message-----
Sent: 13 October 2010 21:00
To: 'jabiruengine-list(at)matronics.com'
Subject: RE: Re: Adjusting screw torque
I recall lately there is two torques, one for building the engine and one for checking afterwards.
Regards, Clive
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of 4aplat
Sent: 13 October 2010 18:28
--> <ulm(at)ascenseur-parisien.com>
Hi Clive
thanks in advance
MIcheL
I believe it's 18, 20 and 24 depending on which engine you have (I
maybe wrong about the 18, I only have a 2000 and a 2003 manual here).
Regards, Clive
http://www.nbsp; the Web href="http://forums.matronics.com">http://forums.matronics.com
_p; generous bsp;   href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
 Filesize:  118.23 KB
 Viewed:  25572 Time(s)
checkpoint2(at)comcast.ne
PostPosted: Wed Oct 13, 2010 1:25 pm    Post subject: Adjusting screw torque Reply with quote
That always worked for me. Bob Haas
PostPosted: Wed Oct 13, 2010 10:35 pm    Post subject: Adjusting screw torque Reply with quote
One remark on this. The text mentions not to back off the studs. After working with Roger on my engine and discussing I am convinced that's bad advice.
The bolts go all the way through the head and screw into the cylinder. On my engine, the exposed threads had corrosion on them. This corrosion caused the bolts not to move at 24lbs even though the heads were starting to leak. Do check for corrosion, use WD40 or similar to lubricate the corroded end and back off the stud a little bit. Then retighten at 24lbs/ft (or whatever your vintage manual tells you).
Rob
 Filesize:  118.23 KB
 Viewed:  25563 Time(s)
4aplat
PostPosted: Wed Oct 13, 2010 11:47 pm    Post subject: Re: Adjusting screw torque Reply with quote
It's a 2200 serial #570
I'm not looking for the torque for the cylinder heads but for the valve clearance adjusting screw (and nut)
MicheL
Regards, Clive
Clive J
PostPosted: Thu Oct 14, 2010 1:38 am    Post subject: Adjusting screw torque Reply with quote
For the same reason on older heads where they deform check by backing off and if necessary take the bolts out and clear the hole out with a drill bit.
My old heads on the 2200 twisted badly (#596) and I had trouble getting the head bolts out for this reason.
CJ
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Rob Turk
Sent: 14 October 2010 07:31
Subject: Re: Re: Adjusting screw torque
Rob
 Filesize:  118.23 KB
 Viewed:  25557 Time(s)
Clive J
PostPosted: Thu Oct 14, 2010 1:39 am    Post subject: Adjusting screw torque Reply with quote
Michel, that was the one where we don't have a reading and a suggested
you practised a bit with locking and un locking the screw until you
'felt' it was right.
Ring spanner hand tight.
Good discussion spawned anyhow,
Regards, Clive
wypaul
PostPosted: Sun Oct 17, 2010 6:53 am    Post subject: Re: Adjusting screw torque Reply with quote
If you have tighten all of the adjusters to 24 ft/lb then you should replace all of the adjustment studs and nuts to avoid in flight failure. IMHO
Paul
Paul Spackman
Q-2 Jabiru 3300
Goto page 1, 2  Next
Page 1 of 2
