		tigeryak18t
  Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
				 Posted: Tue Sep 14, 2010 2:17 pm    Post subject: Yak 18T |
				G'day to all,
 I come back with a few questions concerning the Yak 18T and M14P.
 First, I decided to use unleaded 98 as most of my friends yakees.
 Since four full fills it seems to work fine . At least as good as with 100LL.
    Question is would you recommend to put an automotive lead additive in the fuel?????
 Seems that the eastern friends doesn't care about additive.???
 Second question. Does anyone have a 50 hours maintenance programm  for the M14P. If there is some pics for a beginner that would be great. But at least a card.
    Pics of all the fuel filters on the M14P and how to clean them would be so very helpfull....
 Third question, is it possible to purchase a hose for charging the main gear shock absorbers???
 Then last question, I am looking for a preoiling kit. Does anyone has used one and where to buy it???
   Or also a non electrical autonomous warming device for the winter....working with gas or fuel???
 Sorry to bother with so many question.
 By the way I am happy to annouce my first aerobatic flight in my 18T...very smooth and absolutely non painfull for the plane....2g's max.
   So excited!!!!
 best regards and safe flights to all
 Didier BLOUZARD
 didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)
 0624243672
  _________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
		jan.mevis(at)informavia.b Guest
				 Posted: Tue Sep 14, 2010 10:25 pm    Post subject: Yak 18T |
				Hello Didier,
 It will be very difficult to find any lead additive on the market. The existing additives are all without lead. They can be used to get a higher octane number, but as far as I know, they’re all quite toxic (with toluene and benzene compounds) and I have my doubts.
 There’s a group of car-oldtimer guys in the UK who sell TEL in small quantities, but it’s very expensive, and you have to be knowledgeable about it’s use. Too much makes things worse. Then you’d better continue with avgas.
 Call me off list for the other questions if you want.
 BR,
 Jan
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Didier Blouzard
  Sent: woensdag 15 september 2010 12:15
  To: yak-list(at)matronics.com
  Subject: Yak 18T
 G'day to all,
  So excited!!!!
  Didier BLOUZARD
  0624243672   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Yak-List  | 	  0123456789
				 Posted: Wed Sep 15, 2010 8:23 am    Post subject: Yak 18T |
				Hi Jan,
 You took the words out of my mouth.  TEL is very difficult to get "over
 the shelf".
 There have been a lot of interesting articles written lately about
 "Alternative Fuels".  An expert on fuels from Shell Oil wrote a very
 interesting piece about how most people are talking a lot about Octane,
 and are paying very little attention to the other things needed that TEL
 provides in our aircraft engines.
 I am not an aircraft engine expert (as I have said many times).  But
 from my past experience with other types of engines, I can say that the
 first place that you look for damage when running unleaded fuel in an
 engine that was designed for it, is the valve seats.  I would say the
 valves themselves as well, but I *THINK* that the M-14 uses sodium
 filled massive valves.  I've looked at them and that seems to be
 accurate, but I'd like someone else to confirm it.  So, I *SUSPECT* that
 the M-14 valves can withstand running without lead more than some other
 types.
 The interesting fact though is that as long as the octane meets spec, an
 engine can get by with much less lead than is contained in 100LL.  I
 have no doubt in my mind that running a 50/50 mix of unleaded and 100LL
 would keep the valves and seats happy for a LONG time.
 But for what it is worth ... How well an engine "runs" is not a good
 basis to determine whether you can operate an engine a long time without
 leaded fuel when the original design calls for it.  A lot of folks will
 argue and debate that point, and that's just fine.  Folks can do
 whatever they want with equipment they own.  Personally though, I would
 make it a point ... No matter the cost .... To always run some 100LL
 through the engine every couple of tank-fulls.  Sure, running a 50/50
 mix or so would be even better, but that can be cost prohibitive and
 even may not be available in Europe in many locations.  But you can
 actually get by just running some 100LL through the engine once in
 awhile and that will go a LONG way towards preventing the kind of damage
 to the seats that can eventually happen.
 Be aware that some pilots have claimed to have run M-14's hundreds and
 hundreds of hours and the engines are still "just fine".  Good for them.
 I would still advise throwing some leaded fuel in there every so often,
 regardless.
 Mark Bitterlich
				 Posted: Wed Sep 15, 2010 10:35 am    Post subject: Yak 18T |
				Hello Mark,
 I know of M14P's running for hundreds of hours on cargas. At the end, these
 engines were quite "leaky", dripping oil from everywhere, maybe due to the
 ethanol in the cargas, maybe because of maintenance issues, I don't know.
 Nevertheless, they still were operational, consuming somewhat more oil.
 These pilots never mentioned vapour locks, or even carburettor icing. The
 Russian engines are really strong, and apparently designed to run with oils
 and fuels of variable quality.
 Nevertheless, I only feed Avgas 100LL to my engine, and only the best oils
 that I can get.
 There will be a problem in the not so distant future, Avgas 100 LL being
 ruled out (a recent article mentions 2017). But it's of no use, and bad for
 one's health if we start worrying all the time. I'm sure we'll find a
 workaround when it's due.
 All the best,
 Jan
