Cut Exhaust Stacks
RV7ASask
PostPosted: Mon Sep 06, 2010 10:32 am    Post subject: Cut Exhaust Stacks Reply with quote
I marked my Vetterman Exhaust to cut the pipes off parallel to the bottom of the aircraft. That would mean the hole is parallel to the airflow and the pipes would come to a bit of a point. My local mechanic suggested I should leave them as delivered, the hole 90 degrees to the pipe and the airflow. He said there was better thrust/power/drag.
Looking at Larry Vetterman's Skunkworks http://www.vettermanexhaust.com/ he has cut the pipes as I proposed in a couple of his iterations. The one advantage I can immediately see is there is less pipe hanging out to drag plus it looks better.
Can anyone come up with a good reason one way or the other to cut or not to cut?
David Lamb
RV7A
maxhegler(at)msn.com
PostPosted: Mon Sep 06, 2010 12:53 pm    Post subject: Cut Exhaust Stacks Reply with quote
Maybe a little more thrust with the pipes cut off at 90 degrees. Other than that, I would suggest contacting Vetterman and see if they have any pro's and con's either way.
Max
RV-7 (#2)
[quote] Subject: Cut Exhaust Stacks
Date: Mon, 6 Sep 2010 11:32:16 -0700
To: rv7-list(at)matronics.com
--> RV7-List message posted by: "RV7ASask" <rv7alamb(at)sasktel.net>
David Lamb
RV7A
http://forums.matronics.com/viewtopic.php?p=311556#311556
John Myers
PostPosted: Mon Sep 06, 2010 2:06 pm    Post subject: Cut Exhaust Stacks Reply with quote
rvaitor(at)comcast.net
PostPosted: Mon Sep 06, 2010 5:44 pm    Post subject: Cut Exhaust Stacks Reply with quote
RV7ASask
PostPosted: Wed Sep 08, 2010 4:25 am    Post subject: Re: Cut Exhaust Stacks Reply with quote
As someone suggested I contacted Larry Vetterman on the issue of cutting off the exhaust pipes and here is his reply:
"David, your mechanic is correct. I have tried many combinations and none
of them increased performance but some of them increased the vibration
level. So my suggestion is leave them as they are. Larry"
I think I will leave them as they are!
David
