enginerdy(at)gmail.com Guest
Posted: Mon Aug 30, 2010 7:07 pm Post subject: Progressive switch for electric trim |
Bob, list,
I was reading through a thread on Van's Air Force today and it got me thinking about the approaches to elevator trim control. There seemed to be two camps:
People who use (on)-off-(on) type switches who have problems with sensitivity,
and people who have some kind of high/low motor speed switch, either manually controlled or airspeed controlled with a Vertical Power (or similar) module.
| Quote: | From a usability versus complexity standpoint, I was imagining a progressive-speed switch, implemented as a 5-position switch:
(second-up) : fast down trim
(first-up) : slow down trim
center : trim stop
(first-down) : slow up trim
(second-down) : fast up trim
A quick search has not turned up any toggle switches of this kind, which may be the real problem with this approach. Have you seen this approach elsewhere, or have any part number suggestions?
--Daniel
Posted: Tue Aug 31, 2010 4:32 am Post subject: Progressive switch for electric trim |
At 10:05 PM 8/30/2010, you wrote:
Bob, list,
to be two camps:
similar) module.
center : trim stop
I's aware of no COTS (commercial off the shelf)
switch with this characteristic. There have been
lever operated, sping loaded to center, wafer
switches but those go back a lot of years. I
don't think they were a catalog item.
I've spent a significant portion of my career
working on motor driven trim systems for aircraft,
mostly bizjets. I did get to put the first microprocessor
controlled trim system on Roy Lopresti's M30 prototype
at Mooney. This was a proof of concept controller that
adjusted the servo gain scale factor on a servo/anti-servo
tab. The goal was to provide a constant stick-force/G
response irrespective of IAS.
Initial flight tests were encouraging but the M30
program was scrapped for a host of reasons. We've
had a number of discussions about trim systems here
on the List. A search of the aeroelectric.com website
using the words trim and speed will produce a number
of hits. But in particular, may I suggest you review
the article published at:
http://www.aeroelectric.com/articles/Trim_System_Failures.pdf
The "ideal" trim controller would adjust the motor's
speed linearly over the full range of max to minimum
depending on the airplane's IAS value. After
crafting the trim speed controller for the Lear
55, I wrote and delivered a paper at an SAE
convention where I hypothesized a number of
possibilities for future designs. Two features
of the paper talked about a way to control trim
speed from a single processor in a manner that
precludes a runaway in spite of worst case software
failure. The other was a proposal to adjust motor
speed based on the value of pitot pressure (IAS).
Obviously, there's a huge difference between a
performance of a Lear and an RV. A larger difference
exists between the product development budgets
for the two aircraft.
Setting the "ideal" system aside, what operating
characteristics might offer 90 plus percent of
everything we'd like the trim system to do.
An airplane spends MOST of its flight time in
stable flight at max IAS. This configuration
suggests a very slow trim rate that allows
fine tuning of trim for holding altitude.
A small percentage of flight time is spent
in approach to landing where IAS is on the
order of 90-100 kts and some degree of
flaps are deployed. Here the trim speed needs
to be faster to make timely adjustments to
establish the desired IAS.
On the Lears, the high speed trim was 4x faster
than low speed trim.
I've published a suggested schematic for a
two speed trim system for small aircraft
at:
http://www.aeroelectric.com/PPS/Flight/Trim/Two_Speed_Trim_2.pdf
This is modeled after the system flying on
30 series Lears where speed commands come
from a switch on the flap system. With flaps
full up, low speed is commanded. With flaps
extended more than 10 degrees, high speed
is commanded.
I'm confident that a system crafted after
this model will meet design goals for
crafting a very utilitarian pitch trim
system. The neat thing is that speed
selection is automatically controlled by
flight configuration. I could get this
system qualified on a TC aircraft with
a minimum of bureaucratic fuss.
The controller should be fitted with
screwdriver adjusted trim pots for speed
selection. Over a series of flight tests,
you can optimize system performance to
meet your design goals.
marcausman
Posted: Fri Sep 03, 2010 4:15 am Post subject: Re: Progressive switch for electric trim |
Automobiles now have a similar switch for electric windows. Pull (or push) the switch a bit to move the window, then pull (or push) it past a detent to automatically raise or lower the window.
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
