center spar upgrade 6ZU 3-2
chris Sinfield
PostPosted: Tue Aug 31, 2010 3:54 am    Post subject: center spar upgrade 6ZU 3-2 Reply with quote
Hi gang
can someone please shoot me a picture of how this piece sits against the side of the fuselage skin and around the rear spar upright. I am a bit confused .
Does it sit fully next to the skin between the upright at the undercarriage and the rear spar upright
or
Does it go between the skin and upright at the back but at the front section you have side skin/spar upright/ 6zu3-2 and then the bracket 6B10-4 over the lot.
Chris..
the Zenith Aero video was not clear on this and the photo guide shows it going behind both I think..
a photos worth a thousand words
Chris
Zodiac XLB
Sydney
DaveG601XL
PostPosted: Tue Aug 31, 2010 6:33 am    Post subject: Re: center spar upgrade 6ZU 3-2 Reply with quote
Chris,
I installed it per your first assumption. I placed 6ZU3-2 against the skin and under all surrounding uprights and stiffeners. Picture attached.
Good luck,
 Filesize:  120.41 KB
 Viewed:  10760 Time(s)
David Gallagher
Cincinnati, OH area
Afterfxllc(at)aol.com
PostPosted: Tue Aug 31, 2010 7:00 am    Post subject: center spar upgrade 6ZU 3-2 Reply with quote
Hey David did you change your aft uprights also?
Jeff
In a message dated 8/31/2010 10:35:33 A.M. Eastern Daylight Time, david.m.gallagher(at)ge.com writes:
http://forums.matronics.com//files/upgrade_19_113.jpg
DaveG601XL
PostPosted: Tue Aug 31, 2010 7:53 am    Post subject: Re: center spar upgrade 6ZU 3-2 Reply with quote
Jeff,
My aft upright is still the original one.
David Gallagher
Cincinnati, OH area
Ron Lendon
PostPosted: Tue Aug 31, 2010 6:15 pm    Post subject: Re: center spar upgrade 6ZU 3-2 Reply with quote
FWIW, I puzzled over this also and called Caleb at Zenith. Here is a picture of the outcome of that conversation on mykitlog.
http://mykitlog.com/users/display_log.php?user=rlendon&project=780&category=0&log=101653&row=7
I was able to drive the part up from below, the most puzzling part was did the verticle spar get sandwiched or not. Caleb and I agreed that it should be sandwiched.
I noticed Dave made it the other way, and I'm sure it's fine that way also. I just think, and Caleb agreed, the sandwiched joint it makes a stronger junction.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
chris Sinfield
PostPosted: Tue Aug 31, 2010 11:41 pm    Post subject: Re: center spar upgrade 6ZU 3-2 Reply with quote
Thanks Ron and Dave
its a bit clearer now. my only thought was the bulge due thickness of new 3-2,pushing out the side skin of the fuse as you we are still using our existing rear spar upright & bolt holes.
Was this a problem?
on the Zenith builders photos it shows the ZU-3-2 as inside the Spar upright and the spar upright contacting the side skin? go figure..
Chris
DaveG601XL
PostPosted: Wed Sep 01, 2010 6:50 am    Post subject: Re: center spar upgrade 6ZU 3-2 Reply with quote
Chris,
As far as your concern about a bulge in the side skin, each airplane will have it's own best solution. In my case, adding both pieces under the upright seemed to fit better. It can certainly go either way. As far as a sandwiched joint making for a stronger upright, that could be, but I will not lose any sleep over it. A sandwich with 6B10-4 is only a one rivet sandwich. All this talk of sandwiches is making me hungry. Let's fly out for lunch!
Good luck,
David Gallagher
Cincinnati, OH area
Scotsman
PostPosted: Wed Sep 01, 2010 9:50 am    Post subject: Re: center spar upgrade 6ZU 3-2 Reply with quote
I also didn't sandwich the joint. It didn't feel right and like someone said earlier it is only a one rivet sandwich which I sincerely doubt adds much strength.
Cell +27 83 675 0815
ggower_99(at)yahoo.com
PostPosted: Wed Sep 01, 2010 12:42 pm    Post subject: center spar upgrade 6ZU 3-2 Reply with quote
The important thing to have in mind is that has to "make" a reinforced structure, the more area it touches the better...
Gary.
--- On Wed, 9/1/10, chris Sinfield <chris_sinfield(at)yahoo.com.au> wrote:
From: chris Sinfield <chris_sinfield(at)yahoo.com.au>
Subject: Re: center spar upgrade 6ZU 3-2
Date: Wednesday, September 1, 2010, 3:41 AM
--> Zenith601-List message posted by: "chris Sinfield" <[url=/mc/compose?to=chris_sinfield(at)yahoo.com.au]chris_sinfield(at)yahoo.com.au[/url]>
Thanks Ron and Dave
Was this a problem?
Chris
http://forums.matronics.com/vi Photoshare, and much much onics.com/Navigator?Zenith601-List" target="_blank">http://www.matronics.nbsp; -Matt matronics.com/contribution" =======
PostPosted: Thu Sep 02, 2010 4:34 pm    Post subject: center spar upgrade 6ZU 3-2 Reply with quote
Are they 40 or .063? They look like the .040 but hard to tell from the photo.
Jeff
In a message dated 8/31/2010 11:55:34 A.M. Eastern Daylight Time, david.m.gallagher(at)ge.com writes:
--> Zenith601-List message posted by: "DaveG601XL" <david.m.gallagher(at)ge.com>
Jeff,
David Gallagher
601 XL/Jabiru 3300
First flight 7/24/08
Upgraded 3/19/10
150+ hours and climbing!
http://forums.matronics.com/viewtopic.php?p=310821#310821===============================================
_-= Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
