dgilding(at)verizon.net Guest
Posted: Wed Sep 01, 2010 4:20 am Post subject: Attaching floor ribs and baggage ribs |
I am building a RV-6A and was wondering what the easiest way to rivet the floor ribs and baggage ribs. I took the F-604 out of the fixture to coutersink all my holes and prime the attaching brackets and was thinkng maybe it would be easier to rivet the floor ribs on while it is out vs. in the fuselage fixture. Does anyone have any advice?
Dean Gilding
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
bigdog(at)bentwing.com Guest
Posted: Wed Sep 01, 2010 7:19 am Post subject: Attaching floor ribs and baggage ribs |
You should do all the riveting in the jig. The spacing of the front and rear spar carry throughs are critical. You should be paranoid about the spacing because if it's off the wings won't fit and it's game over. That's what the jig is for. The outer floor ribs are curved and you'll only get them right in the jig. I've built 2 slow build fuselages and the paranoia was only slightly less on the second.
Greg Young
[quote] From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of Dean Gilding
Sent: Wednesday, September 01, 2010 7:15 AM
To: rv6-list(at)matronics.com
Subject: Attaching floor ribs and baggage ribs
Dean Gilding
Smcm75(at)aol.com Guest
Posted: Wed Sep 01, 2010 8:27 am Post subject: Attaching floor ribs and baggage ribs |
In a message dated 9/1/2010 11:21:03 A.M. Eastern Daylight Time, bigdog(at)bentwing.com writes:
Quote: | You should do all the riveting in the jig. The spacing of the front and rear spar carry throughs are critical. You should be paranoid about the spacing because if it's off the wings won't fit and it's game over. That's what the jig is for. The outer floor ribs are curved and you'll only get them right in the jig. I've built 2 slow build fuselages and the paranoia was only slightly less on the second.
You also might try my way of keeping the floor ribs in alignment to drill by cutting 1"dia pieces of wood doweling and placing them between the ribs at a 90 deg. angle to align the ribs. Then tie a piece of string to each piece of wood and lead it through the fuselage skin holes behind the front spar. After you drill and rivet the floor ribs you can pull on the strings and remove the dowel sections.
Scott Morrow
RV-6A N548SM
