tdawson-townsend(at)auror Guest
Posted: Thu Aug 26, 2010 11:03 am Post subject: Diamond Doors from AvWeb |
FAA RESPONDS TO DIAMOND DOOR DEPARTURES
Responding to "several reports of the rear passenger door departing the airplane in flight" the FAA Wednesday published proposed rules for owners of certain Diamond aircraft models. "Several reports" appears to translate to 31, according to the FAA, and affected models are DA40 and DA40F airplanes. The FAA is proposing to change the models' "emergency open doors procedure" via temporary revision to the aircrafts' flight manuals and apply an "improved design" to an open door retention mechanism on some aircraft. The physical change required for door retaining brackets would affect 428 airplanes in the U.S. registry at an estimated cost of $245 per aircraft. But that change does not affect the door locking mechanism, itself, which Diamond says appears to be fine ... so long as pilots actually close the door. More...
Tim Dawson-Townsend
RV-10 40025
APRS KB1URG
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
57.07 KB |
1311 Time(s) |
