TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXI
kevino(at)worldwarehouse.
PostPosted: Fri Aug 27, 2010 7:12 am    Post subject: TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXI Reply with quote
Sent from my iPad
amekler(at)metrocast.net
PostPosted: Fri Aug 27, 2010 7:51 am    Post subject: TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXI Reply with quote
Kevin,
No message came through. Tried the coke bottle test today without injectors -cylinders 1, 2, 3, 4, and 6 equal. cylinder 5 less!
I guess next step will be to call Precesion(Mattituck)/
Alan BODY { font-family:Arial, Helvetica, sans-serif;font-size:12px; }
On Fri 08/27/10 11:10 AM , "Kevin O'Shea" kevino(at)worldwarehouse.com sent:
Sent from my iPad
=_blank>http://www.matronics.com/Navigator?RV10-List
le="COLOR: #ff0000">http://forums.matronics.com
>http://www.matronics.com/contribution
Tim Olson
PostPosted: Fri Aug 27, 2010 9:12 am    Post subject: TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXI Reply with quote
Or very carefully disassemble the spider and find out where it's
plugged, or if it's the line for #5. The flow divider and
lines are now the only real possible area for the issue to
be....the servo just pumps fuel up to it, and it's up to
the divider to put out the equal volumes to the cylinders.
Tim Olson - RV-10 N104CD
On 8/27/2010 10:44 AM, amekler(at)metrocast.net wrote:
Kevin,
Alan
*On Fri 08/27/10 11:10 AM , "Kevin O'Shea" kevino(at)worldwarehouse.com sent:
<kevino(at)worldwarehouse.com <mailto:kevino(at)worldwarehouse.com>>
Sent from my iPad
PostPosted: Fri Aug 27, 2010 9:39 am    Post subject: TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXI Reply with quote
Tim,
Checked the line. Nothing found. Waiting to hear back from Mattituck.
Alan
On 8/27/2010 10:44 AM, [url=javascript:top.opencompose(\'amekler(at)metrocast.net\',\'\',\'\',\'1\')]amekler(at)metrocast.net[/url] wrote:
> Kevin,
> Alan
> *On Fri 08/27/10 11:10 AM , "Kevin O'Shea" [url=javascript:top.opencompose(\'kevino(at)worldwarehouse.com\',\'\',\'\',\'1\')]kevino(at)worldwarehouse.com[/url] sent:
> > <kevino(at)worldwarehouse.com <[url=javascript:top.opencompose(\'kevino(at)worldwarehouse.com\',\'\',\'\',\'1\')]kevino(at)worldwarehouse.com[/url]>>
> Sent from my iPad
tp%3A%2F%2Fwww.matronics.com%2FNavigator%3FRV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-List
tp%3A%2F%2Fforums.matronics.com" target=_blank>http://forums.matronics.com
tp%3A%2F%2Fwww.matronics.com%2Fcontribution" target=_blank>http://www.matronics.com/contribution
avu1(at)md.metrocast.net
PostPosted: Fri Aug 27, 2010 5:24 pm    Post subject: TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXI Reply with quote
I had a similar problem on cylinder #2. I flushed the spider numerous times with no joy. I finally took the spider off of the engine and flushed it upside down over a white cloth. That fixed it. I never saw what clogged the port.Anh 40141-flying
Sent from my Verizon Wireless BlackBerryFrom: amekler(at)metrocast.net
Sender: owner-rv10-list-server(at)matronics.com
Date: Fri, 27 Aug 2010 13:36:41 -0400
ReplyTo: rv10-list(at)matronics.com
Subject: Re: RV10-List: TMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectorsTMXIO-540 and GAMI injectors
Tim,
Alan
[quote]--> RV10-List message= posted by: Tim Olson <[url=javascript:top.opencompose(\'Tim(at)myrv10= .com\',\'\',\'\',\'1\')]Tim(at)myrv10.com[/url]>
On 8/27/2010 10:44 AM, [url=javascript:top.opencompose(\'amekler(at)metro= cast.net\',\'\',\'\',\'1\')]amekler(at)metrocast.net[/url] wrote:
> Kevin,
> No message came through. Tried the coke= bottle test today without
> injectors -cylinders 1, 2, 3, 4, and 6 = equal. cylinder 5 less!
> I guess next step will be to call Prece= sion(Mattituck)/
> Alan
> *On Fri 08/27/10 11:10 AM , "Kevin O'Sh= ea" [url=javascript:top.opencompose(\'kevino(at)worldwarehouse.com\',\'\',\'\'= ,\'1\')]kevino(at)worldwarehouse.com[/url] sent:
> O'Shea"
> <kevino(at)worldwarehouse.com <ke= vino(at)worldwarehouse.com>>
> Sent from my iPad
> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
> =3D_blank>[url=http://metromai= l.metrocast.net/parse.php?redirect=3Dhttp%3A%2F%2Fwww.matronics.com%2FNavig= ator%3FRV10-List]http://www= .matronics.com/Navigator?RV10-List[/url]
> le=3D"COLOR: #ff0000">[url=htt= p://metromail.metrocast.net/parse.php?redirect=3Dhttp%3A%2F%2Fforums.matron= ics.com]http://forums.matro= nics.com[/url]
> >[url=http://metromail.metroca= st.net/parse.php?redirect=3Dhttp%3A%2F%2Fwww.matronics.com%2Fcontribution]http://www.matronics.com/con= tribution[/url]
tp%3A%2F%2Fwww.matronics.com%2FNavigator%3FRV10-List" target=3D_blank>http://www.matronics.com/Navigator?RV10-List
tp%3A%2F%2Fforums.matronics.com" target=3D_blank>http://forums.matronics.com
tp%3A%2F%2Fwww.matronics.com%2Fcontribution" target=3D_blank>http://www.matronics.com/contribution
