frank.goodnight(at)att.ne Guest
Posted: Sun Aug 22, 2010 6:09 am Post subject: Fuel tank |
Hi All,
Any one out there had any sucess welding up a fuel tank ( .050 5052h3 alum ) with gas --ox acetlene?.. I am a pretty fair
welder but have never tryed to gas weld alum. Would it be better to just go to a comercial shop and pay the 100 bucks or so ?
Any thoughts would be helpful.
Frank
[img]cid:1282485665259(at)dclient.mail.yahoo.com[/img]
9.63 KB |
4838 Time(s) |
Posted: Sun Aug 22, 2010 6:47 am Post subject: Fuel tank |
_________________ John Hauck
Titus, Alabama |
Posted: Sun Aug 22, 2010 6:54 am Post subject: fuel tank |
Gang:
This is a resend of the original.
Wonder if Frank G could remove the attachment (character in the lower right
of his emails) when he sends stuff to the Kolb List. My server and
Matronics are having a problem living with that particular attachment.
Frank:
Let a pro do it for you. There is probably a shop in Brownsville that
specializes in marine fuel tanks. It is very difficult to weld up a good
aluminum tank that will not have pin holes, even with a good welder and a
TIG outfit.
I also slosh seal my tanks. If there is a tiny pin hole in there somewhere,
sloshing will insure that it is sealed. I tiny pin hole can drive you nuts
with its constant seep/ooze and the smell of gasoline in the cockpit.
In addition, I slosh seal antique tractor fuel tanks, the last was 74 years
old. They will leak at their soldered seams, and nearly always have rusted
through on the bottom where moisture collects.
Of strict importance is to insure the slosh sealer is compatible with auto
gas/alcohol and av gas.
Titus, Alabama |
Posted: Sun Aug 22, 2010 7:43 am Post subject: Fuel tank |
I have attempted gas welding aluminum with unfavorable results. There are special alloy rods available that have lower meltbut the joint will have poor strength. Maybe if you had good clean lapped joints you could flow it in somewhat like soldering.
Try some on scrap for an entertaining experience. The aluminum will rapidly form an oxide skin from which the liquid beneath
will flow out like water. -leaving a giant hole. Better go TIG and an experienced welder.
I am lucky and have such a neighbor who did my aluminum intake manifold.
BB
dormant MkIII, suzuki
On 22, Aug 2010, at 10:09 AM, frank goodnight wrote:
[quote]Hi All,
Frank
<--static--liam_party_bottomright.jpg>
rickofudall
Posted: Sun Aug 22, 2010 7:47 am Post subject: Fuel tank |
Gas welding aluminum generally goes like this, for me anyway. Scrub, scrub, scrub with stainless steel wire brush to remove oxide layer.
Apply flux
Heat with carbonizing flame until surface has a milky look
Aluminum falls away revealing big hole that was solid just moments ago.
With luck the molten aluminum did not fall on your foot.
Swear prolifically, even if molten blob misses your foot, scream loudly if it hits the bullseye.
Repeat until stupid with rage and heave project as far as you can throw it.
Mumble and be grouchy the rest of the day.
Best stay away from the wife and other civilized people until calm.
The TIG welder is far cheaper in dollars and sanity.
Just MHO.
Rick
On Sun, Aug 22, 2010 at 9:09 AM, frank goodnight <frank.goodnight(at)att.net (frank.goodnight(at)att.net)> wrote:
| Quote: | Hi All,
Frank
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
It is not bigotry to be certain we are right; but it is bigotry to be unable to imagine how we might possibly have gone wrong.
- G.K. Chesterton
9.63 KB |
4837 Time(s) |
by0ung(at)brigham.net Guest
Posted: Sun Aug 22, 2010 9:48 am Post subject: Fuel tank |
Frank i have never seen anyone weld alum sucessfully with a torch, usually done with a mig or tig with a square wave variable power output. takes a lot of practice to melt the alum, without droping out a big hole. the aluminum has no tel tel signs that it is about to drop on your foot. if you try a torch,,,, best to find a special alloy rod. (lower melting point. less stregnth)
boyd young
Hi All,
Frank
Dana
Posted: Sun Aug 22, 2010 10:46 am Post subject: Fuel tank |
It _is_ possible to gas weld aluminum, but you've got to be _really_
good. There are so-called "aluminum welding rods" which are in fact
brazing rods (the base metal doesn't melt), but I wouldn't trust them
for a fuel tank.
I went with a guy who's in the business of making fuel tanks.
-Dana
frank goodnight <frank.goodnight(at)att.net> wrote:
(08/22/2010 10:09)
| Quote: | Hi All,
Frank
Posted: Sun Aug 22, 2010 10:58 am Post subject: Fuel tank |
Thanks to all of you that answeered my request for info. I will go with a pro welder tig , mig or heliarc. thanks
again.
Frank
Sent: Sun, August 22, 2010 1:53:19 PM
Subject: Re: Kolb-List: Fuel tank
--> Kolb-List message posted by: Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
for a fuel tank.
-Dana
(08/22/2010 10:09)
| Quote: | Hi All,
Any thoughts would bsp; -Matt Dralle, ===========
aoldman(at)xtra.co.nz Guest
Posted: Sun Aug 22, 2010 11:58 pm Post subject: Fuel tank |
I have welded a fair bit of alum with ox- acetylene , some as thin as your tank but I would not be keen on welding a fuel tank this way. You need to clean all the oxidization off the aly before starting to weld it .I think on a tank you may have difficulty with blowing holes ,well I know I would . You may also find that eventually you will get a leak along side your weld . This would depend on stress /vibration .You do loose strength in the area where the weld bonds with the base metal . If it was mine I would look at welding the problem area using argon shield then putting a patch over the weld .
I may be wrong with this advise as most of the welding of alum I have done has been boat props and window frames. If you have a good handle on the oxy - acetylene why not get a couple of bits of alum the thickness of your tank and give it a go . I have always had best results by using a unfluxed rod and used a separate flux. From memory its a liquid air flux. Polish both the rod and area to be welded with wire wool first and weld as soon as possible after that . There is a very short time between the base metal { puddling } being ready to weld and slumping away. I have welded a boat prop on the side of the lake using a propane torch and some old alum as a fill simply by polishing { filing } first then not using any flux . Don't know how long it lasted but the boat it was on disappeared off into the distance.What I am trying to say is that yes you can weld this material with oxy - acetylene ,you just need some practice .But a fuel tank ?
Please note I am not a welder by trade, I have held a marine welding certificate for electric welding and completed a gas welding course many years ago. There will be others on this list who may have better advise.
Downunder
MK111c
ceengland(at)bellsouth.ne Guest
Posted: Mon Aug 23, 2010 1:09 pm Post subject: fuel tank |
Another option, if you haven't already cut metal, is to rivet them.
It's not difficult (it can even be done with 'pop' rivets) & then seal
the tank with 'pro-seal' type fuel sealant (multiple brands available),
or slosh the tank with some of John's tractor slosh.
If this option interests you, I can give you some more info on how to do
it. For me, at least, it's *much* easier than trying to weld aluminum.
Charlie
| Quote: | Frank:
TIG outfit.
elleryweld(at)aol.com Guest
Posted: Mon Aug 23, 2010 8:13 pm Post subject: Fuel tank |
Do not use wire wool unless it is made of stainless steel or it will contaminate your area to be welded
I have been a welder by trade most of my life the way I would attack that fuel tank is with a welding machine that has High Freq and a tig torch with Argon Shielding gas for a good strong good looking weld
Ellery Batchelder Jr.
rickofudall
Posted: Mon Aug 23, 2010 8:43 pm Post subject: fuel tank |
Dang, should have been OR welding.
Rick
On Mon, Aug 23, 2010 at 9:07 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
| Quote: | As long as we're talking alternatives, use composites and slosh the inside. Far easier than riveting of welding.
Rick Girard
On Mon, Aug 23, 2010 at 4:09 PM, Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)> wrote:
| Quote: | --> Kolb-List message posted by: Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)>
Another option, if you haven't already cut metal, is to rivet them. It's not difficult (it can even be done with 'pop' rivets) & then seal the tank with 'pro-seal' type fuel sealant (multiple brands available), or slosh the tank with some of John's tractor slosh.
If this option interests you, I can give you some more info on how to do it. For me, at least, it's *much* easier than trying to weld aluminum.
Charlie
| Quote: | Frank:
TIG outfit.
http://forums.matronics.com
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
rickofudall
Rick Girard
Charlie
| Quote: | Frank:
TIG outfit.
le, List Admin.
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
- G.K. Chesterton
