using the Stewarts system
gajindra(at)sbcglobal.net
PostPosted: Tue Aug 17, 2010 8:09 pm    Post subject: using the Stewarts system Reply with quote
I am using Stewarts water bourne system to cover my mark 111c .I bought a Kolb kit that had been started and the fellow quit on it.Stewarts is faa approved and has no toxic fumes,also been around awhile.Glues will stay tacky and the cloth easy to work with and moved around till glue is recoated over seams or joints.Moved the plane into our house after New Years to do the covering.Double doors on front of house.Attached is a couple pics.Also did uv protection in the livingroom.Cost may be little higher but no toxic fumes to inhale or handle.The furnace never had to be turned off.No fumes!
Gary Jindra
Mark 111c
582 E-box
building
 Filesize:  679.22 KB
 Viewed:  3708 Time(s)
 Filesize:  2.15 MB
rickofudall
PostPosted: Wed Aug 18, 2010 1:01 am    Post subject: using the Stewarts system Reply with quote
Beautiful work, Gary. If you don't mind a suggestion from a 582 powered Mk IIIC owner/flyer, put in a one piece larger fuel tank now, if you can. 10 gallons is barely two hours of flight time with no reserve. It really puts a damper on leaving the pattern to enjoy your airplane. I'm sure Hauck will validate this view point. I know it's on my list for this winter when I recover the fuselage of mine. None of my business, but does "into our house" imply a spouse? If so, you are one lucky man. :-}
Rick Girard
Zulu Delta
Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
On Tue, Aug 17, 2010 at 11:06 PM, GARY JINDRA <gajindra(at)sbcglobal.net (gajindra(at)sbcglobal.net)> wrote:
[quote]I am using Stewarts water bourne system to cover my mark 111c .I bought a Kolb  kit that had been started and the fellow quit on it.Stewarts is faa approved and has no toxic fumes,also been around awhile.Glues will stay tacky and the cloth easy to work with and moved around till glue is recoated over seams or joints.Moved the plane into our house after New Years to do the covering.Double doors on front of house.Attached is a couple pics.Also did uv protection in the livingroom.Cost may be little higher but no toxic fumes to inhale or handle.The furnace never had to be turned off.No fumes!
Gary Jindra
Mark 111c
582 E-box
building
PostPosted: Wed Aug 18, 2010 8:27 am    Post subject: using the Stewarts system Reply with quote
Thanks Rick,I have put Kolbs 6 gallon tanks in the plane.By raising the roof line in the back and putting a removable lexan window I can change out the tanks if need be.It also gave some storagebehind the tanks on an aluminum shelf across the upper tank framing that extends to the back.And yes there is a wife and she has been a great help and supporter of the project.
Gary Jindra
Mark 111c
582 e-box building
--- OMn Wed, 8/18/10, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Subject: Re: using the Stewarts system
Date: Wednesday, August 18, 2010, 5:01 AM
Rick Girard
Zulu Delta
Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
Gary Jindra
Mark 111c
582 E-box
building
=nofollow target=_blank>http://www.matronics.com/Navigator?Kolb-List
rickofudall
PostPosted: Wed Aug 18, 2010 3:42 pm    Post subject: using the Stewarts system Reply with quote
Gary, Send her flowers often, she's a real keeper. :-} Where are you located? I keep hoping I'll find a fellow Kolber in Kansas, it's lonely here in the Air Capitol.
Rick
On Wed, Aug 18, 2010 at 11:19 AM, GARY JINDRA <gajindra(at)sbcglobal.net (gajindra(at)sbcglobal.net)> wrote:
Gary Jindra
Mark 111c
582 e-box building
--- OMn Wed, 8/18/10, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
From: Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)>
Subject: Re: Kolb-List: using the Stewarts system
Rick Girard
Zulu Delta
Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
On Tue, Aug 17, 2010 at 11:06 PM, GARY JINDRA <gajindra(at)sbcglobal.net> wrote:
Gary Jindra
Mark 111c
582 E-box
building
Zulu Delta
Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
PostPosted: Wed Aug 18, 2010 5:01 pm    Post subject: using the Stewarts system Reply with quote
Rick I will be flying out of Mayfield airport 1D4 in Akron,Ohio same as Gary Aman does in
the summer
Gary Jindra
Mark 111c
582 e-box
building
Zulu Delta
Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
rickofudall
PostPosted: Wed Aug 18, 2010 6:43 pm    Post subject: using the Stewarts system Reply with quote
Any lurkers out there located on the Great Plains? Someone west of the Missouri River must own and fly a Kolb.
Rick
On Wed, Aug 18, 2010 at 8:00 PM, GARY JINDRA <gajindra(at)sbcglobal.net (gajindra(at)sbcglobal.net)> wrote:
the summer
Gary Jindra
Mark 111c
582 e-box
building
Zulu Delta
Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
Zulu Delta
Kolb Mk IIIC
582 Gray head
4.00 C gearbox
3 blade WD
Thanks, Homer GBYM
