Blumax008(at)aol.com Guest
Posted: Fri Aug 13, 2010 1:13 pm Post subject: Do I follow the 100 hr or Annual Condition Inspection ... |
OR...YOU CAN DO LIKE I DO...OWN 3 ILLEGAL ULTRALIGHTS, DON'T REGISTER THEM AND TELL THE FAA AND ALL THE REST TO GO (it begins with an F) THEMSELVES. I'M 62 YEARS OLD, HAVE AN FAA ATP LICENSE AND AM ABSOLUTELY SICK OF ALL THE (it begins with a B). THEY HAVE WORN MY ASS OUT OVER THE PAST 40 (it begins with an F) YEARS AND I TRULY FEEL SORRY FOR ALL YOU YOUNG WHIPPERSNAPPERS AND ALL THE REST OF THE SHEEP OUT THERE WHO THINK THEY HAVE TO DO EVERYTHING THAT DADDY SAYS. WHO WILL HAVE TO LIVE WITH THEIR (FAA) (it begins with a B) FOR THE REST OF YOUR LIVES. YOU HAVE MY SYMPATHIES.
In a message dated 8/13/2010 4:13:29 P.M. Eastern Daylight Time, ssadiver1(at)yahoo.com writes:
Quote: | --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com>
Hi All,
Many have ask and many more are confused about the time tables for inspections. Do you follow the 100 hr. time table set by the engine and aircraft Mfg or do I follow the FAA and Mfg Annual condition Inspection time table?
The simple answer is both and neither. You may say not so fast here pal, but here is the straight scoop from all authoritative entities.
First the FAA doesn't care how often the Annual is rest so long as it is addressed and done. Flight Design and Rotax have both 100 hr. and Annual inspections. They don't care so long as they are done and addressed and both the annual and the 100 can be done at any time and the time table for each can be reset.
So what does this mean for me and you? If you only fly 50 hours a year then you will be doing the Annual Condition Inspection most of the time. An example is: you have 50 hours on the plane in one year and the Annual is due. So the Annual and 100 hr inspection is the same. You do the Annual and sign off in the log that both have been addressed. Your next Annual is 12 months from then and the next 100 hr. is at 150 hrs. If the Annual comes around again at let's say 110 hrs then you will do the annual and also address the 100 hr inspection. Now the Annual is again in 12 months and the 100 hr. is due at 210 hrs. and so on. So if you are a low time pilot (less than 100 hrs a year) then you will do more Annual condition time table inspections.
What if you are a 100+ hr a year pilot. Let's say you fly 175 hrs or 225 hrs a a year. Then you will be doing more 100 hr time table inspections and addressing and resetting the Annual time table. So lets say your first year you put on 100 hrs. before the annual was due. Now you do the 100 hr. inspection and reset the Annual which then would come due in 12 months from that date. Now you put on another 100 hr. before the annual is due again. You will do the 100 hr. inspection and reset the annual again for 12 months down the line.
This type of schedule give pilots some flexibility for inspection times. You must make sure you write in the logbook that you have done both or you may be doing two inspections separate from each other.
I know it is clear as mud, but that's it in a nut shell.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=308706#308706===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Fri Aug 13, 2010 1:28 pm Post subject: Do I follow the 100 hr or Annual Condition Inspection ... |
Are you planning on firing the escape slide and jumping in?
-- Craig
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Blumax008(at)aol.com
Sent: Friday, August 13, 2010 2:13 PM
Subject: Re: Do I follow the 100 hr or Annual Condition Inspection ..
Hi All,
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=308706#308706=nbsp; = Use utilities Day ======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
Posted: Fri Aug 13, 2010 1:37 pm Post subject: Do I follow the 100 hr or Annual Condition Inspection ... |
In a message dated 8/13/2010 5:28:42 P.M. Eastern Daylight Time, craig(at)craigandjean.com writes:
Quote: | Are you planning on firing the escape slide and jumping in?
Hell, I might be like the folks you see on the news, just get fed up & get ta' blastin'!
Thanks for allowing me to blast off. It keeps me from having to do the above.
BUT MAN WHAT ARE THEY GOING TO COME UP WITH NEXT?
Where's 100LL going? And now we've got Ethanol to deal with.
Just heard yesterday some stupid, lame brained politician (is there any other type?) is trying to make a new TCAS-like instrument mandatory for all general aviation aircraft (and maybe LSAs too)...at "only" $10 to $12,000 per aircraft! How neat! I mean what the hell ever happened to pilots who could actually think & look to avoid for themselves? Good God!
Dick Maddux
Posted: Sat Aug 14, 2010 6:34 am Post subject: Do I follow the 100 hr or Annual Condition Inspection ... |
with
AAAhhh now you are my new hero Bluemax ! (prior was slide blowing flight attendent...hmmm that didn't sound quite right) ... That is precisely the reason why I let my medical expire. I too am tired of the BS. I do however stay current with my condition inspections,biannual reviews etc just in case I crunch the airplane and find myself getting sued by land owner,loosing my license,no coverage on busted aircraft,etc. I am comfortable with that.
BAAAAHHHHHH (sheep sound)
Dick Maddux
Milton,Fl
