Warp Prop Blade Angle Setting
capt_riney(at)yahoo.com
PostPosted: Mon Aug 09, 2010 9:24 am    Post subject: Warp Prop Blade Angle Setting Reply with quote
Getting ready to fireup my Rotax 582 for the first time. I've got a 66", 3-blade warp prop with a 2.62 C-box. For those of you with similar props, what blade angle should I set at the tip before first fire-up to ensure I don't overspeed the engine? Thanks.
Mark Rinehart
Mark III Classic
tclongo(at)att.net
PostPosted: Mon Aug 09, 2010 10:50 am    Post subject: Warp Prop Blade Angle Setting Reply with quote
9.5 Deg
winmail.dat
 Filename:  winmail.dat
 Filesize:  2.64 KB
 Downloaded:  292 Time(s)
PostPosted: Mon Aug 09, 2010 11:10 am    Post subject: Warp Prop Blade Angle Setting Reply with quote
Mark Rinehart
Mark III Classic
Mark R/Gang:
The throttle lever is also handy to prevent engine over speed.
elleryweld(at)aol.com
PostPosted: Mon Aug 09, 2010 3:08 pm    Post subject: Warp Prop Blade Angle Setting Reply with quote
I am running the same engine and Prop I set my Prop at 9 Degrees and it worked out great for me
MK3C
N213
582 Blue head E Box 66"Warp Drive
Ellery Batchelder Jr.
