Two settings for wing Angle of Incidence.
gotime242
PostPosted: Sun Aug 08, 2010 9:54 am    Post subject: Two settings for wing Angle of Incidence. Reply with quote
Hello all,
I'm pretty new to the kolb. I have a firestar II that i have flown twice so far.
It has two holes for the main wing spar, i have been flyng on the lower one, so it has a higher angle of incidence.
How would the airplane handle with the lower angle of incidence setting? I understand the aerodynamics of it, but i would like to hear from kolb specific flyers.
So far i am still getting use to having to come in and land this thing with no flare and its interesting way of losing elevator authority at slow speeds while trying to land. (For now im just landing with a little power).
With the other setting (lower angle of incidence)....how does it land? How does it cruise? Stall characteristics?
Thanks!!
donaho1(at)verizon.net
PostPosted: Sun Aug 08, 2010 12:41 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
If I remember correctly, the plans only call for one hole in the
middle of the tab. If your`s has two holes they either changed the
plans or it was a builder modification. I don`t know how changing to
the other hole will change the way it flies. Also my guess is, not
many of the FSII`s have two holes. I could be wrong, so this
information is worth what you paid for it. Lanny FSII N598LF
rickofudall
PostPosted: Sun Aug 08, 2010 2:12 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
This is one that needs to be talked over with Travis and the guys at the factory, IMHO.Assuming you would get a similar effect that the Mark IIIX gets, lowering the angle of incidence will raise the nose of the fuselage. The wing has to fly at a given angle to produce lift based on airspeed so the only thing that can change is the angle of the fuselage.
Rick Girard
On Sun, Aug 8, 2010 at 3:40 PM, Lanny Fetterman <donaho1(at)verizon.net (donaho1(at)verizon.net)> wrote:
[quote] --> Kolb-List message posted by: Lanny Fetterman <donaho1(at)verizon.net (donaho1(at)verizon.net)>
If I remember correctly, the plans only call for one hole in the middle of the tab. If your`s has two holes they either changed the plans or it was a builder modification. I don`t know how changing to the other hole will change the way it flies. Also my guess is, not many of the FSII`s have two holes. I could be wrong, so this information is worth what you paid for it. Lanny FSII  N598LF
http://forums.matronics.com
le, List Admin.
Eugene Zimmerman
PostPosted: Sun Aug 08, 2010 5:18 pm    Post subject: Re: Two settings for wing Angle of Incidence. Reply with quote
The lower wing incidence will make the tailwheel hit the runway even sooner when landing making a flare even more impossible.
gotime242
PostPosted: Sun Aug 08, 2010 5:31 pm    Post subject: Re: Two settings for wing Angle of Incidence. Reply with quote
Hmm...kind of worries me now. The kit was built in 1996/97 if that makes any difference (if it was diff then).
I really hope it wasnt just a modification Sad
Eugene does your kolb have these two holes?
Does anyone else have two holes? Ill have to check the plans tomorrow...
Eugene Zimmerman
PostPosted: Sun Aug 08, 2010 6:21 pm    Post subject: Re: Two settings for wing Angle of Incidence. Reply with quote
I believe any hole that is there was put there by the builder or a subsequent owner modifier.
I may be wrong but It is my opinion that Kolb did not drill any wing attach holes for the wing spar attach points. At least that was the case on all the kolb planes I built.
PostPosted: Sun Aug 08, 2010 6:41 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
Gene/Folks:
One of the first things I noticed first time I flew Sling Shot was the
exagerated tail low attitude of the SS at slow speeds caused by much less
wing incidence than I was familiar with in the other model Kolbs.
Pull on the flaperons and it leveled up pretty good.
mkIII - Learning to walk before I can fly again. Wink
PostPosted: Sun Aug 08, 2010 6:47 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
gotime242/Folks:
Sounds like your builder made a mistake when he originally rigged the wings,
then went back and corrected it, or....he was experimenting with less wing
incidence to see the difference in flight characteristics and performance.
Just a big ole guess.
gotime242
PostPosted: Sun Aug 08, 2010 6:58 pm    Post subject: Re: Two settings for wing Angle of Incidence. Reply with quote
Crap. Wish i never asked now, because thats a little unsettling. Oh well....it still flies well.
Here is a pic:
Wing spar, two holes.
 Filesize:  36.7 KB
 Viewed:  8839 Time(s)
williamtsullivan(at)att.n
PostPosted: Sun Aug 08, 2010 8:30 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
One of my sets of wings for the Firestar had three holes to set incidence. I asked about it, and somebody said to use the center hole, but the others could be used without any problem. Just a matter of fine tuning, I guess.
    Bill Sullivan
    Windsor Locks, Ct.
    FS 447
rickofudall
PostPosted: Sun Aug 08, 2010 9:55 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
I'd say the original builder screwed up when he drilled the upper hole and corrected it. Both my Mk III and my Firestar are drilled in approximately the same as the lower hole. It's your experiment, but I'd leave it where you have it if it was me. As Beauford says, "Worth what ye paid for it".
Rick Girard
On Sun, Aug 8, 2010 at 9:58 PM, gotime242 <dylanshine(at)gmail.com (dylanshine(at)gmail.com)> wrote:
[quote] --> Kolb-List message posted by: "gotime242" <dylanshine(at)gmail.com (dylanshine(at)gmail.com)>
Here is a pic:
http://forums.matronics.com/viewtopic.php?p=308005#308005
http://forums.matronics.com//files/dscf0145_155.jpg
le, List Admin.
Eugene Zimmerman
PostPosted: Mon Aug 09, 2010 5:22 pm    Post subject: Two settings for wing Angle of Incidence. Reply with quote
242,
In the picture, the hole that has the pin looks to me like it is in
the normal plans built position.
I'd guess someone tried to improve on Homer, and discovered Homer knew
what he was doing.
Gene,
Here is a pic:
