| Okanogan Lew
				|  Posted: Wed Jul 28, 2010 3:12 pm    Post subject: CJ 6 Hot Starts |   |
				| Hey Guys, the latest in the on going saga.  I checked the points in "the shower of sparks" unit & they were pitted & when activated showed a yellow spark & a crackling sound.  I spoke with Doug Sapp & he had a new set off of a defective sparks unit.  I installed those, wiping off the oil mist on the inside of my unit.  Also, the end of the electro-magnetic that pulls the bottom points down, had a coating of surface rust that I removed with fine sandpaper.  I used the gap that was pr-set on the new unit.  This I measured with a dial caliper from the top of the adjustment screw(where the slot is) to the bottom of the  brace it screws into & the distance was .439 thousands.  When activated this time, I got a bright blue spark & a loud snap.  Much much stronger.  Today I parked the CJ out in the sun for about 3 hours at 85 degrees, primed it three times without pulling the blades thru & it wouldn't start.  I gave it two more primes & it fired, but didn't start.  Two more primes got it started & running OK.  So, I think my problem was a weak spark from the starting ignition coil.  Thanks to all for your help.
 ps Doug says he can't get any more points sets for the shower of sparks unit
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
