				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| philgower(at)rappsystems. Guest
				|  Posted: Wed Jul 28, 2010 1:02 am    Post subject: M14P cold starting |   |
				| Hello, following on from my inability to get the  engine started on my Yak18t recently in outback Australia where I was confronted  by extremely cold overnight temperatures, I have done some research into the  problem and if interested you can read about it by clicking on the link below.
 To get a final working procedure I left my aircraft  out overnight and left it to  'soak' in the low overnight temperatures  we have had recently here in Toowoomba.
 http://rappsystemscomau.melbourneitwebsites.com/auth/main/sb/preview/stage/files/starting_the_m14p_from_cold.pdf
 Cheers, Phil (Gent from Australia - for  Mark).
 p.s. Next write up I am intending to do on the  'shower of sparks' with hopefully meaningful test data to go with  it.
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| psb777
				|  Posted: Wed Jul 28, 2010 9:08 am    Post subject: Re: M14P cold starting |   |
				| Phil, if the crankshaft is turned 720 degrees every piston has gone through each of the 4 cycles of a 4-stroke engine.  OK, in various orders, so double it, if you really must.  1440 degrees, or 4 full rotations of the crankshaft.  How many (2-bladed prop) propeller blades is that?  4 * .6 = 2.4 prob rotations or 4.8 blades.  Call it five. In what way have you improved the priming of the engine past the fifth blade?  I wouldn't bother pulling 16 blades for priming, as you suggest in your notes, as all that fuel-air mixture blown out the exhaust valves cannot help do anything but start an (external to the engine) engine fire.
 Paul Beardsell
 G-PYAK http://beardsell.com/flying/g-pyak
 Yak-18T http://beardsell.com/flying/yak18t
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
