talew(at)bellsouth.net Guest
Posted: Mon Jul 26, 2010 5:55 pm Post subject: hot start |
Mark,
I am sure that there was a factory gap that produced a robust ignition spark
when this " shower of sparks" was a new part .
That said , I am not going to instruct a person with your background on
the deviation of such old parts and how that now that
may be a mismatch with the original factory gap specs .
I found that if I activated the "shower of sparks" and during this time adjusted
the gap I was able to visually achieve a spark that was much brighter than
what I started with .
This dramatically improved my warm weather start problem .
Not very scientific without a proper scope but it worked .
I must give credit to Garry Pope who put me on to this fix.
Terry Lewis
Posted: Tue Jul 27, 2010 8:10 am Post subject: hot start |
That sounds good enough to me! How did you do that, did you pull a plug and just look at the darn thing? Sometimes the simple solution is the best!
Mark
Posted: Tue Jul 27, 2010 8:30 am Post subject: hot start |
That's correct .
I pulled a rear plug and closed the hangar door .
You can then see the spark very well .
Terry
