AOA audio Input To Intercom
gclabots(at)execpc.com
PostPosted: Tue Jan 10, 2006 5:19 pm    Post subject: AOA audio Input To Intercom Reply with quote
Looking for a way to get the AOA audio into my intercom or headset.
I have a Appollo GX 60 and a PS Engineering PS 1000II intercom.
If i put it in the music input of the intercom it mutes when any transmission is present.
Could I possibly wire it into my headset jack without problems?
Looking for a solution short of adding a audio panel.
Thanks Gerry
n744bh(at)bellsouth.net
PostPosted: Tue Jan 10, 2006 6:15 pm    Post subject: AOA audio Input To Intercom Reply with quote
jschroeder(at)perigee.net
PostPosted: Tue Jan 10, 2006 6:50 pm    Post subject: AOA audio Input To Intercom Reply with quote
Gerry -
Which AOA do your have? We wired our Proprietary Software AOA Sport to the
"unswitched audio" pin on the GArmin 340. The PSE box must have something
similar. If they do not, wire it to the ADF pin and placard that button on
the bezel as "AOA" and make sure it is punched on when you fly. This
assumes that you are not bothering with an ADF radio in your shiny new
OBAM experimental.
John Schroeder
Lancair ES - in Paint Shop
bkbrown(at)ashcreekwirele
PostPosted: Wed Jan 11, 2006 6:38 am    Post subject: AOA audio Input To Intercom Reply with quote
I was advised by Rob to wire to the unswitched audio pin on my audio panel, he advised against wiring it direct to the headset jack. My recommendation is to look over the pin diagram for your unit and call Rob with that in hand.
Bob Brown
Bill Denton
PostPosted: Wed Jan 11, 2006 6:47 am    Post subject: AOA audio Input To Intercom Reply with quote
The point seems to have been missed that the OP did not have an audio panel,and had no desire to install one.
