portable hydraulic press
jhankin(at)planters.net
PostPosted: Wed Jul 21, 2010 8:42 am    Post subject: portable hydraulic press Reply with quote
This is a portable hydraulic press that I designed to straighten the legs of my Firefly.
The unit can be used OFF the Firefly or attached to the leg without removing the wheel and associated parts.
Parts used.
5 inch wide channel iron 15 inches long
4 ton hydraulic jack, (Harbor Freight)
2 I/8 x 1 inch flat iron 17 inches long
2 1/8 x 1 inch flat iron 8 inches long (brace)
Heavy duty chain (1) 7 inches, (1) 8 inches)
2 3/8 inch Chain connectors
One jack adapter Made on lathe
One 1 inch conduit bending tool head
3/8 bolts only. ¼ inch WILL brake
1 jack handle 22 inches long to fit jack (4130), also serves as a carrying handle
Jimmy Hankinson
Firefly N6007L
Rocky Ford, Georgia
 Filesize:  966.79 KB
 Viewed:  5042 Time(s)
 Filesize:  1.05 MB
 Filesize:  866.01 KB
PostPosted: Wed Jul 21, 2010 12:41 pm    Post subject: portable hydraulic press Reply with quote
Parts used.
Jimmy Hankinson
Firefly N6007L
Rocky Ford, Georgia
 Filesize:  966.79 KB
 Filesize:  1.05 MB
 Filesize:  866.01 KB
frank.goodnight(at)att.ne
PostPosted: Thu Jul 22, 2010 4:44 am    Post subject: portable hydraulic press Reply with quote
Verry nice rig Jim. when you can't get to all the parts for Jims rig. just a 1/4 in. chain
with 2 chain hooks and a small hyd jack will get you back in the air again- use them
just like you would Jims rig. cheap efective and the parts can be bought almost anywhere.
Frank goodnight
Firestar 2
Brownsville , TX
To: kolb-list(at)matronics.com; Jimmy Hankinson <jhankin(at)planters.net>
Sent: Wed, July 21, 2010 11:38:18 AM
Subject: portable hydraulic press
Parts used.
Jimmy Hankinson
Firefly N6007L
Rocky Ford, Georgia
