Another newbie question:
GeoB
PostPosted: Wed Jul 14, 2010 8:04 pm    Post subject: Another newbie question: Reply with quote
I have a United sensitive altimeter sitting on my shelf. It confuses me.
When I use it in my car in the mtns it seems to work right, so I assume the
problem lies with me.
When the weather man says high pressure my altimeter starts reading high
altitude. This last coupla weeks of high pressure has shown the highest
'altitude' I have ever seen on it, while on my shelf. Seems to my pea-brain
that it should have been opposite that! Please someone help me unnerstan
this fee-nom-e-nom.
GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors"
Ralph B
PostPosted: Thu Jul 15, 2010 6:00 am    Post subject: Re: Another newbie question: Reply with quote
The lower the pressure, the higher the altimeter should read. I'm not sure what kind of altimeter you have, but when the pressure is high, it should read lower. Someone please correct me if I'm wrong.
I have seen it vary as much as 500' when a low pressure rolls in.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
by0ung(at)brigham.net
PostPosted: Thu Jul 15, 2010 7:53 am    Post subject: Another newbie question: Reply with quote
Someone please correct me if I'm wrong ..
Ralph
Ralph you are correct... with one possibility. if there is a altimiter setting window ( kallsman ) window that is adjusted for the proper barometer setting... the altitude should read equal... if not adjusting the altimeter for the proper barometric reading. your statement is correct.
boyd
Ralph B
PostPosted: Thu Jul 15, 2010 10:26 am    Post subject: Re: Another newbie question: Reply with quote
Boyd, isn't adjusting the altimeter for field elevation the same as adjusting the pressure in the Kollsman window?
There were some comments awhile back about setting the altimeter for zero elevation or field elevation. As an ultralight pilot, I didn't go anywhere and would set it to zero at the field I flew from. I did this for many years and got used to it. I continued this habit when I got the Kolbra and justified that I wanted to know exactly how high I was above the ground. All is fine and dandy until I go a few hundred miles to the next airport. Then I'm wondering why the altimeter is reading wrong when I land. Needless to say, I have changed my ways and adjusted my altimeter for field elevation before takeoff. I still zero it out on the Firestar because I don't go anywhere with that.
I also notice airshow pilots do the same thing. They adjust it for MSL field elevation to fly to the airport they are performing at and then zero it out before they perform.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
rickofudall
PostPosted: Thu Jul 15, 2010 10:57 am    Post subject: Another newbie question: Reply with quote
Ralph, Adjust the Kollsman window for barometric pressure and it should read field elevation, conversely, set field elevation and the Kollsman reads local barometric pressure. Setting field elevation at zero is only good so long as barometric pressure remains the same. It you fly to another field where the barometric pressure is the same, you get the difference between the two field's elevations. If you take your Kolb into class alpha airspace the kollsman window is set to 29.92" regardless of local elevation or barometer reading.
Rick Girard
On Thu, Jul 15, 2010 at 1:26 PM, Ralph B <ul15(at)juno.com (ul15(at)juno.com)> wrote:
[quote] --> Kolb-List message posted by: "Ralph B" <ul15(at)juno.com (ul15(at)juno.com)>
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=304953#304953
le, List Admin.
GeoB
PostPosted: Thu Jul 15, 2010 11:12 am    Post subject: Re: Another newbie question: Reply with quote
That's what I thought I knew till it looked like it was working backwards.
No Kallsman window, just a knob to set the altitude. Which I haven't touched for several months, as I watch it fluctuate. It is sensitive enough that when driving down the freeway it moves up and down as I go on overpasses and such.
GeoB
PostPosted: Thu Jul 15, 2010 6:08 pm    Post subject: Another newbie question: Reply with quote
ralph
yes that is the same.... and if you adjust the kollsman window the the proper barometric pressure.... the needle will show the elevation..... if there is a barometric pressure change and you don't change the kollsman window. the as the barometric pressure rises, the altitude indicated should decrease.
I always set the kallsman window to show the correct barometric pressure.... when talking with other pilots and trying to remain free and clear of their paint. all the pilots I know use altitude readings of msl.... not agl... I could see a benefit of using agl if doing aerobatic at an air show. but that is usually in a closed airspace environment
Boyd
pj.ladd(at)btinternet.com
PostPosted: Fri Jul 16, 2010 3:07 am    Post subject: Another newbie question: Reply with quote
[quote] all the pilots I know use altitude readings of msl.... not agl... I could see a benefit of using agl if doing aerobatic at an air show. but that is usually in a closed airspace environment
Boyd
Hi,not in the UK.QNH is usually used X country above 3000ft. QFE is normally given by the field you are going to land at, together with usual landing info. wind,runway in use, circuit direction etc.You then can fly the circuit on your altimeter without mental arithmetic. Circuit height usually 1000ft for light a/c etc and 800 or 600 for microlights.Not sure if there is a `best` way, probably what you are used to but at that stage of the flight the height above ground is paramount and if you land with zero alt. on the clock it seems simpler to me Cheers Pat
- Release Date: 07/15/10 11:35:00
PostPosted: Fri Jul 16, 2010 4:09 am    Post subject: Another newbie question: Reply with quote
There is an FAR that covers altimeter settings.
top
(a) Each person operating an aircraft shall maintain the cruising altitude or flight level of that aircraft, as the case may be, by reference to an altimeter that is set, when operating—
(1) Below 18,000 feet MSL, to—
(i) The current reported altimeter setting of a station along the route and within 100 nautical miles of the aircraft;
(ii) If there is no station within the area prescribed in paragraph (a)(1)(i) of this section, the current reported altimeter setting of an appropriate available station; or
(iii) In the case of an aircraft not equipped with a radio, the elevation of the departure airport or an appropriate altimeter setting available before departure; or
(2) At or above 18,000 feet MSL, to 29.92" Hg
The system is set up to operate per the FAR. Terrain and obstacle clearance are set up for MSL, and is field elevation of each airport.
Setting the altimeter to zero at home field is a bad habit introduced by ultralight instructors that did not know any better, or because they were not going to fly much further than the airfield perimeter.
The ultralight folks at Oshkosh and Lakeland still hold on to this ultralight policy of setting altimeter to zero while flying their traffic patterns.
Boyd
 Filesize:  142 Bytes
 Viewed:  11870 Time(s)
mdnanwelch7(at)hotmail.co
PostPosted: Fri Jul 16, 2010 4:55 am    Post subject: Another newbie question: Reply with quote
John,
Interesting that you point it out that there is a regulation for it. Excellent point!
It often looks like the "small airplane" crowd asks what others are doing regarding lots flying habits and practices, but we seem to forget that there's a "real" airplane bunch
that would run us over when we don't adhere to proper flying ettiquete.
Even though the light airplane person may not see himself as part of the "factory" crowd, he is expected to follow the federal rules. Experimental Catagory aircraft are aircraft, and they share the same air as 737s and Piper Arrows. Maybe we experimenters should look to the "regs" more often, rather than rely on annecdotal advice.
Mike Welch
MkIII
Subject: Re: Re: Another newbie question:
Date: Fri, 16 Jul 2010 07:08:52 -0500
§ 91.121 Altimeter settings. top
Boyd
The New Busy is not the old busy. Search, chat and e-mail from your inbox
PostPosted: Fri Jul 16, 2010 5:07 am    Post subject: Another newbie question: Reply with quote
How else would you regulate VFR and IFR cruising altitudes, terrain, and obtacle clearance?
Mike Welch
PostPosted: Fri Jul 16, 2010 5:44 am    Post subject: Another newbie question: Reply with quote
Circuit height usually 1000ft for light a/c etc and 800 or 600 for microlights.Not sure if there is a `best` way, probably what you are used to but at that stage of the flight the height above ground is paramount and if you land with zero alt. on the clock it seems simpler to me[quote] Cheers Pat
>>>>>>>>>>>>>>>>>>>>. landing may be easier,,, but if you encounter another aircraft in route are looking for him in the air in an effort of not trading paint... altitude above sea level should be more consistent way of knowing where to look. boyd Cheers
lcottrell
PostPosted: Fri Jul 16, 2010 12:54 pm    Post subject: Another newbie question: Reply with quote
Not to mention that the entire island is small enough that there is probably only one setting you need to make to have your altimeter read the right altitude no matter where you are. Not sure if there is any terrain much above flood stage anyway? Keep in mind that the above is not intended to insult, although the likelihood is probable, allow me to apologize beforehand.
Larry
Note: If you forward this email, please delete the forwarding history, which includes my email address.
PostPosted: Thu Jul 29, 2010 3:04 am    Post subject: Another newbie question: Reply with quote
Hi larry,
i could tell straight away that it was not intended to be insulting from the way you apologised in case it was.
Actually I think we have 3 altimeter setting areas to cover the country. Close attention to these enables us to look out of the cockpit and avoid Ben Nevis and Scafell Pike (978 metres). Snowdon pokes up a little way as well. The lowest point is 4metres (about 13ft to you) below sea level.Miles away. Probably a200 miles or more (just)
I still think that it a bit wacky to have to engage in mental arithmetic by flying on sea level pressure to calculate a landing height at some arbitrary figure instead of everyone flying the circuit at the same height and landing at zero on the clock
Pat
GeoB
PostPosted: Sun Aug 15, 2010 11:14 pm    Post subject: Re: Another newbie question: covering under the seat Reply with quote
I have been staring at my FS-I (when I am not sitting in it making engine noises). It has no fabric on the fuse. The PO took it off and I know not how much of the frame was covered. There is a short piece of aluminum sheet from the pod back, it ends in front of the stick a few inches. What do most Kolbers use under the seat? Do you folks use fabric or metal or?
Thanks!
GeoB
GeoB
GeoB
PostPosted: Sun Aug 15, 2010 11:17 pm    Post subject: Re: Another newbie question: Inspect wing swivel bolt? Reply with quote
I will be studying all the Kolb material I can find on the FS. But so far I don't know about inspecting parts. I was looking it over and the bolt that extends into the frame that the wing hangs on looks like it is kinda hard to get to. How often should it be inspected? This is the bolt the universal joint for the folding wing attaches with.
Thanks!
GeoB
GeoB
Eugene Zimmerman
PostPosted: Mon Aug 16, 2010 4:35 pm    Post subject: Re: Another newbie question: Reply with quote
Geo.
I suppose I'm being a bit snide here with my remark, but I'd say you should take that joint apart to inspect it every time you trash your wing, or whenever you detect any evidence of excessive up and down, or lateral movement at that location.
If I understand you correctly you are talking about the bolt that is actually a welded in part of the cage. I've never had one, or heard of one that needed to be replaced, but then again I seldom fold my plane.
ces308
PostPosted: Wed Aug 18, 2010 7:35 pm    Post subject: Re: Another newbie question: Reply with quote
...I was taught in ground school that when you fly from a HIGH to a Low ,to look out below.....
chris ambrose
M3X/Jabiru A-2200 143.8 hrs
n327CS
