Fuel Pressure on a 914
pestar
PostPosted: Tue Jul 13, 2010 1:09 pm    Post subject: Fuel Pressure on a 914 Reply with quote
Background
Building a MCR-4S (dynaero.com) with a 914 fitted with an intercooler. Have MGL instrumentation with fuel flow monitoring. Had thought about monitoring fuel pressure which leads to the following questions.
1. Does anyone monitor fuel pressure on their 914 and what value do they get out of it.
2. If you have done it where did you mount the sender as my first impression of doing this looks as so you have to hack into the Rotax pipework which I would prefer not if it can be avoided.
3. What value sender did you use and what type.
Appreciate your comments.
Peter Armstrong
Auckland, New Zealand
kenryan
PostPosted: Tue Jul 13, 2010 5:15 pm    Post subject: Fuel Pressure on a 914 Reply with quote
From Understanding the Rotax 914 document located here:
http://www.rotax-owner.com/pdf/UNDERSTANDING%20THE%20914%20ROTAX.pdf
Indicates fuel pressure is best monitored in relation to airbox pressure:
Maximum fuel pressure is 0.35 BAR (5.08 PSI or 10.36”) above airbox pressure
Minimum fuel pressure is 0.15 BAR (2.18 PSI or 4.45”) above airbox pressure
Normal fuel pressure is 0.25 BAR (3.63 PSI or 7.41”) above airbox pressure
Gauge for monitoring this way can be found here:
http://www.aircraftspruce.com/catalog/inpages/umadiff1.php
Ken Ryan
Anchorage, Alaska
On Tue, Jul 13, 2010 at 1:09 PM, pestar <peter(at)reivernet.com (peter(at)reivernet.com)> wrote:
--> RotaxEngines-List message posted by: "pestar" <peter(at)reivernet.com (peter(at)reivernet.com)>
Background
Peter Armstrong
http://forums.matronics.com/viewtopic.php?p=304701#304701
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
#avg_ls_inline_popup { position:absolute; z-index:9999; padding: 0px 0px; margin-left: 0px; margin-top: 0px; width: 240px; overflow: hidden; word-wrap: break-word; color: black; font-size: 10px; text-align: left; line-height: 13px;} [quote][b]
craig(at)craigandjean.com
PostPosted: Tue Jul 13, 2010 5:28 pm    Post subject: Fuel Pressure on a 914 Reply with quote
"Requires the use of a 1EU007D UMA different pressure sender."
MGL/USA supplies a version of a non-differential UMA sender that works with the MGL RDAC. Check with them to see if they can provide the same mod in the differential sender. Or it may be that the differential sender doesn't need the (electrical) mod. As I recall it had to do the the output of the older op-amp in the UMA sender.
-- Craig
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Ken Ryan
Sent: Tuesday, July 13, 2010 6:14 PM
Subject: Re: Fuel Pressure on a 914
Ken Ryan
Anchorage, Alaska
Background
Peter Armstrong
le, List Admin.
#avg_ls_inline_popup { PADDING-RIGHT: 0px; MARGIN-TOP: 0px; PADDING-LEFT: 0px; FONT-SIZE: 10px; Z-INDEX: 9999; PADDING-BOTTOM: 0px; MARGIN-LEFT: 0px; OVERFLOW: hidden; WIDTH: 240px; COLOR: black; LINE-HEIGHT: 13px; PADDING-TOP: 0px; POSITION: absolute; TEXT-ALIGN: left; WORD-WRAP: break-word } [quote]
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
