pchristensen10(at)austin. Guest
Posted: Thu Jul 08, 2010 7:45 am Post subject: Removing ethanol from gasoline |
Here is my experience with removing ethanol from gasoline.
In the North Austin, Texas area I have found no source for gasoline without
ethanol. The nearest I have found is more than an hours drive away without
any nearby airport. I could load up my van with 5-gallon cans, but buying
the cans and the cost of time and fuel for my van would make that difficult.
I have read everything I can on the subject on the Internet and have
corresponded with a few of you online.
Here is what I came up with. Last week I bought a 6-1/2 gallon carboy used
for making beer. I put 1 quart of water in the carboy and marked a line at
the top of the water. I then poured 5-1/2 gallons of high-test gasohol into
the jug. The pouring action stimulates the ethanol to begin separation from
the mix. After awhile the water-ethanol has separated from the mix and I
mark a new line that indicates the new level of the bottom of cleaned
gasoline. I use a siphon to siphon the cleaned gasoline off the top of the
water/ethanol leaving a gallon or so of good gas to avoid siphoning up any
water. (Note I do NOT pour the out this gas/water/alcohol from the jug.) I
can continue pouring gasohol into the carboy and the process starts all over
again. After a gallon or two of water/ethanol builds up, I siphon the
water/ethanol from the bottom of the jug and add a little more water.
I pour this cleaned gas into my plane through a Mr. Funnel Fuel Filter
Funnel, which is supposed to remove any remaining water. (I found no
detectable water in the filter after pouring 10 gallons)
I have run this so far about 50/50 with avgas I had in my tank.
I have only flown the one time a couple days ago for more than an hour with
no problems. Time will tell if problems develop.
I am NOT endorsing this process for others but only describing what I am
doing.
Pete
Kitfox III SN 1000
912
Grove
marwynne(at)windstream.ne Guest
Posted: Thu Jul 08, 2010 8:02 am Post subject: Removing ethanol from gasoline |
Did you think of how effected the Octane Rating ? Just a concern. The ethanol was add in place of other octane boosters.
msm_9949(at)yahoo.com Guest
Posted: Thu Jul 08, 2010 8:09 am Post subject: Removing ethanol from gasoline |
NOW I understand why ethanol-free gas costs so much more at the pump!
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
Hersey, Michigan
--- On Thu, 7/8/10, Pete Christensen <pchristensen10(at)austin.rr.com> wrote:
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Subject: Removing ethanol from gasoline
Date: Thursday, July 8, 2010, 11:43 AM
In the North Austin, Texas area I have found no source for gasoline without ethanol. The nearest I have found is more than an hours drive away without any nearby airport. I could load up my van with 5-gallon cans, but buying the cans and the cost of time and fuel for my van would make that difficult
Posted: Thu Jul 08, 2010 10:17 am Post subject: Removing ethanol from gasoline |
My 912 is an older lower compression engine. Regular unleaded car gas runs
just fine so that when hi-test looses a little octane no problem.
Pete
Posted: Thu Jul 08, 2010 10:23 am Post subject: Removing ethanol from gasoline |
Good point Marco! Imagine the size of the carboy they use.
Pete
do not archive.
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Thu Jul 08, 2010 10:32 am Post subject: Removing ethanol from gasoline |
Take care, Pete. The ethanol replaces MTBE which brings the octane number
back into spec. You probably will not hear engine detonation (pinging) due
to all the other noise. Burned pistons and valves could be the result.
Especially if your Rotax is the 912S.
Here's what I'm presently doing: If the premium fuel has no more that 5%
ethanol I go ahead and use it, so far no problems. (my fuel tanks are 2003
vintage and the fuel lines are now SAE J30R9) If the fuel contains more
than 5% ethanol I add 100LL as needed to bring the percentage back to 5%.
Decalin additive is used with the 100LL and oil changes are at 25 hrs.
Hope this helps.
Vic
Vic Baker
S7 912S Warp
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
Float Flyr
Posted: Thu Jul 08, 2010 12:22 pm Post subject: Removing ethanol from gasoline |
Pete it sounds to me like you are doing things properly. The next step
would be to reduce the amount of AVGAS in your mix just in case your engine
can't take the lower octane level fuel. Being the CR of the Rotax engines
isn't extreme I doubt you will have any problems.
BTW distil our leftover water alcohol mix to around 50C for fuel for your
fondu warmer or camp stove. Other leftovers will probably make good weed
killer and is bio degradeable.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Jul 08, 2010 12:34 pm Post subject: Removing ethanol from gasoline |
How’s that... Ethanol is added to the gas as it leaves the distributor... It doesn’t have to be separated... Just not added in the first place. The ethanol in fact costs more than 4 times the cost of the gas to grow and process. That means that gas not contaminated with ethanol should be considerably cheaper.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Marco Menezes
Sent: July 8, 2010 1:39 PM
Subject: Re: Removing ethanol from gasoline
Marco Menezes N99KX
Hersey, Michigan
--> Kitfox-List message posted by: "Pete Christensen" <pchristensen10(at)austin.rr.com>
In the North Austin, Texas area I have found no source for gasoline without ethanol. The nearest I have found is more than an hours drive away without any nearby airport. I could load up my van with 5-gallon cans, but buying the cans and the cost of time and fuel for my van would make that difficult.
I have read everything I can on the subject on the Internet and have corresponded with a few of you online.
Here is what I came up with. Last week I bought a 6-1/2 gallon carboy used for making beer. I put 1 quart of water in the carboy and marked a line at the top of the water. I then poured 5-1/2 gallons of high-test gasohol into the jug. The pouring action stimulates the ethanol to begin separation from the mix. After awhile the water-ethanol has separated from the mix and I mark a new line that indicates the new level of the bottom of cleaned gasoline. I use a siphon to siphon the cleaned gasoline off the top of the water/ethanol leaving a gallon or so of good gas to avoid siphoning up any water. (Note I do NOT pour the out this gas/water/alcohol from the jug.) I can continue pouring gasohol into the carboy and the process starts all over again. After a gallon or two of water/ethanol builds up, I siphon the water/ethanol from the bottom of the jug and add a little more water.
I pour this cleaned gas into my plane through a Mr. Funnel Fuel Filter Funnel, which is supposed to remove any remaining water. (I found no detectable water in the filter after pouring 10 gallons)
I have only flown the one time a couple days ago for more than an hour with no problems. Time will tell if problems develop.
I am NOT endorsing this process for others but only describing what I am doing.
Pete
Kitfox III ww.matronics.com/Navigator?Kitfox-List" target=_blank>http://www.matronicbsp; --> h= -->
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
Posted: Thu Jul 08, 2010 12:48 pm Post subject: Removing ethanol from gasoline |
Thanks Noel. You are one who knows the meaning of experimental aircraft.
My 912 being older and of lower compression requires only 86 octane. I plan
to burn only "cleaned" gasoline if it works out. Maybe I can modify the
home heating unit to burn ethanol in the winter or sell it to model airplane
guys.
Pete
Roger Lee
Posted: Thu Jul 08, 2010 4:42 pm Post subject: Re: Removing ethanol from gasoline |
Hi Pete,
If you are running a 912 series engine then Rotax has in writing that 10% ethanol is fine and people use much higher amounts than that around the world. Just bring your fuel system up to par for the ethanol and save yourself a lot of time and effort. Ethanol won't hurt your 912 Rotax.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Lion8
Posted: Fri Jul 09, 2010 4:25 am Post subject: Removing ethanol from gasoline |
I've been flying a Rotax 503 for 10 years now, using 10% ethanol gasoline with no problems. I have a Polyproplene fuel tank. Aircraft Spruce sel'ls the 'Blue' fuel line that is Alcohol resistant. I change these lines every year along with the fuel filter.Cheap insurance. I fly between 25 to 50hr a year. I also had an authorized Rotax mechanic tear the engine down to inspect the entire engine and to replace ALL organic materials in the engine, Carbs and fuel filter with alcohol resistant materials. 500hrs and no issues. I also syphon out all the fuel if it sits in the tank for more than two weeks. Syphoning out the tank allows all the small particles in the bottom of the tank to be drawn out.
Tom McDowell-NJ
EAA-216
_________________ Tom (Lion8), Currently Flying an LSA Trike
Rebuilding a Kitfox IV Speedster
Southern New Jersey |
Dick Maddux
Posted: Fri Jul 09, 2010 4:50 am Post subject: Removing ethanol from gasoline |
Pete,
Roger is absolutely correct, the alcohol is fine for your 912 (up to 10 percent) I am assuming the reason you are removing it is because of your tanks. My tanks are also the old formulation fiberglas coated with Kreem and I am also concerned about alcohol. I only have one station here in my area that carries no ethanol premium. When he goes then I will have to use ethanol fuel (unless I go to a boat dock or the gas distributor selling fuel for off road farm equipment... a possibility)
As you are adding avgas to the mix, you are adding back some of the octane you removed but what are you left with? Do you have the needed 87 for your engine 87? I know on my engine if I use regular that is a little old I get kickback on shutdown and the prop rotates backward (no good) Burning premium or adding octane booster (Lucas brand) will stop this from happening. I now burn premium in the hot summer months. (plus put a block of ice on the engine to cool it down for start)
If you have detonation from burning low octane fuel, you will never hear it, but your engine will certainly feel it.
My two cents
Dick Maddux
Fox 4, 912UL
Milton,Fl
Posted: Fri Jul 09, 2010 4:52 am Post subject: Removing ethanol from gasoline |
Thanks Roger and Tom, but (older fiberglass tanks) + ethanol = crash. QED
Pete
Posted: Fri Jul 09, 2010 5:01 am Post subject: Removing ethanol from gasoline |
Dick,
So far I get no kickback. I still have some av gas in the tank but as I continue to fly I will eventually have clean gasoline. I can't find clean gas less than 1+ hour away by car at a boat dock. If I had floats I could taxi right up to the pump since it's only 1/2 hour flying time. I think Texas government is a bunch of horses asses allowing us to burn corn instead of sweet Texas crude. Thanks Damn-acrats.
Pete
KeysFox
Posted: Fri Jul 09, 2010 5:12 am Post subject: Removing ethanol from gasoline |
Pete,
I found that the ethanol and water that settles out will flow through the
fuel funnels that are supposed to trap water. You might want to try that
with your Funnel.
BJ
N154K
[quote] Good point Marco! Imagine the size of the carboy they use.
Pete
do not archive.
_________________ B Jones
N154K
443-480-1023 |
Posted: Fri Jul 09, 2010 5:19 am Post subject: Removing ethanol from gasoline |
That's something to think about. I probably need a little off airport
landing practice.
Pete
Doesn't have to make sense, Noel. The government and oil companies are involved.
Â
Marco Menezes N99KX
Hersey, Michigan
Â
--- On Thu, 7/8/10, Noel Loveys <noelloveys(at)yahoo.ca> wrote:
Subject: RE: Removing ethanol from gasoline
Date: Thursday, July 8, 2010, 4:26 PM
Â
Noel
Â
Â
Â
Marco Menezes N99KX
Hersey, Michigan
Â
Roger Lee
Posted: Fri Jul 09, 2010 5:24 am Post subject: Re: Removing ethanol from gasoline |
Hi All,
My tanks are Kreem Wiessed and that is just fine for alcohol. There are over 1500 Flight Design CT's flying world wide and about 320 here in the states. They are all kreem Wiess coated. Kreem Weiss is impervious to alcohol and just about anything else. It is one of the top tank coatings on the market. If you have a tank you are worried about them Kreem it and don't worry.
p.s.
I never had much luck with MR. Funnel taking water out either. Your Rotax will burn a certain amount of water in the fuel so long as it doesn't become excessive. That's why I don't worry about a little water in the fuel or using ethanol. That said I do live in Tucson, AZ where the humidity is usually only 10-15% and we only get 12" of rain a year. There are thousands of people who live in a humid rainy climate with their Rotax's around the world and don't have any major issues with just humidity.
p.s.s.
Hi Dick,
How are you doing? Hope your staying out of the heat?
Why don't you use 91 oct. all year and not worry?
Tucson, Az.
Cell 520-349-7056 |
KeysFox
Posted: Fri Jul 09, 2010 5:25 am Post subject: Removing ethanol from gasoline |
Multiple folks with expertise in the commercial fuel science industry that
I spoke with, who would not endorse the process of removing the ethanol
from auto fuel to use the cleaned gas in an aircraft, when pressed, said
that if I started with "cleaned" premium auto fuel and adding less than
25% leaded (100LL) avgas the result would have over 87 octane.
What has been missed in this thread so far, is the potential for settleout
to occur in a planes gas tank. I have had it occur in other applications.
And the engines would not run on the settleout. Probably not a problem in
dry climate from condensation and in planes with gas tank caps that
prevent rain water from getting in.
BJ
N154K
BJ
N154K
<marwynne(at)windstream.net>
N154K
443-480-1023 |
Posted: Fri Jul 09, 2010 5:33 am Post subject: Removing ethanol from gasoline |
I'll Kreem my tank when I need a recover. Or sooner if you'll come help
Roger.
Pete
