hans-chr.erstad(at)c2i.ne Guest
Posted: Wed Jul 07, 2010 10:41 am Post subject: KIS IT-1 Aerodynamics - Main wheel location |
Hello Mark
Your wrote: "Next time you fly please try this for me but be very careful
and let me know what happens!"
I went flying today, and on takeoff I held the stick back just enough to
lift the nose wheel and take off. I held the stick in that position for a
while (2-3 seconds?). The nose became too high and speed too low. Just as
you predicted.
I have not really noticed this, but apparently I always reduce stick back
pressure when the airplane lifts off, to keep pich angle more or less
constant, and low enough for the speed to increase.
Landing again, I can keep the nose wheel from comming down immediately after
landing, and can keep it raised for the first 50-100 meters or so. With CG
at max fwd position, I need to be concentrated to manage this. If I land at
a short runway, I let the nosewheel come down, in order to start braking.
Regards, Hans Christian
-----Opprinnelig melding-----
Fra: owner-kis-list-server(at)matronics.com
[mailto:owner-kis-list-server(at)matronics.com] På vegne av Mark Kettering
Sendt: 5. juli 2010 20:18
Til: kis-list(at)matronics.com
Emne: Re: SV: Re: KIS IT-1 Aerodynamics
Hello Hans,
| Quote: | I have flown my KIS 1 for 10 years now, and I agree with 'OC' comments
about the handling with respect to difficulties making consistent
landings and keeping the nose wheel up.
I have flown a TR1 with the main gear in the stock position and with that
aircraft I also had the same problems. So I made some calculations and
found out that the stock main gear location was too far aft. On my TR1 I
then moved it forward and fully eliminated not only this problem on my
aircraft but also the takeoff tendency to over rotate. When flying with
Rich and watching the stick I noted that he had to pull way back to rotate
then quickly release this back force and movement to prevent over rotation
on lift off.
| Quote: | About the wing/fuselage fairing. I have meet Julian several times at
fly-in. He told that the fairing modification made the landings with a
low approach speed a lot easier. Why not believe his experience? I
think he is the only one to make the modification, and having
experiencd what difference it makes. I have fairing modification on my
to-do list. But I may never come to that item on my list, as I feel the
landings are still OK, and I do not operate from runways shorter than
800 meters. I usually keep a little power on in the flare.
Well, I am not a believer! But that has little to do with Julian's
experiences. More to do with science and engineering methods. At some
point with more data I may agree that the elevator loses authority due to
wing fuselage junction separation. At this point I am waiting on seeing the
video for myself. The one still picture I have seen does not seem to
support the conclusion that the wing fuselage junction is causing separation
of flow over the tail. I also never have a sudden loss or any loss of
elevator authority with my aircraft at any time and I have the stock wing
root fairings so this data also does not seem to support that conclusion.
But this is not to say that Julian did not have this problem. Maybe his
plane is slightly different than mine. Maybe my more poor (or maybe better)
fit of my parts in this area prevented a problem that his plane had. Who
knows?
But I do do know the stock main gear location is too far aft relative to the
CG (range) location. I also know that angling the gear forward (moving the
gear contact point forward) reduces the hard nose let down at all CG
locations and cures the tendency to over rotate.
Next time you fly please try this for me but be very careful and let me know
what happens! As you pull back to rotate just hold the stick in the same
location and fly off the runway. This is how a good handling aircraft
should takeoff. It should not need pilot input beyond a steady back
pressure. You should not need to release or push forward. The plane should
literally "fly itself" off the runway. But if you do this in the TR1 with
the main gear in the stock location you will over rotate and need to move
the stick forward. Or you will stall and maybe worse.
Also please keep in mind that the gear location is very easy to change.
Mark
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
John Jackson
Joined: 27 Mar 2010 Posts: 14 Location: Shrewsbury, UK
Posted: Wed Jul 07, 2010 11:00 am Post subject: KIS IT-1 Aerodynamics - Main wheel location |
Hello all
I'm not sure if this is worth anything to the discussion but there's a video on youtube of my TR-1 landing on a short grass strip last weekend.
http://www.youtube.com/watch?v=ZZz2DuQXACo&feature=related at 8minutes 48 seconds onwards.
I hold the power at about 1200rpm until the very late, short flare. The nose wheel could have been held off but I let it lower early to begin braking. I then had to pick it up again to cross a small track that I'd not noticed until quite late in the landing.
I was one-up with about 30ltrs of fuel and needed about 350m on the downslope to come to a halt.
JJ
From: Hans Christian Erstad <hans-chr.erstad(at)c2i.net>
To: kis-list(at)matronics.com
Sent: Wednesday, 7 July, 2010 19:39:55
Subject: Re: KIS IT-1 Aerodynamics - Main wheel location
--> KIS-List message posted by: "Hans Christian Erstad" <hans-chr.erstad(at)c2i.net (hans-chr.erstad(at)c2i.net)>
Hello Mark
you predicted.
Fra: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)
[mailto:owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)] På vegne av Mark Kettering
Til: kis-list(at)matronics.com (kis-list(at)matronics.com)
--> KIS-List message posted by: Mark Kettering <mantafs(at)earthlink.net (mantafs(at)earthlink.net)>
Hello Hans,
on lift off.
knows?
Also please keep in mind that the gear location is very easy to www.matronics.com/Navigator?KIS-List" target=_blank>http://www.matronics.========================
