Posted: Mon Jul 05, 2010 6:35 pm Post subject: For Sale: Hartzell extended hub prop, Precision fuel injecti |
On 7/4/2010 11:15 PM, Charlie England wrote:
| Quote: | I have for sale a nearly new Hartzell HC-M2YR-1BF extended hub prop.
Also available, a used governor & high pressure line for this prop.
This is the prop that fit's James' 'long' cowl without the need for an
extension. The prop was installed new on a Mustang II, and removed
when the builder retired the airframe with around 100 hrs on the prop
(he didn't want to worry about liability when he quit flying the plane).
I also have available a sump & intake tubes for a parallel valve O-360
that is set up for a forward facing servo. It's a sump from an A-1x
series engine that originally had a rear induction, modified by a
certified engine shop for a forward facing injector. The sump & intake
tubes will fit an unmodified Rv-x motor mount (unlike the 'C' series
sumps). The servo mount position appears to be within fractions of an
inch of the OEM Lyc forward facing servo, based on comparing pics of
the OEM part to this one.
Additionally, I have a Precision EX5VA1 fuel injection system,
complete from the firewall to the heads, including the flex lines with
firesleeve, high pressure pump, servo, distribution block, injector
lines, and injectors. This system came off an RV-7 with less than 10
hours (wrecked). This system is 'as new', if it was still in the
packing, you couldn't tell it had ever been installed.
If you're interested in any of these items, email me or give me a call
at 601-879-9596 & we can discuss price (prices will be very reasonable).
Correction: the prop's model number is HC-M2YR-1BF.
