Handheld GPS
tscott165(at)cableone.net
PostPosted: Thu Apr 27, 2006 3:15 am    Post subject: Handheld GPS Reply with quote
Anybody had any experience with a Lowrance 2000C? Looking for a
portable unit and it got good review from Aviation Consumer last
year. Reportedly has poor backup battery life. Looking for feedback/
suggestions.
Scott Boyce, N28339
Robert.Dwork(at)Arbella.c
PostPosted: Thu Apr 27, 2006 3:41 am    Post subject: Handheld GPS Reply with quote
I've had the 2000c for two months now, and I like it very much. I can't
really compare it to any other aviation unit (my prior GPS was Trimble
Flightmate circa 1993) although I have a Garmin 392c marine GPS in my boat
which is similar in size, functionality, etc. Both are nice units.
I like the Lowrance, though. Very fast lock onto sats, great direct sunlight
visibility, all the functionality you would want and expect, nothing is
missing.
Backup battery IS very poor....turn down the backlight and you may get 30-45
minutes out of it. It is purely for emergency backup in the event of primary
power failure/rundown. I have mine hooked up through an input jack into the
panel, where it draws power off the bus and communicates with the JPI 450
Fuel Flow.
It comes with a great bracket system. I have it attached to the short arm
(rather than the yoke mount) that has a powerful suction cup on the
end....clamps right onto the windshield just ahead of the interior lights
rocker switch and I can punch buttons with my left hand while still holding
the yoke.
A few caveates: I find searching through the database for airports by
identifier isn't great, can't always find them that way, although by name,
there they are. There are a few popup alarms that are very useful to enable,
but you have to press a button to get rid of them....that can be annoying in
densely controlled airspace, where "Entering the X Airspace" message keeps
popping up every couple of minutes. It should remove itself after a user-set
period.
I did pretty extensive shopping for this unit once I decided the Lowrance is
what I wanted. I found Rob Rollison at airplanegear.com, who had by far the
lowest price, and he was a pleasure to do business with. I highly recommend
that if you don't plan to hard-wire the power in some way, purchase the
small powerpack called the "Go-Pak".
Bob Dwork
Traveler N9536L
n32romeo(at)aol.com
PostPosted: Thu Apr 27, 2006 7:45 pm    Post subject: Handheld GPS Reply with quote
Since as I read the Lowrance 2000C is designed to run on 6VDC, what did you do to step the voltage down from the bus? I have been thinking of this unit also, but in my AA-1B I have my old Megellan GPS and my portable Intercom wires spliced together and plugged into the cigarette lighter. I see the Lowrance comes with a cigarette lighter with a built in step down transformer.
Rich Harrison
AA-1B N1632Romeo
Fuel Flow.
PostPosted: Fri Apr 28, 2006 4:30 am    Post subject: Handheld GPS Reply with quote
I'll tell you exactly how I did it, Rich.
I said to my avionics guy: "Please attach my 2000c to my JPI FS 450", and he
did.
I'm sorry I don't have a better answer....the electrical system of my
Traveler scares me, because the more I read about it on the lists, the more
confused I get. Mechanical stuff I get: electrical stuff I leave alone.
I do know that for power alone (ie; a data cable is required and purchased
sparately to communicate with the fuel flow computer) the lighter plug works
just fine in the console lighter socket.
PostPosted: Sat Apr 29, 2006 3:49 am    Post subject: Handheld GPS Reply with quote
The specs I saw said the Lowrance 2000c runs on 5-35 volts DC. It
runs fine from the cigarette lighter in car or plane. Batteries are
for standby back-up only and go down quickly when operating on
batteries only. I bought an AC/DC 12V adapter at radio shack with a
cigarette lighter outlet for $27. I plug the units power cord into
the adapter and can explore the intricacies of the unit or set up
flight plans and waypoints at home and not be concerned about batteries.
Scott Boyce
AA5B N28339
Rich Harrison
AA-1B N1632Romeo
<Robert.Dwork(at)Arbella.com>
JPI 450
Fuel Flow.
n32romeo(at)aol.com
PostPosted: Sat Apr 29, 2006 9:48 am    Post subject: Handheld GPS Reply with quote
This is from the operating manual (downloaded from Lowrance)
Input power:......................6 volts DC (uses four 1.5v AA batteries as
emergency backup power). Cigarette lighter
power adapter included. Optional rechargeable
battery pack available.
From what I understand the Cigarette lighter plug has the voltage step-down transformer built into it to feed the unit 6VDC. I don't think you could connect the unit directly off the aircraft bus without providing some sort of step-down transformer. The Lowrance Airmap 500 / 600 models run on 3VDC.
Rich
Scott Boyce
AA5B N28339
PostPosted: Sat Apr 29, 2006 10:20 am    Post subject: Handheld GPS Reply with quote
Check it out on the Lowrance website:
http://www.lowrance.com/Aviation/Products/AM2000C.asp
It says 5 - 35 volts via cigarette lighter adapter. Isn't the
cigarette lighter in your plane wired directly to the bus? I think so
and therefore supplies whatever your battery or alternator is
cranking out, somewhere between 12 and 14 volts, usable by most
portable GPS, etc designed to run off the cigarette lighter without
any further conditioning.
Scott Boyce
AA5B, N28339
batteries as
Rich
<tscott165(at)cableone.net>
batteries.
Scott Boyce
AA5B N28339
n32romeo(at)aol.com
PostPosted: Sat Apr 29, 2006 7:59 pm    Post subject: Handheld GPS Reply with quote
Yes, but you must use the supplied cigarette lighter plug that provides the unit with the 6VDC (stepping down from the bus voltage) is my understanding. I was just wondering what the installer did on Bob Dwork's Traveler to as he states: "I have mine hooked up through an input jack into the panel, where it draws power off the bus". I am thinking the installer must have installed some form of step-down transformer to feed the unit 6VDC (or installed the cigarette lighter plug behind the panel).
I have a similar issue that I am feeding multiple equipment from the cigarette lighter. Currently I have the wires going to my portable intercom and my old GPS spliced together and then plugging into the cigarette lighter. My intercom needs 12 volts, so this same set-up would not work with the Lowrance supplied plug. This would be a minor problem to solve with Radio Shack parts, just need to put together the schematic.
Maybe I am wrong on this. If someone with a 1000 or 2000 could measure the voltage on the connector going to the GPS out of the cigarette lighter and let me know if this is bus voltage (12 or 24) or stepped down to something close to 6VDC, that would tell me what I need to do.
Rich
dwork(at)comcast.net
PostPosted: Sun Apr 30, 2006 4:13 am    Post subject: Handheld GPS Reply with quote
Rich, I can find out for you exactly what was done by the avionics tech. He
did NOT use the cigarette power cord supplied with the unit because, as I
said, I had to buy a separate data cable, which is a four-wire lead (one
power, one ground, and two data connections to the fuel flow meter - which
takes info from the Lowrance and tells me how much fuel I'll need to get to
my destination, how much reserve I'll have when I get there, and what I'm
getting for NMPG ). My statement that the GPS power goes into a jack isn't
quite accurate - the jack is there for legality purposes ( as the portable
GPS is not considered portable if it is directly hard-wired into the
electrical system - so says my avionics tech ) but actually, the power lead
from the gps DOES have a direct connection into the system. The
"portability" arrives from the ability to disconnect the power cord from the
back of the GPS and run it on batteries - for the 30 minutes it'll last).
Again, I suggest you might want to call or write Rob Rollision at
airplanegear.com with questions about the 2000c- he knows this unit very
well.
PostPosted: Mon May 01, 2006 7:27 am    Post subject: Handheld GPS Reply with quote
The reason you must use the supplied cigarette lighter plug is
because the other end of the cable is terminated with a connector
with the specific pin configuration to plug into the GPS unit.
Scott Boyce
I need to do.
Rich
