SD-20 alternator
tdawson-townsend(at)auror
PostPosted: Wed Jun 16, 2010 3:41 pm    Post subject: SD-20 alternator Reply with quote
Anyone using a B&C SD-20 alternator on the vacuum pad? I was not getting any juice on initial engine runs, but I’m wondering if it really has to get up to “run up” engine speeds to produce much. I did basic trouble shooting in the hangar and didn’t see anything amiss.
What are the experiences of others?
TDT
Tim Dawson-Townsend
RV-10 40025
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
Phil.Perry(at)netapp.com
PostPosted: Wed Jun 16, 2010 3:53 pm    Post subject: SD-20 alternator Reply with quote
An ALT should be producing power at the most modest idle settings. A generator would behave as you described.
Phil
From: Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero>
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: Wed Jun 16 16:16:36 2010
Subject: RV10-List: SD-20 alternator
TDT
Tim Dawson-Townsend
RV-10 40025
tdt(at)aurora.aero
rene(at)felker.com
PostPosted: Wed Jun 16, 2010 3:59 pm    Post subject: SD-20 alternator Reply with quote
I am and I think it has to be 1800 RPM or better. But don’t quote me……..
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Wednesday, June 16, 2010 5:17 PM
Subject: SD-20 alternator
TDT
Tim Dawson-Townsend
RV-10 40025
recapen(at)earthlink.net
PostPosted: Wed Jun 16, 2010 4:02 pm    Post subject: SD-20 alternator Reply with quote
Mine works fine at idle speeds - I test it each time by energizing it before the primary.
Site Admin
PostPosted: Wed Jun 16, 2010 4:05 pm    Post subject: SD-20 alternator Reply with quote
Did you connect it up with a B&C external regulator? I've got an SD-20 as a secondary on my RV-8 and I find that it works nicely. At idle, however, it definitely doesn't put out full current. At cruse it does alright, but it can't keep up if I've got all the lights turned on. This is to be expected, though, since its only rated at 20amps.
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Enjoying The Fruits of 2500 Hours of Labor...
TDT
Tim Dawson-Townsend
RV-10 40025
<mailto:tdt(at)aurora.aero>tdt(at)aurora.aero
partner14
PostPosted: Wed Jun 16, 2010 4:13 pm    Post subject: SD-20 alternator Reply with quote
Although my B&C 60amp alternator seems to work fine at lower rpm settings, the 20 seems to need more revs to offset the load and show a positive current.
My experience, Don McDonald
--- On Wed, 6/16/10, Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> wrote:
Date: Wednesday, June 16, 2010, 4:16 PM
TDT
Tim Dawson-Townsend
RV-10 40025
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Don A. McDonald
40636
n223rv(at)wolflakeairport
PostPosted: Wed Jun 16, 2010 4:24 pm    Post subject: SD-20 alternator Reply with quote
How are you troubleshooting it? It will not output anything until the main alternator 'fails'. Start the engine, pull the breaker or turn the main alternator off and the secondary should kick in.
On Jun 16, 2010, at 7:16 PM, "-Townsend,Timothy" <tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)> wrote:
TDT
Tim Dawson-Townsend
RV-10 40025
[url=mailto:tdt(at)aurora.aero]tdt(at)aurora.aero (tdt(at)aurora.aero)[/url]
aarongleixner(at)sbcgloba
PostPosted: Wed Jun 16, 2010 5:10 pm    Post subject: SD-20 alternator Reply with quote
I just got my plane flying, and thought I had a problem with my B&C SD-20. It did not appear to work at all (voltage at battery voltage when turned on during ground runs). Rather than trouble shoot the backup alternator, I decided to "fix" after first flight. Once I got the plane flying and running at higher RPM, it worked fine.
Aaron
Sent: Wed, June 16, 2010 8:12:34 PM
Subject: Re: SD-20 alternator
TDT
Tim Dawson-Townsend
RV-10 40025
tdt(at)aurora.aero
<?XML:NAMESPACE PREFIX = SKYPE /> 617-500-4812 617-500-4812 (office)
617-905-4800 617-905-4800 (mobile)
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List=nofollow>http://forums.matronics.com
[quote]p://www.matronics.com/contribution" target=_blank rel=nofollow>http://w=======================
sean(at)stephensville.com
PostPosted: Wed Jun 16, 2010 6:06 pm    Post subject: SD-20 alternator Reply with quote
"Status: Enjoying The Fruits of 2500 Hours of Labor..."
Matt, quit enjoying those fruit and get us some videos. Priorities man, priorities! Smile
Sean
#40303 - Not eating any fruit.
RV-8 #82880 N998RV
> TDT
> Tim Dawson-Townsend
> RV-10 40025
Deems Davis
PostPosted: Wed Jun 16, 2010 6:23 pm    Post subject: SD-20 alternator Reply with quote
B&C used to have a graph, that plotted AMP output vs RPM for all of their alternators. I just looked on their web-site and couldn't find it. My memory of the graph is that the SD-20 doesn't produce it's full 20 am output until it's turning near max RPM's. My SD-20 Low Voltage light is lit when the engine is at idle. I have a check list item on my run-up to check that it extinguishes when I go through my run up.
Deems Davis
N519PJ
www.deemsrv10.com
On 6/16/2010 6:09 PM, Aaron Gleixner wrote: [quote] I just got my plane flying, and thought I had a problem with my B&C SD-20.  It did not appear to work at all (voltage at battery voltage when turned on during ground runs).  Rather than trouble shoot the backup alternator, I decided to "fix" after first flight.  Once I got the plane flying and running at higher RPM, it worked fine.
Aaron
From: Don McDonald <building_partner(at)yahoo.com> (building_partner(at)yahoo.com)
--- On Wed, 6/16/10, Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> (tdawson-townsend(at)aurora.aero) wrote:
From: Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> (tdawson-townsend(at)aurora.aero)
TDT
Tim Dawson-Townsend
RV-10  40025
tdt(at)aurora.aero
gengrumpy(at)aol.com
PostPosted: Wed Jun 16, 2010 11:04 pm    Post subject: SD-20 alternator Reply with quote
Mine runs fine above 1200 rpm or so.
Grumpy
On Jun 16, 2010, at 6:21 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
[quote] B&C used to have a graph, that plotted AMP output vs RPM for all of their alternators. I just looked on their web-site and couldn't find it. My memory of the graph is that the SD-20 doesn't produce it's full 20 am output until it's turning near max RPM's. My SD-20 Low Voltage light is lit when the engine is at idle. I have a check list item on my run-up to check that it extinguishes when I go through my run up.
Deems Davis
N519PJ
www.deemsrv10.com
Aaron
From: Don McDonald <[url=mailto:building_partner(at)yahoo.com]building_partner(at)yahoo.com (building_partner(at)yahoo.com)>[/url]
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
--- On Wed, 6/16/10, Dawson-Townsend,Timothy <[url=mailto:tdawson-townsend(at)aurora.aero]tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)>[/url] wrote:
From: Dawson-Townsend,Timothy <[url=mailto:tdawson-townsend(at)aurora.aero]tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)>[/url]
TDT
Tim Dawson-Townsend
RV-10 40025
rene(at)felker.com
PostPosted: Thu Jun 17, 2010 5:03 am    Post subject: SD-20 alternator Reply with quote
Need to add a correction……..I am running the 8 amp model……not the 20 amp.
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker
Sent: Wednesday, June 16, 2010 5:55 PM
Subject: RE: SD-20 alternator
Rene' Felker
N423CF
801-721-6080
TDT
Tim Dawson-Townsend
RV-10 40025
 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution
