Posted: Sat Jun 12, 2010 5:44 pm Post subject: LED light strips |
| Quote: | Sounds like I'm okay. I just need to figure out where to mount the
resistor so the heat isn't an issue.
How do you plan to use this product? I sounds like
a LOT of light output capability.
Posted: Sat Jun 12, 2010 5:46 pm Post subject: LED light strips |
OOPS . . . scratch the above . . . I picked it up
in your earlier post. I was just thinking that
these would be about 100 times more light than
what was needed for cockpit night lighting.
mrspudandcompany(at)veriz Guest
Posted: Sun Jun 13, 2010 4:43 am Post subject: LED light strips |
Rather than use a resistor, I would cut the
strip in half, as the manufacturer suggests, and put the 2 strips in series.
This way you need no resistor and you can run it on 24V. See attached
sketch.
Roger
 Download |
| Filename: |
winmail.dat |
13.35 KB |
| Downloaded: |
298 Time(s) |
